Question about HP LJ 3020 All-In-One Printer / Scanner / Copier
Whenever I attempt to launch the HP scanning software I get the message, "The function you have requested cannot be performed because another program already has control of the device. If the program currently using the device, save any unsaved work, close the program and try again." Same error :"The function you have requested can?t be performed because another program already has control of the device."
  • eddie8888 Aug 14, 2008
    I did.
    Kinda strange. I have 5 PCs sharing this LJ3055.
    3 of them can work perfectly (I can initiate scan from PC and initiate scan using the "Scan To" button on the printer)
    Another 2 simply wont response to the "Scan To" button but I can initiate scan from the PC.
    I have reloaded the software, ran the scanfix utility and latest software patch to no avail. Formatting the PC will be kinda ridiculous so I will leave that option out
  • 2,785 Answers
Plz try by reloading the software
Posted on Aug 13, 2008
2 Suggested Answers
found new hardware
Posted on Mar 21, 2008
Please insert your originals into the automatic document feeder hp 3052
It is looking for a document to scan. Either a copy job was started and interrupted or the device is not sensing a document in the adf. If scanning, ensure document is flushed and is fully inserted. If not scanning, cancel all jobs. If scanning and document is flush and fully inserted, check sensor/flag which may need replacement if all else is good.
Feb 21, 2015 | HP LaserJet 3052 All-In-One Printer
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
My hp laser jet 3052 cannot scan documents in pdf.It is only giving options to save either in jpeg, tif, bmg format. There is no pdf format.
You may need to purchase a scanner to get a PDF like Acrobat Reader. But if you managed to save to PDF before, try to reinstall the software and add software and choose OCR. Most of the HP PDF capablility is together with its OCR software.
Aug 22, 2010 | LaserJet 3052 All-In-One Printer
Scan error - Can not connect
If you are scanning from your pc and seeing this error message it could mean that your scan drivers are disassociated. If you have multiple multi function printers or scanners that could be causing the problem as it creates a conflict with the software framework. I would recommend uninstalling the software as well as any other multifunction and reinstalling the software as well as the additional product software.
If you are scanning from the printer it may not be set up and you would have to set up scan destinations.
Jul 10, 2010 | HP LaserJet 3052 All-In-One Printer
My HP 3052 won't print color. Prints in black and white fine but no color! Thanks
The LaserJet 3052 is a Black and White only model. It does not PRINT in color. It will SCAN in color.
Jun 21, 2010 | LaserJet 3052 All-In-One Printer
Hp psc 1513 all in one series scan problem
reformat your system so that you can install properly your HP printer, this time the system are being invaded with spywares & viruses...
Jun 18, 2009 | LaserJet 3052 All-In-One Printer
I purchased a HP LaserJet 3050
The instruction to use scanner in HP Laserjet 3050
Click Start, click All Programs or Programs, and then click HP. Click HP LaserJet
3050/3052/3055/3090 all-in-one, and then click Scan.
Click Setup.
Select Change the destinations that show up on the all-in-one control panel when I press
the Scan To button, and click Next.
Select Allow me to scan by pressing the Scan To button on the all-in-one....
Move the destinations from the PC window to the All-in-one window.
Click Update. See the online User Guide for complete information
Source : Manual for HP Laserjet 3050
Thanks for using Fixya
Sep 11, 2008 | HP LaserJet 3050 All-In-One Printer
Scanner Problem
The Laserjet 3050/3052/3055/3390/3392 FULL software version 4.0 (27 Mar 2007) for Windows Vista. Check out HP's download page or click the following for the US & EU version:
This should fix all your problems
Aug 27, 2008 | HP LaserJet 3055 All-In-One Printer
HP LJ 3020 All-In-One Printer / Scanner / Copier Logo
637 people viewed this question
Ben Johnson
