Question about Dometic RM2652 Refrigerator
Dometic DM2862 made in 2007
Hi
Works fine on LPG but will not switch to AC. When I parked in the yard here at home and plugged in it was fine. Went out a few days later and the beer was hot... no AC light on = problem. Checked AC outlets and they are fine. Check breakers all ok. Checked little glass fuses; 3.5amp and 5 amp, they look ok too.
Now what?
Thanks Brad
Heating element is out. They are usually about $40.00 give or take.
Posted on Aug 30, 2008
I have duo therm rooftop Ac unit, was working fine and just went out. Seems like it is not getting power, I checked breaker and fuses. Still not working. What do i do next ?
First of all are you plugged in at a rv park or home? Had ours do that as well, found the electrical source in rv park was defective. Caused our AC unit to cut in and out then wouldn't run at all. Moved to a new location and the ac was fine.
Jul 24, 2014 | Dometic Rooftop RV Air Conditioner
2007 dometic Rooftop AC "high-lo" switch. What does it do?
YES WITH OUT A DOUBT .. DO NOT TRY TO RUN IT ON HIGH IT MAY DAMAGE YOUR GEN SET ... HELP ? PLEASE VOT
May 28, 2010 | Dometic Rooftop RV Air Conditioner
AC compressor will not engage
It could be the capacitor, it could be a loose wire connection, it could be a delay switch or a contactor/relay.
Mar 30, 2010 | Dometic Rooftop RV Air Conditioner
Hi i have an lpg ldv convoy have just put new spark plugs and filter and oil in. runs fine but seems the cough some times on lpg in second gear??????
lpg doesent have as much octane as gas/petrol, and so will stall and hiccup more at lower revs, most people with lpg conversions run their car on gas when around town and switch to lpg when in on the highway. have you replaced the air filter as well?
Mar 09, 2010 | Ford LTD Cars & Trucks
Inop on ac electric
There should be fuses/breakers in the converter box. It sounds like the DC circuit is ok but the AC portion is still out. Eric
Jun 20, 2009 | Dometic Refrigerators
A/C not working. Clutch not turning
jumper the ac compressor cycling switch in the low side line or accumulator and see if system works. They stick and cause this problem.
May 22, 2009 | 1998 Chevrolet Tahoe
My fredge rm 2652 not working
You need to check your fuses on the fuse panel inside your coach. The frig will not operate on gas or electric without 12 volt power to the frig circuit board.
Feb 03, 2009 | Dometic RM2652 Refrigerator
Dometic ac/heat pump
Would suggest it is drawing excessive current, make sure both fans are going, (inside will cycle low/high), or possible faulty reversing valve solenoid, or could be as simple as loose wire connection, how long does it run for and is it on the same 20amp breaker as the rear?if so start by running only the front unit in cooling 15/20min, check fans running, no unusual bearing noises, switch off for 60 sec then back on heat mode, if unit runs without stopping rewire onto separate circuit, if inside fan not working on heat check bi-metal switch in the airway, if running for a while, fans going but not very warm, check reversing valve.
Note, electrical's should be tested by someone who are qualified in the field.
Nov 05, 2008 | Dometic Rooftop RV Air Conditioner
Duo-therm by dometic ac rv unit
I suspect that you have a bad selector switch for the on, off, low fan, high fan operation. If the selector switch is put into the off position everything should stop completely.
Apr 30, 2008 | Dometic Rooftop RV Air Conditioner
Dometic RM2652 Refrigerator Logo
213 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
