Question about Kogi l5qx-ta ko 15" Flat Panel LCD Monitor
Does not work with new desktop
Hii bought a new desktop, plugged in the monitor and it would not show anything, i turned it off and when I turned it on It showed:
OVERSIZE
Recommand Mode
1080X1024
What will i do?
  • Anonymous Oct 21, 2008
    I have the same problem but don't know how to fix the resolution to
    this size with a dark screen. How do you do that? Reboot?
  • alkaseltz9 Feb 15, 2009
    I have the same problem and there is no way to get the menu to open to change any resolution.
When you start your computer start pressing the key that will allow you to chose boot options like safe mode etc. Depending on your computer it varies which key it may be. Sometimes it may be F8. Mine is F6. When you get to that list there should be an option that says something to the effect of VGA mode towards the bottom. Chose that and it will boot to a small default resolution. From there you are Finally in Windows and then can set a compatible resolution. My max resolution is something like 1280 by 800. I have a KOGI and even though it is a pain in the but at first it works from then on. Good luck
Posted on May 06, 2010
  • 2,794 Answers
All you have to do is change the monitor resolution to that mode. That's probably the maximum resolution you will get with that monitor, video card, and comptuer.
Posted on Aug 13, 2008
Aspire AX1200-U1510A starts but monitor doesn't show anything. Monitor works with an odl Dell.
If an old Dell monitor works with your computer then that monitor has something wrong with it.
Try to plug in the monitor to a wall outlet but do not plug it to your computer. If it still doesn't show anything, then you should replace it. You can contact the manufacturer of the monitor. You might have a warranty for it. They might fix it or replace it with a new one.
I hope this helps.
Carlo
Nov 20, 2012 | Acer Aspire X1200U1510A PC Desktop
I have a hp v75 old desktop computer that I brought from my garage, I got everything plugged up, but the monitor wouldn't show anything.. I googled it and I didn't think it would work but I just...
As your monitor had showed up once before, I assume it is still in a good condition. The next time, you were not able to wake up the monitor by pressing the power button on your CPU cabinet, which means, the power supply to the monitor may have been interrupted. To check whether your monitor is working properly, plug it to any direct connection and see if the power button on the monitor is flashing. If this works, get everything plugged up, check all the connections properly and try to run the computer again.
Hope this helps, Mrityunjay.
Jun 28, 2012 | Computers & Internet
E machine model T3626 turns on display doesnt work and doesnt power off???
Sounds like either the Monitor is bad or the Video Card is bad. Try plugging another monitor on the computer and if it can't show a display then more than likely the Video Card is bad. If it shows on the monitor you just plugged in, then the original monitor is bad.
May 01, 2012 | Computers & Internet
My compaq computer wont turn on for more than a second. It boots and the cpu fan starts but than the monitor doesnt show anything even though its on, the fan turns off and the computer stops booting. I...
1) Is this a laptop or a desktop?
2) What OS are you running?
3) When was the last time that it booted successfully? Did anything change then? Did you upgrade the OS? Did you upgrade the software (firmware) on the processor (Intel or AMD)?
4) Do you see anything on the screen? Compaq logo? Boot options?
Feb 01, 2018 | HP Compaq Presario SR1500NX (PX786AA) PC...
My desktop will turn on but the screen mouse and keyboard dont, i dont know whats wrong.. A while back my old nvidea 9800 burnt, I bought a new 9800 gt, it powers up fine but i still can't get anything to...
have you tried hooking an external monitor? if still it does not have any display, i think its the slot that is having the problem. you also said it was not recognizing kb and mouse, so probably usb port or ps2 port is damaged too. i suggest you have your motherboard replaced. or, first, try updating your chipset driver.
Apr 08, 2010 | Computers & Internet
Connected new computer to acer monitor and it says no signal all cables are plugged in. Tried a second monitor as well
The video-adapter on the new computer may be defective,
since it does not output anything to either monitor.
Take the computer back to where you bought it,
and get them to connect one of their monitors to it,
to prove that it works, or to replace it, or to fix it.
Dec 30, 2009 | Acer Computers & Internet
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
When i turn my pc on it tells me in a blue box no signal but the pc keeps running but i cant see anything i bought a new graphics it still doesn't work i bought a new monitor still doesn't work
The No Signal thing is your monitor saying it doesn't have anything from the PC to display; the PC has nothing to do with that.  Try refitting the card to the PC to make sure it's in there right, and if your PC boots then you should see something (especially if your cables are all plugged in right and your monitor is paying attention to the interface the PC is on, not some other source it could be fed (e.g. SVHS, composite, DVI-D...)
Jul 31, 2008 | Computers & Internet
Kogi l5qx-ta ko 15" Flat Panel LCD Monitor Logo
153 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Computer Links
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
