Question about Fujitsu fi-5750C Flatbed Scanner
Green layer on scanned image from ADF Simplex
The output is green, what ever is scanned through ADF Simplex, using RGB color settings.It seems it has some layer on it. As even if a white page is scanned it appears a uniform green. No lines or distortion in image ouput.
my email add is iansar@lmkr.com
  • 490 Answers
What model of scanner are you using? Is it white light based or RGB LEDs (Light Emitting Diodes). Very rarely it may happen that the Red and Blue LEDs are not glowing may be because of loose contact, but this very rare occurence. Try reloading driver software.
S. Mohan
Posted on Nov 19, 2008
Perblem lg37lb1r has a color very often the color of green blindon
You can adjust the green temperature at the color RGB adjustment.press the menu button then choose the video adjust then scroll down to RGB setting RGB stands for RED,GREEN AND BLUE..adjust it according to your preference..
Apr 06, 2012 | LG 37LB1R 37 in. HD-Ready LCD Television
Its glittery white because i briten the color but when darken it gets green
you must re-adjust in the RGB (Red-Green-Blue) setting. depending on the brand of your TV, because there are set manually from the TV (you must open the cover of the rear of the TV). and there is a set directly from the remote only, with the open "factory settings", then you can re-adjust RGB color, especially green, not too dominant with the other colors (RED-BLUE). how to set is that you need to neutralize the color, (color TV sets to zero level) so that the image becomes black and white. if the green is too dominant, then Decrease the level of Green Bias or Green Cut off/ G-drive.
Aug 05, 2010 | Televison & Video
Panasonic SC-HT730 Green picture when showing DVD's
The DVD player of this system will output to a TV on either composite (Yellow jack), component (RGB jacks) and S-Video (a small round jack that looks like a mouse or keyboard connector) jack. Since the tint is off, I would guess that you're using the more desirable component or even the S-video jack. Try removing & re-seating the plugs into the jacks at the DVD and at the TV; then check the picture color. If it still is wrong, try using a different cable type - use a standard video cable between the yellow jacks on both the TV and DVD. You may need to set the TV input to reflect the use of the new jack - and possibly set the DVD to 480i or Interlaced if you used the Progressive Scan or 480P output when using component RGB video cables (Red, Green & Blue). Check for correct color.
Chances are the connection got dirty and caused the color issue - or less likely, the cable or even less likely - the DVD output has failed.
Mar 26, 2010 | Panasonic SC-HT730 System
How to scan picture to upload on computer
First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
  • Color Document(Simplex): Select this to scan one side of color documents.
  • Color Document(Duplex): Select this to scan both sides of color documents.
  • B/W Document(Simplex): Select this to scan one side of monochrome documents.
  • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
  • Text(Simplex): Select this to scan one side of text documents.
  • Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required. Click here for detailed information
6. After making the setting changes, click 'Scan'
7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
The directions for Batch Scanning, or using the ADF to scan, are shown below.
  1. Place the document(s) in the Automatic Document Feeder (ADF).
    1. To scan using the ADF, remove any documents from the platen glass.
    2. Open the document tray.
    3. Insert the documents face-up in the ADF and then adjust the document guides.
      Note:
      When scanning using the ADF, the documents will automatically feed.
  2. On the Windows desktop, double-click 'MP Navigator 2.2'.
    1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
    2. Then click 'MP Navigator 2.2'. MP Navigator opens.
  3. Click 'Batch Scanning'.
    * Color Document(Simplex): Select this to scan one side of color documents.
    * Color Document(Duplex): Select this to scan both sides of color documents.
    * B/W Document(Simplex): Select this to scan one side of monochrome documents.
    * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    * Text(Simplex): Select this to scan one side of text documents.
    * Text(Duplex): Select this to scan both sides of text documents.
  5. Click 'Specify' and set the preferences as required. Click here for detailed information.
  6. After making the setting changes, click 'Scan'.
    1. After the documents are scanned, a dialog box will appear indicating to load the next document.
    2. After the next document is loaded, click 'Scan'.
    3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
  7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
  8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
    Save to PC dialog box
    Save as PDF file dialog box
  9. Make settings to save a file. (Click File save settings for details.)
  10. Click 'Save' after all settings have been selected.
Aug 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I have a GBV441 DVD/VCR player which is shaky and plays the DVD in an overall green color which distorts the image. I have tried to adjust the color, but this doesn't work. I've tried it on 3 DVD's and...
I think the DVD player might either be set to output RGB, or if you are watching it via a scart to TV, and the TV is not RGB type. Alternative the TV is an RGB type and your player needs switching to RGB output.
Jun 20, 2009 | Televison & Video
Green shade color on screen over tyhe program that is been broadcast
its a loose connections to you color amplifier RGB. cold solder in that board section.
May 30, 2009 | Samsung HL-R6167W 61" HDTV
Problem with RGB color...registering as green and image distorted
did u fix your tv cuz thats the same thing thats happening to me
Apr 15, 2009 | Philips 60PP9202 60" Rear Projection...
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
DR-9080C BackgrounfColour Dropping Out
Color scanning is a big technology. There are concepts like Hue and intensity, refer to wikipedia for explanation. There is something called source light (your monitor for example) and reflected light (your picture that is being scanned). After scanning properly, say you view on a monitor where the Brightness & Contrast are not proper, you will see the image poorly! To test the scanning scan absolute white and check the output. It should read the values 255,255,255 for RGB (Red, Green & Blue). If the values are 255,255,255 but still the image does not appear white on the monitor, it is monitor setting that is wrong. If the output is not 255,255,255 then CANON service personnel only can help. Any good imaging software will display the RGB values.
CANON uses LED light source and they have fairly long life as compare to scanner bulbs. It is okay if you use a powerful system, but it has limited role as the scanner does all the jobs and it only sends the data to the Comp. May further processing is better withe high performance CPU and large RAM.
Aug 05, 2008 | Canon DR-9080C Path-Through Scanner
Color image imported is way off
TIP : always set image on RGB, printer drivers or programmed to convert RGB to CMYK then sending it to the printer. printers understand CMYK only.
Jan 17, 2008 | Epson Stylus Photo R1800 InkJet Printer
Fujitsu fi-5750C Flatbed Scanner Logo
277 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
