Question about Prime 40 Watt 2 Channel Lead Electric Guitar Amp Car Audio Amplifier
Need a wiring diagram for a 7 string bass. I have 2 pick-ups,5 potts (1 treb, 1 mid, 1 bass,1 vol,1 pick-up strength contol) and 1 pick-up selector switch
  • 66 Answers
Find a wiring schematic for a hofner bass knock off?
It should still be close to a real Hofner bass
a common wiring configuration is
two pickups volume for each pickup, pickup selector switch,
bass on/off switch, and treb on/off switch
there are quite a few schematics available online...
http://www.hofner-guitars.com/information-service/vintage-wiring-schematics.html?___store=guitar_store_en&___from_store=guitar_store_de
Mar 06, 2015 | Bass Music
Rms b80 bass guitar amp has little volume in the low side jack , hi side jack is fine just not as much bass
The low in side jack has a lower vol. but should only be1/4 less than the high in jack on most amps, --try this,-- plug guitar in high in then take all the treble off and 1/2 mid. range bring up bass range and if you have equauzation bring down 26k 5k 10k about 2 notches or points. See if that give you better bass tone.
Oct 10, 2013 | Bass New Rms 40 Watt Bass Guitar Amplifier
Spark plug wiring diagram for 05 tahoe
Greg Bernett 2821 Solutions February 14, 2010
You didn't post your engine size so please pick the applicable diagram:
1996-98 4.3L Engines Firing Order: 1-6-5-4-3-2Distributor Rotation: Clockwise
1996-98 5.0L, 5.7L and 7.4L Engines Firing Order: 1-8-4-3-6-5-7-2Distributor Rotation: Clockwise
4.3L Engines Firing order: 1-6-5-4-3-2 Distributor rotation: Clockwise
4.8L, 5.3L and 6.0L Engines Firing order: 1-8-7-2-6-5-4-3 Distributorless ignition system (one coil on each cylinder)
5.0L, 5.7L and 7.4L Engines Firing order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
Source: spark plug wiring diagram for 98 tahoe
    ledsled378 2926 Solutions July 24, 2010
01f93b7.jpg ..............................
Source: Need diagram for spark plug wiring for 1997 Chevy
Testimonial: "Thank you for your prompt response. Saved my husband from some distress!"
Was this solution helpful? Yes No
    Dennis Weid. 44272 Solutions September 16, 2008
This was all I could come with, hope it helps.
Feb 27, 2013 | 1998 Chevrolet Tahoe
I'm having some crazy feed back with either my amp and i'm not sure what its from or if its my guitar but, every time i go to practice or to play a show i kill peoples ears. Now i play death metal and i...
If the guitar can "hear" the sound, the strings can resonate from the sound and result in feedback. Running at maximum gain is asking for trouble. That causes distortion which drive the speaker as a square wave and worsens the problem. Also back off the treble as you can have supersonic feedback that you can't hear but will heat up your amp.
Test by allowing the feedback and then dampen the strings... if this stops the feedback you need to move the amp away from the guitar. Being a passive pickup makes NO DIFFERENCE about the problem.
Nov 22, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
On top volume & top drive with nothing plugged in it feedback
You should check if the thing does it with a guitar plugged in.
The shorting switch for input connectors that keeps the input grounded are prone to failure.
Mar 06, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Spark plug wiring diagram for 98 tahoe car is missing need to know which wire goes were
Feb 14, 2010 | 1998 Chevrolet Tahoe
How to get the best sound
punk and metal tones (late 80s): treb-7 mid-6-7 bass 6-8, presence 6-10, gain/distortion all the way up. classic rock just turn down the gain/distortion to 6-7. bridge pickup
metal mid 90s & up: treb 6-7, mids 3-5, bass 7-9, gain all the way up, presence (which is a mid and treble boost) 4-6. bridge pickup
blues SRV: treb 6, mid 6, bass 7.5, presence 8, gain 5, reverb (if you got it). use your neck pick up
of course this is subjective and depends on the guitar, cable quality, etc. it looks like a small speaker with a low watt output. that little speaker in there is going to be hard to articulate any tones. more than likely it will have a harsh bit to it cause the value of the pots and the logarythm you hear. reduce treble as needed to smooth out the harsh, keep the mids up.
Nov 02, 2009 | Washburn Amplifiers: 25 WATT Guitar...
I need to know the value pots to buy for vol,bass
If you have the old pots look on the edge of the cans (metal backs) for the code. Take them to a good electronics supplier and they can match them or measure the resistance from each outside pin with all pins free of interconnection. You will also need to know the audio tapers. The supplier should be able to tell from the codes.
Jul 08, 2009 | Music
Prime 40 Watt 2 Channel Lead Electric Guitar Amp Car Audio Amplifier Logo
96 people viewed this question
Top Prime Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Prime Audio Player and Recorder Expert? Answer questions, earn points and help others
