Cell Phones Logo
Posted on May 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have no option that reads wifi connect in the apps. all i have is a WAP, or Data account in the internet services. under the Data file im asked for GSM or GPRS data. under the WAP file, im given the option of the internet services, i think i'm supposed to use the input adress option but i don't know what adress to put there(i put my e-mail in,i think thats wrong).
Mamoon Haltam
Level 3:
President:
  • Master 695 Answers
  • Posted on May 11, 2011
Mamoon Haltam
Master
Level 3:
President:
Answers
695
Questions
0
Helped
131487
Points
2494
NO NOT YOUR EMAIL
AND YOU DONT NEED TO PUT IT MANUALLY
CALL YOUR SERVICE PROVIDER ,AND ASK THEM TO SEND YOU THE INTERNET AND GPRS SETTINGS
THEN THEY WILL SEND THEM TO YOU AS TEXT MESSAGE
THEN WHEN YOU RECEIVE THEM SAVE THEM AND RUN THEM AS DEFUALT IF IT ASKS YOU TO RUN AS DEFUALT
THEN TURN YOUR MOBILE OFF FOR 3 MINUETS AND RE SWITCH IT ON
THEN THE INTERNET AND GPRS SERVICE NOW IS ACTIVATED AND YOU CAN USE THE INTERNET FROM YOUR PHONE
3helpful
2answers
Set up gps on sicphone
GO TO SERVICES AND FOLLOW THE FOLLOWING:
SELECT DATA ACCOUNT
SELECT GPRS
SELECT ANY OF THE PROFILES LISTED(EXAMPLE CHINA MOBILE)
A SCREEN SHOWS ACCOUNT NAME, APN, USER NAME AND MORE
EDIT ACCOUNT NAME TO AT&T, GO ON OPTIONS AND PRESS DONE
EDIT APN EDIT TO wap.cingular (lower case), GO ON OPTIONS AND PRESS DONE.
EDIT USER NAME TO [email protected] (UPPER CASE) AND PRESS DONE.
EDIT PASSWORD TO CINGULAR1 (UPPER CASE) AND PRESS DONE.
EDIT AUTH. TYPE TO SECURE.
SELECT DONE AND IT SHOULD ASK TO SAVE, SELECT YES.
GO BACK A COUPLE OF TIMES UNTIL THE OPTION WAP AND DATA SUPPORT APPEARS AGAIN
SELECT WAP
SELECT SETTINGS
SELECT EDIT PROFILE
SELECT SIM 1 OR SIM 2 (OTHER SIM NEEDS SETUP IF BEING USED ALSO)
IF AT&T APPEARS SELECT IT, IF NOT EDIT ANY PROFILE AND RENAME IT AT&T.
SELECT EDIT PROFILE
GO ON HOMEPAGE AND CHANGE IT TO http://device.home lower case)
GO ON DATA ACCOUNT, THAN GPRS, AND SELECT AT&T.
GO ON CONNECTION TYPE, ITSHOULD READ HTTP, PRESS ON IT, SELECT HTTP
ENTER PROXY ADDRESS 066.209.011.032
ENTER PROXY PORT 8080
PRESS OK THAN SELECT DONE AND IT SHOULD ASK TO SAVE, SELECT YES.
SELECT ACTIVATE PROFILE( ATT WILL APPEAR AS SELECTED)
THE PHONE IS READY. GO TO SERVICES AND SELECT HOMEPAGE FOR INTERNET.
MMS SETTINGS
1. Select Messages
2. Select MMS
3. Select MMS Settings
4. Select Edit Profile
5. Select any profile
6. Choose Edit Profile
7. Edit Rename Profile to AT&T MMS
8. Press Options
9. Press Done or OK
10. Edit Home Page to http://mmsc.cingular.com
11. Press Options
12. Press Done or OK
13. Select ATT MMS and press OK
14.Edit Connection Type to HTTP
15.The IP address is 066.209.011.032 and the port number is 8080 and press OK
16.Edit the Username to [email protected] (UPPERCASE)
17. Press Options
18. Press Done or OK
19.Edit the Password to CINGULAR1 (UPPERCASE)
20. Press Options
21. Press Done or OK
22. Press Done
23. When prompted to SAVE please select Yes
24. Select Activate Profile and yes.
tip
Sciphone i68 AT&T GPRS & MMS Internet Settings
Thanks to the author, follow these steps:
SELECT DATA ACCOUNT
SELECT GPRS
SELECT WAP
SELECT SETTINGS
SELECT EDIT PROFILE
SELECT EDIT PROFILE
MMS SETTINGS
1. Select Messages
2. Select MMS
8. Press Options
9. Press Done or OK
11. Press Options
17. Press Options
20. Press Options
22. Press Done
2helpful
I bought and sciphone which the model is i9+++ and its through att but they said that they couldnt help me with my problem of getting my internet to work. everytime i try to get on it it say gprs not...
AT&T Internet and MMS Settings Sciphone i68
SELECT DATA ACCOUNT
SELECT GPRS
SELECT WAP
SELECT SETTINGS
SELECT EDIT PROFILE
SELECT EDIT PROFILE
MMS SETTINGS
1. Select Messages
2. Select MMS
8. Press Options
9. Press Done or OK
11. Press Options
17. Press Options
20. Press Options
22. Press Done
Inernet settings for china mobile
hi...
do the following steps to set the airtel internet settings....
1)In Wap profile in setting for networksetup select a profile name it, home page :http://www.google.com gateway :100.001.200.099
port:8080 Data account :Airtel
In Data Setting :Put same name for profile as Data account : Airtel
Apn: airtelfun.com
Auth. type : normal
Data Setting And Wap Settings r connected together as part of Wap
or
2) Airtel Live
first click SERVICES icon in main menu==>DATA ACCOUNT==>GPRS==>EDIT any existing account==>
Account Name--> LIVE
APN-->airtelfun.com
Auth. Type-->Normal
save all the settings.
Come back to SERVICES==>WAP==>SETTINGS==>EDIT PROFILE==>EDIT any existing account==>
Rename Profile==> Airtel Live
Homepage==>http://live.airtelworld.com
data account==> LIVE (which we created previously)
Connection Type==>
Here u find three option
a) Connection-oriented
b) Connectionless
c) HTTP
choose c) HTTP==>
Proxy Address==>100.001.200.099
Proxy Port==> 8080
Again save all the settings and click BACK button and choose "Activate Profile"
Come back to SERVICES==>WAP==>Homepage
and you r ready to use Airtel Live...
2helpful
Internet and MMS settings for ATT carrier with unlocked samsung f-480
AT&T Settings
1) Start>Settings>Data Connections>Menu>Edit Connections
2) Open Dial-Up Connections. Delete all Orange Settings.
3) Open Proxy Connections. Delete all Orange Proxy Settings.
4) Create PROXY CONNECTION:
Description: mMode
Connects from: The Internet
Connects to: WAP network
Proxy (nametongue.gifort): 10.250.250.54:8080
Type: HTTP
Username: (blank)
Password: (blank)
5) Open GPRS Connections. Delete all Orange Settings.
6) Create a new GPRS CONNECTION
Description: ATT GPRS
Connects to: The Internet
Access point: proxy
User name: (blank)
Password: (blank)
Primary DNS: (blank...will later default to 0.0.0.0)
Secondary DNS: (blank...will later default to 0.0.0.0)
IP address: (blank)
7) DATA CONNECTIONS
Internet Connection: ATT GPRS
Work Connection: Automatic
WAP Connection: Automatic
Secure WAP Connection: Automatic
8.) In Internet Explorer, Menu>Options>Connections
Auto Detect Settings: Unchecked
Select Network: Wap Network
9) MMS SETUP.
Inbox>Menu>Options>Account Setup>MMS>Menu>Edit Connections.
Delete any Orange Settings that are there.
10) Menu>Add
Description: ATT MMS
MMSC Address: http://mmsc.mobile.attwireless.net
Data Connection: The Internet
Gateway: WAP 1.0 Gateway
IP Address: 10.250.250.100
Port: 9201
11) Click Done twice to return to the MMS Setup Screen
Server: ATT MMS
Download Messages: Automatically
Outgoing Message Size: Less than 100KB
Allowed Message Types: Personal
Click DONE.
Cingular Settings
WAP
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to [email protected] (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to [email protected]
11.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Select Done or Save
Make sure to activate the profile and you are good.
May 02, 2009 • Cell Phones
4helpful
5answers
Unable to get internet on i9 phone im with fido
Go to Main menu> Services>Data Account>GPRS
Select a profile and select "Edit profile"
Enter the following settings
APN: internet.fido.ca
user: fido
password: fido
Go to Main menu>Services>WAP>Settings>Edit profile
Select a profile and select "edit profile"
Enter in the following settings
Homepage: www.google.com
Data account: GPRS>FidoINT
Connection type: HTTP
user: fido
password: fido
Then to browse, Go to main menu>Services>wap>homepage
You may get an error "Unsupported scripts in content" Just click ok.
1helpful
2answers
Unable to download mms on rocada xphone
get you network setting from your provider if they are wap or http get the proxy address and the server name and create a new profile under gsm and gprs
Jan 21, 2009 • Cell Phones
1helpful
Iphone clone p168
You need to do some setups for the internet.
For AT&T
Watch the YouTube video on internet setup for AT&T WAP
***First Step***
11. Save
***Second Step***
Select WAP
Select back or done
MMS
Select Edit Profile
Select Done or Save
Email will not work with any server that requires smtp authentication (which is pretty much all of them here)
There is no java in the browser. Forget it. There is also no java loader so there is no downloading java games. Copying them to the SD card won't work either. No java loader so the file will be unrecognized.
Wap services like gmail, yahoo email and wap based instant messagers work fine. Make sure you have a good unlimited feature so you do not incur overages from over using your new toy.
For T-mobile:
This is the one that worked for me - I have the $5.99 TMobile Web plan:
Create Data Account
1. Select Menu
2. Select Entertainment
3. Select Services
4. Select Data Account
5. Select GPRS
6. Choose an empty profile
7. Account Name enter T-Mobile WAP
8. Press Options
9. Press Done
10. APN enter wap.voicestream.com
11. Press Options
12. Press Done
13. User Name >Leave Blank<
14. Password >Leave Blank<
15. Auth. Type choose Normal
16. Press Done
17. Press Save
Create Profile
1. Select Menu
3. Select Services
4. Select WAP
5. Select Setting
6. Select Edit Profile
7. Select a profile
8. Choose Edit Profile
9. Rename Profile enter T-Mobile WAP
10. Homepage enter wap.myvoicestream.com
11. Data Account select GPRS
12. Select T-Mobile WAP
13. Connection Type select HTTP
14. Proxy Address enter 216.155.165.050
15. Port enter 8080
16. User Name >Leave Blank<
17. Password >Leave Blank<
18. Press Done
19. When prompted to SAVE please select Yes
20. Select Activate Profile
21. When prompted to Activate Profile please choose Yes
22. Press Done
If you have the $19.99 or higher plan replace the following:
Step 7 under Create Data Account:
Optional - change name from TMobile WAP to TMobile "whatever"
Step 10 under Create Data Account:
use wap.voicestream.com or internet2.voicestream.com or internet3.voicestream.com instead
and
Step 9 under Create Profile:
Step 10 under Create Profile:
change to www.tmobile.com - may not work so try google.com also
SMS, MMS AND VOICEMAIL
1- Click on thee envelope icon it will take you to Messages
CLICK ON SMS
1- Message settings--> click in Profile Setting
2- Click edit on any profile name it T-mobile that will be line No. 1 in No.2 type +12063130004
MMS
1-Message Settings-->click Server Profile
2-Click on any 1--> click on Edit Profile
1- Rename profile
T-mobile MMS
2- Homepage
http://216.155.174.84/servlets/mms
3-Data Account
click on GPRS--> choose Tmobile--> press OK
4- Connection Type
HTTP
5- Username
leave it blank
6 Password
leave it blank
CLICK ON DONE --> SAVE-->ACTIVATE PROFILE
VOICEMAIL:-
Edit it--> name No.1 Viocemail
No.2 +18056377243
NOTE:
Whenever the phone will ask you for a proxy address and port number.
You need that info to be able to get your sevice to work
Here is that info ...
Proxy: 216.155.165.050
port: 8080
1helpful
9answers
Hiphone internet setup
Try this. Depending on the HiPhone though, it may not work or may be different.
  • Select Menu
  • Select Services (Sometimes, Entertainment > Services)
  • Select Data Account
  • Select GPRS
  • Select an empty profile
  • Set the Account Name to T-Zones
  • Press Options
  • Press Done
  • Set APN to wap.voicestream.com
  • Press Options
  • Press Done
  • Leave Username and Password blank
  • Set Auth. Type to Normal
  • Press Done
  • Press Save
Create Profile:
  • Select Menu
  • Select WAP
  • Select Settings
  • Select Edit Profile
  • Select a profile
  • Choose Edit Profile
  • Rename Profile to T-Zones
  • Set Homepage to wap.myvoicestream.com
  • Set Data Account select GPRS
  • Select T-Zones
  • Set Connection Type to HTTP
  • Set Proxy Address to 216.155.165.50
  • Set Port to 8080
  • Leave User Name Blank
  • Leave Password Blank
  • Press Done
  • When prompted to SAVE please select Yes
  • Select Activate Profile
  • When prompted to Activate Profile please choose Yes
  • Press Done
49helpful
20answers
Airtel live settings for china mobile
Im using china Blutooth y690 & have airtel sim but it does'nt accept the settings of airtel live pls tell me how to configure settings mannually the phone has two menus i.e. wap profile & data setting
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
