Vocopro Gig Man Karoake Not working properly
My daughter was singing on this machine and my son walked by and switched the external speakers to internal then back again and every since that happened nothing on the front side of the machine works. It lights up when you flip the switch on the back but the power button on the front does not work nor does any other button. We cannot eject the cdg or anything, Please help!
Susan
  • susu1 Aug 19, 2008
    That did not work, but thanks for trying, we could not find the factory reset. But did find a blown fuse inside so we are contacting Vocopro for help
    Thank You,
    Susan Prestwood
  • 4,889 Answers
Hello! Did the live session get disconnected? It is possible that he has also toggled the voltage selector that may have roasted the mainboard however you can try the factory reset to see if it works..
http://www.vocopro.com/PDF%20Manuals/GIG%20MAN%20MANUAL%20eng.pdf
Posted on Aug 13, 2008
Ar all chips compatible with karoake systems
no
there are various issues , model of the system the make ( magic sing will fit magic sing ONLY )
if laungage font is different example hindi etc then also it will not work
chips made for very old models may not work on new systems
example ed series chips may not work on KV and KH series
for more please email me on mumbai11@gmail.com
Jan 07, 2015 | LeadSinger Audio Players & Recorders
The built in speakers on my gogear 8gb mp4 player is not working. i've been using it for almost 2 years now :(
My ENT doctor said no more ear buds, no more ear phone so I Amazon purchase another GOGEAR Ariaz because they have an external speaker, or so I thought.
I tried all to get the speaker ARIAZ 16 gig to work. Nothing. Speaker does not work. The instruction manual that comes right on my 16 gig GoGear Ariaz is for titled GoGear AZURE!
AZURE! Where did that come from? The Azure manual does not show a speaker. Go figure. I do not think my Ariaz-Azure has a speaker. It does have Bluetooth that works for me OK with a Philips external Blue Tooth Speaker. No ENT correct external speaker on the player itself? Or am I wrong.
The tiny, tiny micro writing label on my "GOGEAR Ariaz" is a label for "SA5AZU16KF/37. Even though the Logo on the case of the GoGear is imprinted ARIAZ!
If I am wrong and my Philips Azure???-Ariaz has a speaker I would be pleased to know how to make the speaker work.
PS, I do own a GoGear ARIAZ 8G, and it does have a speaker that works for me.
Nov 03, 2013 | Philips GoGear Ariaz MP3 Player
How do I connect a droid to my voco pro gig man?
You need at least one adapter. Buy a 3.5mm male headphone to STEREO RCA adapter. Make sure to buy one with 2 channels (red and white) for stereo.
Plug a digital/analog 3.5mm male headphone jack adapter into the droid. Plug the RCA (red and white) into the mixer. Good luck!
Jun 06, 2011 | Vocopro Kj7000pro 19" 6 Channel Karaoke...
I get little sound out of the microphone spots onm my DA-X10Pro. I have a karaoke THE SINGING MACHINE. When I use my karaokee machine mic plug in the mic works fine...but any voice into the mic...
The mics on the singing machine are very low end mics and MAY not work on your other unit. The Voco has very sensitvie inputs to use with "professional" type microphones. The Singing machine mics are going to be fairly high output and likely to overload the voco inputs. Procure some professional mics like Shure, AKG, Sennheiser or others and don't forget to use a balanced to unbalanced adapter or cable on the mics.
Jan 06, 2011 | Vocopro DaX10pro
Long delay between singing into mic and hearing voice in speakers
Usually delay is associated with "reverb" not echo. If you are in a large room, the room acoustics can add reverb without the benefit of signal processing.
Reverb NORMALLY passes the inout signal as is and then adds in a delayed version on top.
The delay should be less than the room size delay.
Try turning off all effects as a start. There is some "transport" time if it goes through a digital signal processing.
Apr 30, 2010 | Vocopro Da1000pro Professional Digital...
My speakers don't work, I can plug in head phones or external speakers and they do work. it started after my son repeatedly pluged and unpluged the external speakers
There is a microswitch in the speaker jack of the system. It disables the on-board speakers when external speakers are connected. If sounds like that switch is stuck and the on-board speakers are staying disabled when the jack is removed.
Jan 30, 2010 | Dell Inspiron E1505 Notebook
2-second delay with Magic Sing
i bought et18k. just the same as yours.its 2 days old and has the same problem. the technical assistant says that its because of the digital setting that new tvs have. there are two ways to solve this though:
1. connect the video (yellow plug) to the tv. and the other two plugs (yellow and white) to the stereo. when i say stereo, its not the dvd home theater system that you have but a separate one. if you connect it to the home theater that you have, it'll just sound the same, you still have the delay.
2. connect the magic sing to the older tvs hangin out. and you'll get no problem at all.
**TVs such as sony, samsung, philips, sharp and all plasma tvs including other newly designed tvs will have the delay since they all share the HDMI thingy that causes sh*t.
Aug 20, 2009 | Magic Sing Along Consumer Microphone
Display not lighting
Hi last1975
You will find that the display has a lamp behind it that backlights the LCD display. Changing out the lamp is usually simple enough if you are handy with screw drivers and a soldering iron. Most generally are 12 volt, meter it first if you have a multimeter, You can buy lamps to suit from Farnell electronics in most countries of the world. If you have any trouble matching types to order one, I can help you there. Happy to answer any questions you may have about your job. Good luck, and thanks for using FixYa.
regards robotek
Jan 24, 2009 | Audio Players & Recorders
No Disc Error
there is no fix you bought someone else's junk
May 08, 2017 | The Singing Machine DVD/CDG Karaoke System...
Vocopro Gig Man won't play
we're having probles.we have avhf-4800 from voco pro,lights come on the box and on mikes no sound on teo mikes
Jan 09, 2008 | Audio Players & Recorders
375 people viewed this question
 Grubhead
Grubhead
