I can't play the games on my psp that saved on the memory stick.
I can't play my psp games that saved on my the memory stick with the game format cso...please help me why and how to troubleshoot step by step.....i wanna play games on my psp....please help me.........e-mail me at fushigi681@yahoo.com thank you so much....
You got to put the downloaded cso file format into a folder in the psp called iso
or jus check out on youtube
Posted on Nov 22, 2008
Psp go i have an error code 8010850f it says i
If you are getting this error when trying to play games from memory stick i might have the solution for you.
1) Back up your data on memory stick to PC using usb cable.
2) Format your memory stick from PSP.
3) Copy game from your PS3 to your PSP using usb cable.
4) Copy game saves etc. from your PC back to your PSP.
5) Play your games on PSP.
Mar 21, 2010 | Sony PlayStation Portable (PSP) Console
I upgraded my psp 2006 from 5.00 m33-6 to version 5.50. Now it does not detect the games saved in my memory stick. What should i do?
Are you trying to play the game from the memory stick? Or are you trying to play a game from the UMD and retrieve the saved game data from the memory stick?
5.00 m33 is a custom firmware that allows the PSP to play games stored on a memory stick. If you upgrade to 5.50, which is an original Sony firmware, that functionality will go away. If you have custom firmware, you should never upgrade it or the features like playing homebrew or loading games from a memory stick will go away.
Oct 09, 2009 | Sony PlayStation Portable (PSP) Console
PSP only reads first 7 game saved
in psp get virus plz format ur psp than recover u psp than solve r problam thank u
Jun 03, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Memory stick does not work
Connect the memory stick to your PC and format there. If it still fails, it's highly likely that your memory stick needs replacement
May 17, 2009 | Sony PlayStation Portable (PSP) Slim...
Cannot get games to play-where is the "OASS Button"?
Try this:
1) You must first backup ur data on your memory stick to your PC. Mainly the saved games data. ( directory is PSP\SAVEDATA) 2) Format the memory stick using the PSP format tool in system settings...not your PC. 3) In System Setting UNCHECK or UNSELECT "UMD Cache" this must be off!!!! 4) Connect your psp via USB cable 5) Copy your game saves / data back to your psp remember >> PSP\SAVEDATA . 6) Do a hard reboot of your psp ie hold the power switch for 3 seconds and it will reboot. 7) Your UMD games should now work with no probs.
This is not my solution, just a solution found on a messge board from others having the same problem
Apr 23, 2009 | Sony PlayStation Portable (PSP) Console
Hey i have prob in iso games
STEP 1: CONNECT YOUR PSP TO PC
The PSP can function as a USB Memory Stick Duo reader. Using this functionality, you can copy pictures, audio, and other content to and from your Memory Stick Duo. To access the Memory Stick Duo in your PSP from your PC, you'll need a USB cable that has a "Mini-B" connector (common for digital cameras) and a "Standard-A" connector (common for printers, etc). Plug the Mini-B side into the top of your PSP and the Standard-A side into your PC. From the PSP software, navigate to the top of the settings list and select "USB Connection." Your PC (Windows/Mac/Linux) should detect a new "Removable Disk Drive" that you can then access.
STEP 2: FORMAT YOUR MEMORY STICK
In order to be able to use your new memory stick on your PSP, you'll have to format it. When you format your memory stick, the formatting will create a set of new folders on your PSP: GAME, MUSIC, PHOTO, and SAVEDATA.
STEP 3: EXTRACT THE SAVED GAME
This process will greatly depend on which software you use to extract zip files. WinRAR for instance offers the "extract here" option, which will simply extract the contents of a zip file to it's current directory.
STEP 4: TRANSFER SAVE GAME TO "SAVEDATA" FOLDER
Just copy the folder you have just extracted, and paste it into the PSP's "SAVEDATA" folder. But, BEWARE!, to any folder overwrite warnings! Because the PSP save game folders use the same names for the same games, copying folders into these locations could lead to lost data. For this reason, we recommend that you backup your old save games before overwriting them. For Example, I would simply rename a folder like "ULPS0004" to "ULPS0004_backup."
STEP 5: EXIT USB MODE
Because your PSP has been in USB Mode throughout this process, just push X to exit. Then you can safely disconnect your PSP from your PC.
STEP 6: VERIFY TRANSFER OF SAVE DATA
To verify the integrity of the SAVE GAME data you have just transferred, use the PSP's built-in Save Data Utility. Select it from the "Game" menu.
That's it, simple and smooth.
Oct 16, 2008 | Sony PlayStation Portable (PSP) Console
Games on Memory Stick
well, to run games on a memory stick you must have a certain psp hooked up to where you can play games on your memory stick, buying a psp from the store won't let you play games from the memory stick,you must buy a psp game,, im sorry
Aug 14, 2008 | Sony PlayStation Portable (PSP) Console
PSP Games
You most likely need to format the memory stick with the PSP. What may have happened is once you've upgraded, the PSP re-rooted itself into the memory stick. So it's looking for a folder that doesn't exist. (But that's just what I think...) I've had this problem also. After you format it with the PSP, it should work fine. As for your game files, they should still be saved on the memory stick. Search all your files with your computer then save them to your computer so they don't get formatted. After the format, put the files back onto the memory stick where they belong and everything should work fine! Please ask if you have any questions!
Jan 02, 2008 | Sony PlayStation Portable (PSP) Console
Problems after updating ver3.80
Possible solution:
You can try to have your memory stick content backed up to your computer local hard disk, and then do a format for the memory stick from your psp, as well as full reset, (should be found under the setting=>system setting menu) then, copy the backups back to your memory stick.
Give a try and let me know if it works
Dec 20, 2007 | Sony PlayStation Portable (PSP) Console
1,213 people viewed this question
 Grubhead
Grubhead
