Question about Samsung 250GB HD250HJ SATA II 300 7200rpm 8MB cache HDD Hard Disk Drive oem HD250HJ 250 GB SATA Hard Drive
SumsungHDD Fails to load OS
After Power fluctuation. 250gb SATA HDD Fails to boot. Not even Consistence check is possible.
  • 101 Answers
Try:
Have you got a decent spinup?
Are the rest of the drives working properly, if they are not it may suggest faulty PSU.
Try connecting to a diffrent pc, or purchase a USB sata convertor
Posted on Aug 13, 2008
When a SATA CD/DVD-ROM Drive is removed, the system fails to boot! Crazy! I just used the drive to re-load the machine but has to remove it. The moment it is removed, the machine fails to boot pas the...
Hi.
Go into the BIOS and set the BIOS configuration to its default settings. Save the changes and exit the BIOS.
When the computer restarts see if it will boot past the Windows logo.
Please let me know what happens.
Good luck.
Jun 09, 2011 | IBM ThinkCentre M50 8187 Desktop PC -...
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
I have a sony VAIO RB53 unit and the original HDD is dying, I replaced it with a 250gb Hitachi HDD and after install the thing won't boot. any help would be appreciated
First need to know more info. what os did you install, did it build from restore disks or windows disks have you any other hdd in unit for example if the old hdd is still in there the pc will have problems. Is it sata or is it IDE or Sata 2
Aug 23, 2010 | Sony VAIO VGC-RB53 PC Desktop
Controller MSI K8N Neo4 does not work
SHUT DOWN COMPUTER AND CLEAR CMOS BY RESETTING JUMPER ON MOTHERBOARD AND THEN RETURN JUMPER TO NORMAL POSITION OR USE RESET BUTTON. UNPLUG ALL HDD SATA CONNECTORS FROM HDD. BOOT COMPUTER TO BIOS. MAKE SURE ENABLE ALL SATA IS ENABLED, PRESS F10 AND EXIT.YOU WANT TO SHUT DOWN AGAIN. NOW REATTACH SATA HDD AND CONNECTORS AND BOOT TO BIOS AGAIN. NOW HIT F10 AND LET COMPUTER RESTART AND LOAD INTO THE OS. LOGON AND CHECK DEVICE MANAGER..SHOULD BE THERE. IF NOT CHECK MOTHER BOARD WEB SITE FOR BIOS UPDATE. IF BIOS UPDATE DOESN'T DO THE TRICK, SHUT DOWN AND DISCONNECT THE IDE DRIVE, UNLESS IT CONTAINS YOUR OS. TRY BOOTING TO BIOS AND CHANGE ORDER OF 1ST BOOT OPTIONS, HIT F10 AND EXIT AND ALLOW COMPUTER TO BOOT TO OS, THEN LOGON, GO TO DEVICE MANAGER AND REMOVE IDE AND RESTART, ONLY IF THIS HDD DOES NOT CONTAIN OS. YOU SHOULD BE FINE AFTER THIS, OR INSTALL YOUR OS ON THE SATA HDD.
Apr 09, 2010 | MSI K8N Neo4 Platinum nForce4 ultra K8...
Can i install xp-sp3 without Sata driver on motherboard 'DG31PR'
You have a board with 4 SATA ports on it and a SATA HDD. The hardware detection routines will see this and load the SATA drivers. Why would you even want to try to set it up without them?
Mar 21, 2009 | Intel DG31PR Motherboard
Wont load
It is on your os problem. Insert your OS installer. You don't have to install a fresh copy but you can repair your previous OS installation. Make sure you have set your boot sequence to CD, floppy and last HDD. You can now reinstall your drivers after doing that.
Dec 21, 2008 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Can I transfer data from 250GB IDE HDD to a SATA II 500GB HDD
Yes you can. You may have to go in BIOS or and select your SATA as the first drive to boot off of though, else it might try to boot off the old IDE. But once you're in windows, it will appear as another drive in my computer.
Thanks and please take a moment to rate as fixya.
Dec 16, 2008 | ASUS A8N-VM Motherboard
The HDD speed suddenly droped
Check the pins connecting the HDD and Motherboard.
Aug 18, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
ASUS K8V-MX Motherboard with 250GB SATA HDD and 250GB IDE HDD Problem
Hi LP,
I’ am very familiar with ASUS motherboards. I am thinking you have posted two questions or more referring to the,
ASUS K8V-MX board. When you sign into you're FixYa account you than need to click on you're profile. Within you're profiles are the questions you have posted. Click that question to add or see the expert's answer. If you need another question (about the same item) re-post within that same question. You can even copy the link to an older post & past that link into you're next question. (Than I can read you're last question & my responce).
LP you have me all mixed up. I'll answer the question you have posted above. In the future please provide you're old post so I understand better.
There is nothing wrong with IDE 250GB drive or the SATA drive.
The problem you are haveing is setting the correct settings.
The ASUS K8V-MX can support two serial ATA SATA drives. The SATA drive's can only run at 1.0 version. 1.5GB transfer speed & not SATA II, the 3.0GB speed.
How to setup the SATA drive?
Please disconnect any other drives (IDE) & a second SATA drive that may be connected to the system. Except the CDROM drive.
Using you're manual the SATA drive should be connected to SATA1 port. Page 1-24 in you're manual.
Put you're windows CD into you're CD-ROM drive & boot the PC. You will see, Press any key to boot from CD... (press any key on your keyboard). Windows will start to install. Durring installation of windows the system will restart. You will again see, Press any key to boot from CD... (DO Nothing)!
Just allow windows to conintue on its own. Windows will continue to install it's self. This will happed once again, & again do nothing. Windows will finish installing it's self.
After windows has finished, load the ASUS CD into you're CD-ROM drive & install it's driver software. Restart the PC.
You must register windows. Do so.
Than update windows through windows update service. (This will take some time to complete). (Do not install service pack 3).
If you have an IDE drive 250GB in size & you installed windows on it. You must erase the drive or it will conflict with you're new installation on the SATA drive. To do this, look on the IDE drive & you will find a large white sticker. Printed on there is instructions of how to set the drive pin. Set the drive up as a slave drive. (This is only temporary).
Power off the PC & unplug the power cord. Connect the 250 IDE drive's power cable & data cable. Plug in the power cord to the PC & turn on the PC. Windows will load. Right click once on the start button & slide up to & left click on Explorer.
Find the 250 IDE drive, it should be drive letter D or E. Right click the proper drive letter & format the drive.
( Do Not format, Local_Drive C:\ ). Once the format is complete, power down the PC by clicking on the start button & click turn off the computer. Once off, unplug the power cord. Change the pin on the 250GB IDE drive to Master with a slave. Take the 40GB drive & change it's pin so the 40GB drive is a slave.
Connect the 250GB drive to the end of the IDE data cable & connect the 40GB drive to the next connector of the same IDE data cable. Re-check all power cables & data cables for good connections before closing the case. Plug the power cord in & power up the PC. Everything should run just fine.
Setting the pin for you're IDE drive's can be very confusing. Click on the link below. This will give you an idea of how to set you're pin for a master drive, master with a slave drive. If you post the name ST****** of you're two drives I can post the correct pin locations from Seagate's web site.
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
Have more questions about this post?
Mike
May 21, 2008 | ASUS K8V-MX Motherboard
Open Questions:
Samsung 250GB HD250HJ SATA II 300 7200rpm 8MB cache HDD Hard Disk Drive oem HD250HJ 250 GB SATA Hard Drive Logo
161 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
