Question about Asrock P4I45GV R5 Motherboard
System error Repected once i am using the dell orignal system but a few days i am receiving, whenever i start my computer, the message of " the amount of system memory has chaged" what is this problem and how i can solve it. kindly give me a needfull suggesion. Thanks Shani
DRIVERS
Posted on Aug 28, 2008
First i got a error message as "memory unsupported please update dimm1".After that i moved the ram to slot 1 after i restarted another error message showing"battery voltage is low ".what is the exact...
these can be related as the main battery on the motherboard is need to retain cmos setting when a system is unplugged from a/c power for extended periods of time.
so the loss of cmos would prompt you about certain components including amount of memory(pending no changes in memory amount/ slot location as a single chip unit must have the mem in slot 1). there is a round 3.0 volt battery that once reports bad, should be replaced. start there and see if you get any other errors. as there could be a problem with the powersupply or motherboard if that doesn't resolve it.
Jul 08, 2014 | Dell Optiplex 755 Desktop Desktop Computer...
I keep getting messages that tell me I have many errors on my computer. One company with whom I accidentally thought was you told me it was going to cost X amount to fix. Norton which is on my computer...
If your computers running OK ignore them they are after your money.If you are running Microsoft Windows do the routine maintenance once a week.Use file checker and the defrag tool
and the delete browsing history tool, also find the add and remove programs tool and remove games and programs you don`t use.But be careful and make sure you don`t remove system files.You will probably still get error messages but ignore them or do a reinstall of Windows and start afresh with a clean system.I don`t like Norton and use the free Microsoft Security Essentials program and have never had a problem.
Oct 24, 2013 | Dell Computers & Internet
I have a dell optiplex 780 desktop computer that refuses to start. error message says that a hardware/software problem is preventing the system from starting. how can I solve this problem? how do I...
If the HDD is OK . Perhaps this will help: http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&cs=19&l=en&s=dhs&docid=DSN_362029&isLegacy=true
Dec 23, 2012 | Dell OptiPlex 780 MT Desktop Computer...
I get a blue screen error message ''c000021a unknown hard error'' after running CHKDSK as a result of receiving an initial blue screen error message ''The Type of file system is NTFS. The volume is...
Hi, Boot into Safe Mode by pressing F8 at bootup and choose
'Safe mode with command prompt'
At the command prompt type
C:\Windows\system32\restore\rstrui.exe
Hopefully System Restore will open so choose a Restore Point a few days ago.
Please rate my response!! Thanks, SF
Jan 28, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Blue screen when I close the top of my laptop or shut it off
this error relates to video drivers. to fix this. restart your computer and as soon as you see dell keep tapping the F8 key in the top row to get advanced boot options. and then select "Enable VGA Mode" and press enter 2 times. then the computer should start and then do a system restore. to do system restore.
There are two ways to perform a System Restore in Microsoft Windows. The choice only depends on if the computer is currently able to boot into Windows or not. If the computer is able to get to the desktop (with the clickable start
in the lower left corner), then choose Method 1. If the system is unable to boot to the desktop or otherwise is unable to complete a system restoration using the selection above, then choose Method 2.
Method 1 Able to Access the Desktop.
1 start .
then click Help and Support
2 Under Pick a Task
, click Undo changes to your computer with System Restore
3 Select Restore my computer to an earlier time
, then click Next >
4 Under, 1. On this calendar, click a bold date, select a date before problems were observed with the computer.
Dates in bold indicate a restore point is available for that date.
5 Under, 2. On this list, click a restore point, click to choose a restore time from the list.
6 Click Next >
7 Verify that the desired restore point is listed, then click Next >
8 After the computer restarts, the Restoration Complete page of the System Restore window appears. Click OK
If the problem still occurs, try restoring the computer to an earlier restore point.
Method 2 Unable to Access the Desktop.
1 Turn off the computer.
2 Turn on the computer and press the F8 key every other second until the Windows Advanced Options window appears.
3 Press the <Down Arrow> key on the keyboard and select Safe Mode with Command Prompt.
4 Press the <Enter> key on the keyboard.
5 Log in as the administrator or as a user with administrator rights.
6 At the command prompt (blinking cursor), type:
and then press the <Enter> key.
If Windows XP has been reinstalled to a different location on this computer, change C:\Windows to the new path.
If this doesnot work...then we need to reset the computer back to factory settings.
Notice:
Restoring the original factory image erases ALL existing data. This includes files, folders, programs, drivers, E-mails, photos. Before performing a PC Restore, back up all personal files. If you do not back up your personal files, the data will be lost.
1 Turn on the computer.
2 When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
NOTE: Some systems like Inspiron Mini 9 (910) do not support System Restore as they do not have <F11> nor any substitute.
3 In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>.
4 When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear:
The system recovery process was successful.
5 Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
The software is now installed as it was when the computer was first received.
Oct 13, 2009 | Dell Inspiron 6400 Notebook
Inspiron 1520 error code 0f00:137B or dvdrw_4
this is either a faulty dvd drive error message, or you have missing system files on the hard-drive.
The computer is asking you for the ( Media-Software Disk ) that is missing, and is required to start the computer.
Try putting your restore cd, or operating system in the dvd drive when booting the computer.
Mike @ Compurepair.
Jun 15, 2009 | Dell Inspiron 1150 Notebook
Unable to Calibrate: Dell E153FPT
CHECK THE DRIVERS OF THE MONITOR, TRY TO UPDATE THE DRIVES
RESETING THE REFRESH RATE LOWER THAN IT IS NOW
IS THE RESET BUTTON THAT WILL SET THE MONITOR BACK THE THE MANUFACTURE ORIGNAL SETTING,
THAT MITE AN OPTION ON THE COMPUTER ITSELF, SHORTING OUT THE BOIS ON THE MOTHERBOARD BUT WHEN YOU DO THAT YOU CLEAR EVERYTHING ELSE LIKE HD,KB,MOUSE, CDROD,DVD,FLOPPIES, MONITOR SETTING,
ROD
Feb 12, 2009 | Dell E153FPT 15" Flat Panel LCD Monitor
Error message whenever I reboot my computer
this problem is regarding windows file.
check this website..and download the dll...
http://www.dll-files.com/
Jan 04, 2009 | Computers & Internet
Asrock P4I45GV R5 Motherboard Logo
27 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
