Cant write DVDs with my DVD+RW RW8165 Drive
It doesnot detect any DVD-RW disc. it only detects sony DVD+R disc. but on that too it doesnot write successfully. it gives some error after a while and the disc then becomes useless.
please help
ashraf
  • 1 more comment
  • ashrafjk Aug 13, 2008
    thanx. i will try this and let u know
    regards
    ashraf
    but i have one more observation that is whereas DVD+R is detected and when u start burning, it fails after some time rendering the disc useless. so what can be solution for that. i m using nero 8
    regards
    ashraf
  • Anonymous Apr 25, 2009
    I have USB Sony DVD R+RW drive that install completely but dont read DVD or Write DVD even genuine Sony DVD Disc. can any one know the solution?
    model is Sony DVD R+RW8165 USB Drive
    im using Wni XP 2006 with service pack 2
  • 57 Answers
Your drive may not be compatible with -rw disks. Try using +rw. They are totally different.
also i am having a similar issue with vista with burning dvds. I have to set it on 4x or it fails around 90 % up to 99%. Lower your max burn speed.
Posted on Aug 13, 2008
Hi, My Optiarc DVD RW AD 7530B doesnt read or play DVDS or CDs. it has power but when you click on E drive, an error comes up, that there is no disc
hey gues... we have some problem about my dvd/cd rewritable Drives model AD-7530B . it's my note book HP 520 can detect disk drive , but can not work anything . could you help me and give me information . how i can solution this problem ?... thank's
Jan 26, 2010 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
Dvd drive not detected
Try unistalling the cd drive using your device manager. After removing it from there reboot and see if it is correctly identified and installed by Windows. If not you can manually install the driver or firmware from the drive manufacturers website. Hope this helps.
Jul 26, 2009 | IBM (33P3227) CD-RW/DVD-ROM (Combo) Burner
Wont boot
go to BIOS and enable the secondary drive auto detect.
if you manaully set the drive to primary, secondar. the system should be able to detect it as you have set it. if you select cable select or auto. the sytem will put the drive connected to the end of the IDE cable as primary.
Apr 02, 2009 | Intel Motherboard
Sony DVD+/-RW |DW-Q30A will not record cd or dvd & only play dvds
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD , or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Mar 28, 2009 | Sony DVD+/-RW |DW-Q30A BG w/o SW %...
My lg dvd rom play cd doesnot play dvd
DVD NOT DETECT ONLY DETECT THE VCD
PLEASE GIVE THE SOLUTION
Dec 28, 2008 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Cant read dvd on my sony 18x dual layer dvd writer
go to nero 6.66 and use imation discs, if your os is running ok and you do not suceed whith that i told you, your dvd unit is bad.
Mar 14, 2008 | Sony AW-Q170A-B2 BLACK 18X DOUBLE & DUAL...
Problem in running dvds
are you sure it reads dvd's ? If it does it should have a dvd logo.
If thats not it Laser may not be working correctly and you will probably need to replace disc drive.
nowadays you can find them real cheap and are easy to install.
Feb 24, 2008 | LG GCC-4522B (0048231293594) CD-RW/DVD-ROM...
Sony DVD RW AW-Q170A Burning Problem Plzzz.....Help me out: i have two drives, 1) Sony DVD RW AW-Q170A 1.70 Ver 2) Sony DVD/CD-RW Combo RYK4 Ver My "Sony DVD RW...
Check that the writable DVDs you are using are compatible (+/-) with your Sony DVD-RAM.
Go to Windows Explorer and check to see if the Sony drive is visible. It may not be connected or the Jumper switch may be set incorrectly.
Check you have drivers installed, take a look in Hardware manager.
Sometimes, it's a little difficult to copy CDs and DVDs when you have more than one burning suite installed - for some reason, they 'just don't get along'. Try uninstalling any suites other than Nero.
Or it may just be that your Sony CD-RW drive is just that, and your DVD-RW drive is just that. So it wouldn't be possible to write DVDs on the CD-RW and CDs on the DVD-RW? Though I would assume Nero would detect that and use your hard-drive as temporary storage.
In Nero SmartStart, have you selected the CD or DVD tab to correspond to the project you're burning?
Jan 07, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Computers & Internet Logo
230 people viewed this question
David Payne
David Payne
