Question about HP PSC 1610 All-In-One InkJet Printer
Printing quality marks appearing on edge of paper - how do I stop this from happening
    Novelist:
    Scholar:
  • 111 Answers
You don't give a great deal of detail about your problem, but I'll try to offer the most relevant suggestion. HP.com has a web page that describes how to diagnose and solve common print quality problems:
Image Quality Problems
This this web page doesn't help, please post back more details describing the symptoms of your specific issue. Thanks.
Posted on Oct 14, 2008
When printing color the paper jams. This does not happen when printing black. How do I stop it from jamming when printing color.
Is that true for both print and copy job ?
Where does the jam happen ?
I am thinking if it is at the paper pickup roller area just as the job starts to print and not midway while printing, check the paper quality; dirty pickup roller; clean cork pad and try job from another tray
Sep 21, 2016 | Konica Minolta magicolor 1680MF -...
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
ADJUST THE COLOR AND PRINT SPEED You may need to adjust the color and print speed. CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES 1 From the Finder desktop, double-click the Lexmark X5400 Series folder. 2 Double-click the Lexmark X5400 Series Utility icon. 3 From the Maintenance tab, check the ink levels of the cartridges. If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge. Improving print quality These are possible solutions. Try one or more of the following: CHECK PAPER • Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo Paper. Your print cartridges are not compatible with this type of paper. • Use a paper that is a heavier weight or bright white. CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on and "Installing print cartridges" . If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts". If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print cartridges". CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges" If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts"
Nov 10, 2010 | Lexmark X5495 All-in-One &USB...
HP P3005 - skid marks along paper's edge
Print 3 pages. Use the manual feed tray. As they print, open the cover, remove the toner and look down at the paper in the printer. Do you see marks along the edge? If no...replace the fuser. If yes...it could be the transfer roller.
Jan 07, 2010 | HP P3005d Monochrome LaserJet Printer
How topaper load cannon mp 160 pixma
Loading Paper into your Canon MP 160 Pixma.
A) Loading Paper :
Follow this procedure:
1) Open the Paper Support, then pull out the Paper Support Extension.
2) Place a stack of paper (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Set the Paper ThicknessLever to the correct position for the paper.
Note : Set the Lever to the left for most paper. When the Lever is set to the right, the confirmation message appears before the machine starts printing.
Important : Make sure the stack does not exceed the Load Limit Mark.
B) Loading Envelopes
Follow the following steps:
2) Prepare the envelopes for loading.
Important : * Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
* Remove any curling by holding the edges diagonally and bending them gently.
* If the edges of the envelopes are inflated or curled, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
* Ensure that no curl or puff exceeds 1/8 in. (3mm).
3) Place the stack of envelopes (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Load the envelopes in the Auto Sheet Feeder with the short side down.
* Set the Paper Thickness Lever to the right.
Important : Make sure that the stack does not exceed the Load Limit Mark.
Hope this helps. PLease rate my response.
Thanks
Have a good day.
Dec 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
HP LaserJet 1100A unwanted toner marks on face of print
check this link,
either fuser or print drum. to verify , start print job, open door before finnished and see if marks appear before or after fuser. Before paper gets to fuser toner ink will smudge.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl70340#RepImgDef
Feb 15, 2009 | HP LaserJet 1100a Printer
Black ink mark
try this......run a card with heavy matte paper using 'regular settings'.....see if the extra black is gone then
Oct 04, 2008 | Epson Printer
Xerox phaser 7700 having problems printing transparencies and accumulator belt problems
Hi xander4265:
I
Streaks in direction of paper travel
There are dark lines running along
the page in the direction of paper
travel from the leading edge to the
trailing edge (B-size print shown).
The printer displays no error code.
Note A-size prints are processed
through the printer with the short
edge of the print parallel to the
direction of the paper path --
making horizontal print artifacts
parallel to the shot edge of the
print.
B-size prints are processed
through the printer with the long
paper path -- making horizontal
artifacts parallel to the long axis
of the print.
1. Check the end of life for each of
the consumables by printing the
supplies usage page. From the front panel’s Printable Pages Menu, select
Print Supplies Page.
2. Run the solid fill test pages; From the front panel’s Printable Pages Menu,
select Service Pages, then select Print Solid Fill Pages. If the missing bands
only occur in a single primary color, replace the print cartridge of the affected
color.
3. Swap print cartridges and run another test print.
Note Under some circumstances, streaking may occur in the margin of
SRA3-size paper. This is due to the edges of the paper extending
beyond the end of the imaging components. print-quality in the
margins of SRA3 paper is not guaranteed.
4. Inspect the Accumulator Belt cleaner; replace the cleaner, if necessary.
5. Run the Remove Print Smears routine. From the front panel’s Support Menu,
select Improve Print-Quality?, then select Remove Print Smears.
6. Replace the Developer Housing Assembly (RRP 27, on page 7-171).
7. Remove the print cartridge and (with a flashlight) check for debris along the
edge of the developer housing.
3041-42
Leading Edge
hope that this will help you.
Sep 18, 2008 | Xerox Phaser 7700 Laser Printer
Will not print test page or documents
  • Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
  • While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
  • Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
  • Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
  • Press the PAUSE button. The printer begins printing the self test.
  • To stop printing temporarily, press the PAUSE button.
  • To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Jul 04, 2008 | Office Equipment & Supplies
HP PSC 1610 All-In-One InkJet Printer Logo
50 people viewed this question
Seeker5211
Seeker5211
