Question about Sony NW-E003F MP3 Player
Will not charge
All of a sudden it just said low battery and it will not charge when I plug it in to my USB drive. What can I do?
  • 55 Answers
Your mp3 battery my be dead or there is a electrical probelm with the usb cord. if thats not the case try to use an update firmware and if all else fails do a factory rebut at the mp3 players web sit of the manufacture company.
Posted on Aug 13, 2008
My garmin gps battery is low and will not charge.
have you tried charging it by plugging in with the interface. able to a compter usb port? Or if this is the method you have tried, try plugging it in to your car power source. If it still won't charge the internal battery may need to be replaced.
Sep 09, 2014 | Garmin GPS
Bought the PDV-709 a few years ago and never really used it. Took it on a trip and found that it would not work when plugged into the outlet in the van while the van was running. If you turn off the van...
That's an odd one for sure, but it might be some safety feature so DRIVERS won't use it while driving.
The cheap solution is a 7812 votage regulator - but since the safety circuit is likely in the cigarette plug itself, it's not easy to put the regulator between the source voltage and the circuit input.
So, here's the not-so-technical solution.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6421307&CatId=237
It's a 100W power inverter with USB
For under $20, it turns your cigarette lighter plug into a 120V AC outlet plus has a USB 5V port for things like MP3 players etc that charge off the USB port in the PC.
So basically you just plug in the home adapter into the 120V outlet, and you can watch and charge while driving. Not only that, it'll be good for other low power devices later on, not just this one (like laptop/notebooks blackberry/cellphones, any low power plug in device).
For the price, it's a perfect solution, and you can order online and have it delivered!
Mar 18, 2011 | Durabrand PDV-709
I was charging my tomtom on the computer. Suddenly my computer made the noise it makes when a device is detached. So I unhooked it and tried to turn it on, and it wont. The screen is active when I plug it...
Wait for the battery to fully recharge, The battery was ln a low state, are you sure you were using the correct USB cord. Some look very similar but one of the inner cables is disconnected and so does not charge the unit.
If you still get no luck after using correct cable then it may be time to change the battery as it has collapsed. batteries last up to 2 years and can go very quickly. Never plug it into car power whenhj starting engine. It shortens battery life and damages siirf chip
Please rate my help++++Thanks for using FIXYA
Jun 22, 2010 | Tomtom XL 330S GPS Receiver
Toshiba External HD battery running low?
They can only charge thru the USB port when your computer is on.There is no voltage supplied when it is off.This help?
Jan 17, 2010 | Computers & Internet
All of a sudden it will not turn on....nothing...when plugged into the usb...it say fully charged....but if you disconnect..and try to turn it on.....nothing happens..
If you can turn your player on while being plugged to your PC/Laptop or USB charger, then your internal Lion battery is most likely gone past its useful life (some 500 charges or 18 months usage) and may need replacing. Most MP3 player may show 'fully charged' when plugged in either when the battery is truly fully charge or defective battery is no longer taking a charge: e.g. minimum or no current flow situation.
Dec 20, 2009 | RCA M4204 MP3 Player
Sansa clip sandisk 2gb won't charge. Thought it was low and after plugging it in to computer overnight it wasn't fully charged but worked the next morning but suddenly died. Now it won't charge. Sansa...
I had the same problem this morning, albeit with my 8G Clip. Nothing worked -- the thing seemed dead as roadkill -- until I found a link about "forcing MSC mode." Basically, it told me to hold down the center button while plugging my Clip into my computer using my USB cable. Suddenly, boom! It's awake and alive and happy again. I'm unsure how that works, but that did it for me.
Nov 03, 2009 | SanDisk Sansa Clip MP3 Player
My sony walkman nwz-e436f was working fine and all the sudden its taking no charge from any usb ports
Check the connector of the USB Ports and Sony. Also it's internal battery require replacement.
Jul 06, 2009 | Sony NWZ-E436F MP3 Player
Garmin c530 Streetpilot
I just called tech support at 1-800-800-1020 and I was told that the battery on the unit may be so low that it won't power on even with a power source. The unit actually uses more power than it's taking in from the car charger. I was told to plug it into the computer using the USB cable and give it a few hours to replenish the battery. Apparently it should be plugged into the computer ever so often to keep the battery from getting too low.
May 09, 2008 | Garmin StreetPilot c530 GPS Receiver
SAMAUNG-YP-Z5,LOW-BATTERY
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
Feb 10, 2008 | Samsung YP-Z5 MP3 Player
Charging Battery
did u try to charge it connected to your pc? maybe its the charger
Feb 04, 2008 | Motorola Mobility Moto Q
Sony NW-E003F MP3 Player Logo
133 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
