Question about Gateway Computers & Internet
I sent i a question yesterday .Still I'm unable to
    Guru:
  • 158 Answers
If the screen shows running in lower power as an error. I think your powersupply isn't supplying enough power to the computer, and probably needs to be replaced.
Posted on May 11, 2011
SOURCE:
HELP dell inspiron 531s boots to message cmos "checkum error" and freezes
It is possible that the floppy drive has failed and that it is causing an error as at boot up the cmos is unable to complete the required tests that it performs and brings u the error to alert you to a problem. This is an easy fix but before I continue I will ask you this. Think about when was the last time you used your floppy drive?
If you replied with can't remember or ages ago then it is time you disable your floppy drive as it is now virtually an obsolete piece of hardware and secondly the actual drives are no longer made for internal use anymore the USB counterparts are just as good if not better.
If you answered just the other day then it is most likely that it has failed and that you will still have to follow y fix and purchase a USB external floppy drive.
The Fix :
Ok start up the computer and when you get the chance to enter your cmos screen enter it then find where your floppy drive , hard drive setting are disable your floppy drive, then save your changes and exit let your pc restart and this should solve your problem if you do this and you still have the error occurring then please contact your pc's manufacturer for further technical assistance.
Sep 03, 2012 | Dell Inspiron 531s Desktop Computer
Floppy Diskette Seek Failure Drive 3 Not Found: Parallel ATA, PATA-1
If your computer has the old floppy disk drive on it, then Remove the Power Cord, Remove the Case and then remove the cable from the back of the floppy disk drive. Evidently the drive is bad.
If there is no floppy disk drive on your computer, turn the computer off, restart it and watch the screen for which key it says to hit to get into the System Bios or System Setup and hit that key. You have to hit the key when you see the message or it will not work and you will have to reboot it. Once you get into the bios check your devices and drives for the Floppy drive and set it to None or Not available ( It is probably set on auto or enabled). Also check your Boot Sequence or Boot Order in the bios and remove the Floppy Disk from being in the boot sequence or set it to be after the Hard Drive and CD Drive.
May 31, 2012 | Dell Dimension E310 PC Desktop
Problem with my PC's working
There's any number of reasons why you would experience such problems and also various solutions that might work.
- One of the keys on your PS2 connected keyboard might be stuck and your PC's BIOS assumes you're trying to boot from your floppy drive at the boot up sequence. Check your motherboard's manual for what key that might be and visually inspect it if it's stuck or there's signs of any el. conducting liquids under it or around its base. If such is the case, try rocking the stuck key gently until it gives and returns to its proper position or help it up with a toothpick. You can also use a dull tipped tootpick or soft cotton earbud to clean underneath it, if needed.
- Your PC's BIOS is set so that floppy drive is your first boot device and you forgot to remove non-system floppy disk in it. Remove the disk from the drive and see if your error disappears.
- Your floppy disk drive (FDD) might be corrupt and causing other el. problems on your motherboard, possibly including confusion in the sleep states of your PC. Try disconnecting the power cord off your FDD and see if that helps.
- If you don't really need your floppy disk drive, go to your motherboards BIOS (see manual for how to do that or follow on-screen instructions at boot-up sequence) and either disable your FDD completely, or change the boot-up order so it's not listed before your optical drive and your hard drive. Save changes and reboot.
- Your floppy disk drive might be dead and your motherboard's controller has problems reading from it (regardless if there's disk in it or not). Disconnect power cord and the signal cable from your floppy drive and reboot your PC.
Of course, it could be something else and you'll have to clarify exactly what error codes you get. Still, maybe one of the suggestions above do the trick ;)
Mar 25, 2012 | Logitech Computers & Internet
When a compaq armada m700 laptop is showing non-system disk or disk error replace and strike any key when ready
this usually happens when the computer is trying to boot from a disk that isn't a valid boot disk.
if you have a floppy drive plugged into the multibay and a floppy in the drive, try removing the floppy.
if there is no floppy involved, try to boot from your system recovery disks, as it's likely that the boot record on the hard drive will need repaired. your system recovery disks should walk you through the process.
Nov 03, 2011 | Compaq Armada M700 Notebook
My screen says no bootable device-- insert boot disk and press any key
This sometimes shows up if the floppy drive is set as the first boot device in Bios, and the disk in the floppy drive is not bootable.
Have you attempted to boot to Safe Mode? To enter the Safe Mode menu, continually tap the F8 key just after powering on the computer.
If you're abe to boot to Safe Mode, try choosing the option "Last known good configuration" as the boot option.
If this doesn't work, try Safe Mode (with or without Networking)
We need to know if you can even boot before continuing. If you can't boot then you may need to do a Windows repair. Do you have the OS Disc?
Any doubts you can get in touch with a technician through
www.thebestpcdoctor.com
Toll Free: 877 407 9229
Sep 12, 2011 | Acer Aspire One Netbook
Turn on laptop and VAIO appears as normal but then shows 'operating system not found' - unable to do F8 for starting in safe mode
Sadly, this sounds as if the computer is not seeing the HDD at all. Can you go into the BIOS (either del. key or F2 key on boot up) and see if the HDD is listed? The second screen along normally gives the boot order, and it may show that the HDD is not listed.
Also, check that there are no floppy disks in, or a CD/DVD - as this may cause a problem.
If none of this works, then it may need a replacement hard drive.
Jul 31, 2011 | Computers & Internet
Starting up i get PXE-E61 media test failure some people tell me its the hard drive some say the cddrve others say it could be trying to boot from a LAN
PXe Boot is used by the computer to boot to a network DOS-type environment.If you are receiving a PXe failure message on bootup check that your PC is set to boot from the CD Rom, Floppy, and Hard Drive BEFORE network or other boot device.
That's where you need to check to get solution to your problem, if not... try these
1. your settings in your bios
2. faulty cable/wire to your media device (hard drive, cd/dvd rom, etc)
3. The cmos battery (which indirectly points to your bios settings)
Hope this helps!
Jul 18, 2011 | Toshiba Satellite L455D-S5976 Notebook
My dell dimension 9200 is booting and then giving me a Floppy Diskette Seek Failure message. What is causing this to appear and not boot windows 7?
Hi. You computer seems to be booting up using the floppy disk and your floppy disk drive might not be connected properly, not working or not even there. Press F2 to run the setup utility and disable the floppy seek in the bios. It will most likely be in the "Advanced CMOS setup" area, or the 2nd screen depending on your bios. look for "Seek floppy drive at boot?" or, "Disable floppy seek at boot?" or something like that. When you find it, make sure it's not enabled for the seek. Save the change on exiting. :-)
Jun 05, 2011 | Dell Dimension 9200 PC Desktop
Currently have a samsung floppy drive device manager shows its installed but not showing in computer bios changed to make as default boot device system doesn't recognize it have a PANASONIC product...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to either swap floppy drive or boot up floppy seek both could be disabled press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
hope this helps
May 07, 2011 | Panasonic (JU-256A216P) (JU256) External...
Firmware update interupted, server out
If you have jumpered for BIOS recover it should be able to boot from floppy. I think you will have to install a floppy drive, boot from floppy. Jump the MB for BMC update (if ness) and flash the BIOS and BMC that way.
Jan 16, 2010 | IBM x3400 Server
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
