Vizio vw42lf hdmi problem
I had a vw42lf, worked great but one day hdmi1 quit working, hdmi2 still worked. vizio replaced my tv for free. I got it today, hooked it all up and cant get any of the hdmi to work. i dont have anything else to check it with beside the jvc dvd player. i am going to get another new hdmi cable tomorrow to see if that is problem, but i been reading about all the hdmi problems vizio is having. what do you think and how do i access factory menu for this model tv. thanks also, i hooked dvd player up with s video it works fine. it is either the tv, the cable, or the dvd player. all three are new. HELP
  • Anonymous Mar 29, 2014
    I have a 60' Vizio LED Smart TV. Everything works fine except since I had a cable box hooked up with the cable company I can no longer access the Smart TV apps. My password won't work and I can't find how or where to change it. Is there any trick to changing the password in settings or getting the current password to work?
The factory menu won't help you diagnose anything. If you are having issues on both HDMI ports, definitely check the cable and that the output works on the DVD player, try this on another TV if possible. If all else fails, call Vizio @ 1-877-MYVIZIO and they will send one of us techs out to replace the main A/V board, that should resolve your problem.
Posted on Aug 21, 2008
Switching from HDMI2 watching computer back to HDMI1 to TV channels I have no picture coming on the TV. Why ?
Look if there is a FIRMWARE update for your model of TV and the SAORVIEW.
Many a times, the TV lock in with the frequency and will not release until the proper reset command arrives.
Try switching to a different resolution on the computer before you switch HDMI port
Aug 16, 2016 | Televison & Video
I am connecting Yamaha DVD player to the Vizio M420 NV via HDMI. i have a picture but no sound. how do I gain audio when using HDMI?
HDMI has both Audio and Video (High Definition Multimedia Interface) and should carry both. However, I had this problem with a client just the other day and it turned out that the firmware on his TV needed to be up[graded. Different model TV, but I believe you may need to download the latest software/firmware update via your PC and put it on a flash drive and then flash the firmware on your TV to get it to work. Sorry I don't have the specifics; I was stumped and the Time-Warner guy ended up doing it. I hope this at least sends you in the right direction.
James
Apr 17, 2011 | Vizio Televison & Video
While watching my new Vizio e470va tv, the audio will go off. I have to change the channel to get the audio back? What is causing this?
gets a little better if you switch from HDMI1 port to HDMI2 port on tv. Vizio says try a new HDMI cord which sounds like baloney
Jan 14, 2011 | Televison & Video
Turn hdmi2 on
hdmi is auto detecting and shouldn't need to be turned on. try plugging your hdmi1 device into the hdmi2 slot. if switching devices around doesn't get hdmi2 working, that jack is likely broken. all the hdmi ports go into the 1 main board inside, and a lot of times you would have to replace that board to fix. if only 1 jack now works, you could also get an hdmi switcher, and then plug all your devices into that, and then just plug the switcher into the working jack. let me know if I you require further assistance.
Sep 09, 2010 | Samsung LE32A457 32 in. LCD TV
No signal on HDMI1. Had to switch to HDMI2
Ur HDMI/1 might be shorted,will not work again.But u can tries unplug,replug the tv an hour later,let it reset it self back to factory setting.Who know might get lucky,it work again.
Apr 24, 2010 | LG 50PC5DC 50 in. Plasma HDTV
No picture when tv powered on
When power on and input set to hdmi1, there is no image appears
Dec 31, 2009 | Toshiba 32AV502R LCD TV
Can't change from HDMI2 back to HDMI1
You need to change via tv selections option for tv, this should be possible by selecting the source for tv feed. This should give various options to select hdmi11, hdmi12, scart1 ect. If remote not working to change look on the tv itself for the control buttons, normally on the back to 1 side (rh from front) then pressing the correct button. If this does not work try turning power off to tv for a couple of minutes and then turning back on. Hope this helps.
Apr 29, 2017 | Vizio Televison & Video
No picture on hdmi2
First of all connect the Direct TV box to HDMI 2 and see if it works there. If it does then the next step is to connect the DVD player to HDMI and see if it wors there. If not then connect the DVD player to the TV using the component inputs and if the DVD player works on those. If it does then maybe the HDMI interface in the DVD player no longer works as it needs to communicate with the TV.
Dec 06, 2007 | Panasonic TH-42PX60U Television
Televison & Video Logo
596 people viewed this question
Top Televison & Video Experts
Electro Med Services...
