Question about Refrigerators
New GE profile refrigerator bottom freezer model pfss6pkwass. Will not run, stuck in display mode. Lights are on but when setting temp on panel it goes back to off after a few seconds. After spending 2000.00 at best buy they cannot send a tech out for three days to unlock the display mode. (of course they took my old fridge that was working fine) Any help would be great.
  • jacquiboo22 Aug 14, 2008
    I have the same problem! The fridge display has been showing "OFf" for 24 hours now and IT IS NOT GETTING COLDER! So frustrating! What to do? The instructions say NOTHING about this!
Ok, I had the same problem with this fridge. It is in "demo" mode. You have to push in and hold the Energy Save and Adjust Freezer buttons at the same time. Hold these in until the display starts flashing. You should hear the compressor kick on. I did this, and it was fixed and started cooling in a matter of seconds.
Posted on Aug 31, 2008
  • Jazzyjezzy Sep 09, 2011
    Thanks. I used it on my Sansung ref - hold down the energy save and the alam botton for 10 sec.
    and it worked.
The turbo freeze and turbo cool readings on the door read at 88 and allow water to be dispenced but no other external function
Posted on Jun 11, 2010
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
Refrigerator and Freezer lights do not work and all display lights are not working either, but fridge and freezer are working.
Hi i'm sean I work for GE as an employee, this is a bad control board located in the rear of the refrigerator behind an access panel, you will want to change this as soon as possible it will possibly cause damaged to your sealed system on this model if prolonged in that condition. The board usually runs between 175.-200.
Sean
Mar 26, 2011 | GE Profile Stainless Bottom-Freezer...
My GE Profile bottom freezer and frig's temps are also up..help
has a FF error shown up on your display. If so that is your freezer fan, and if not it still might be the FF motor is running to slow.
Jul 20, 2009 | GE Profile Stainless Bottom-Freezer...
Cannot get the fridge to start cooling
If the panel temperature reads 0 F 0 F it is in the "DEMO" mode. This is normal if you purchase a floor model. To bring it back to normal mode press ENERGY SAVER & ADJUST FREEZER together for 3 to 5 seconds until it beeps. Then unplug the referidgerator for at least 30 seconds. Then plug it bck in. That will reset the stupid computer and get it back to normal operation.
Did you think this was helpful? Yes No
Feb 08, 2009 | General Electric GFSS6KKXSS Stainless...
Ge refrig
I have a ge profile side by side. when it auto defrosts the water runs to the bottom and out the freezer door instead of down the drian??
May 31, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerators Logo
768 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
