Question about Apple Mac mini G4 Desktop
Mac Mini G4 Flickering Screen at Start Up
I have a mac mini G4 1.5 Ghz running 10.4.X. Last week the lcd screen started flickering.
The screen starts off fine when we restart. But as soon as it displays the apple logo, the flickering starts. It flickers (vertically) so bad (& wierd colors) that we can't even see well.
We tried to zap the PRAM but didn't work. Neither did restarting from Apple installer disc worked.
Then we changed the DVI connector, didn't work.
Changed to a different lcd monitor, didn't work.
Opened the computer and dust-sprayed, didn't work.
Does anybody have any idea? This mac is only 1.5 years old and is the first lemon we got from Apple. Unfortunately we didn't purchase extended warranty because I have used at least 20 different mac models (including refurbished ones) since early 90's and never had this type of problem.
Thanks for any input.
Emeo
    Problem Solver:
  • 37 Answers
Did you check the wires?  Sometimes if you pull one loose it flickers.
Posted on Aug 18, 2008
    Novelist:
    Champion:
  • 233 Answers
Does this have a graphics card or is it on board graphics? The problem could be there. Also might test with a CRT monitor.
Posted on Dec 22, 2008
How much ramin a 2005 mac mini 1.42 ghz
It came with a max memory of 1Gb. As it is now obsolete, there is no support nor option for upgrading.
Aug 20, 2014 | Apple Mac mini G4 Desktop
Everytime I login to my Mac PowerBook G4 the screen shows logging in and then after about 30 seconds it goes back to login screen
HELLO
FOR SOLVE THIS ..Starting your Mac in safe mode does the following: ... Start or restart your Mac, thenimmediately press and hold the Shift ... If your startup disk is encrypted with FileVault, you might be asked to log in twice: once to unlock the startup disk, ... If the issue comes back, you might have incompatible login items. 1 800 726 0294 Apple Support Number Mac Technical Support Help Apple Customer Support Number 1 800 726 0294 Mac Help USA https://plus.google.com/u/1/116937682228750782866 APPLE SUPPORT NUMBER
Sep 09, 2017 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Why does the screen of my iMac G4 stay black on start up?
Test the system on an external monitor. If OK, replace the screen.
Jun 09, 2012 | Apple iMac G4 20" Mac Desktop
My LCD powerbook G4 has a white vertical line
This is usually symptomatic of a chafed or pinched LVDS cable, especially if the line comes and goes as you work the hinges. This not a user-replaceable part. If the line does not flicker when the hinges are moved, there is a possibility that your LCD screen itself has gone bad.
Nov 24, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook: I've a PB G4 1.25Ghz, since few weeks, when I'm tr...
Try replacing the inverter board. If that don't help then the next step is the back light, but replacing it is a bi.ch, so most people just replace the whole screen. Also, check that the video cable wire is not crimped/cut and securely fastened onto the logic board.
May 17, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My screen flickers and goes out sporadically.
Bad video graphics chip on logic board. Probably made by Nvidia. Repair logic board or replace the logic board.
Feb 17, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
White flash/flicker on Powerbook G4 LCD monitor
There might be an internal device in your computer that is causing this, I have a 4 year old G4 myself, and a defect right hand side light sensor both caused purple stripes on the screen and made it go to sleep mode every time left hand side light sensor was covered.
You could run a hardware test on it: http://www.info.apple.com/support/aht.html
Maybe you could try to deactivate the light sensors in System Preferences?
These are more suggestions than a solution, but maybe you could start there. Good luck, I hope you get it solved!
Mar 23, 2009 | Apple PowerBook G4 Mac Notebook
Mac Mini G4 turns itself ON
Have you looked into System Preferences>energy saver>schedule? Maybe it's set up to start itself. I have my mother's mac set to start up and shut down automatically. Just a thought.
Jan 09, 2009 | Apple Mac mini G4 Desktop
MacBook Screen Problem
Hi there
If I understand you correctly from start up the screen is dim but does brighten up after time? But now after start up you are getting a flicker how ever a restart solves this.
On the dimming issue. Check your energy saving settings and brightness key is working OK.
The flickering is a bit of a concern.
Just a couple of questions.
Are there any dead spots on the screen? Areas where there are no pixels.
When you tilt the screen forward and backward, does this effect the brightness or flickering?
Paul
Sep 03, 2008 | Apple MacBook Mac Notebook
7 month old mac mini freezing & being slow
Generally there are a variety of reasons that can consequently cause the freezing or slow issues on your Mac. Meanwhile, there are certain ways through which you can do to fix one by one. However, if you prefer a more efficient way to resolve, try an all-in-one Mac speed up software as it can help resolve all issues in just a few clicks. Learn more: http://www.howtospeedupmac.com/
Hope this helps!
Jan 20, 2008 | Apple Mac mini G4 Desktop
Apple Mac mini G4 Desktop Logo
327 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
