Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
I just posted my problem with the ice maker
Not making ice after emptying the ice from the bucket all electrical connections are good just no ice. Black hose in top of the freezer seems fine, not frozen up blocked
Does your icemaker have a seperate filter that is JUST for the icemaker?
Posted on Aug 23, 2008
We replaced the ice maker in our Samsung refrigerator and now we cannot get the water to dispense once we cut the water back on. What do we need to check?
By your question, you are saying you are not receiving water from the water dispenser. Make sure the electrical connector you disconnected when making the ice maker repair is securely re-seated. If you removed the door to make this repair, there is also a connector at the top of the door make sure it is also seated. The only other connection for water or ice delivery is at the water inlet at bottom rear of fridge. There are two relays at the water inlet, one for water, one for ice. If these were disturbed recheck that they were reconnected. Of course these checks should be performed with the power cord disconnected to prevent shock. Once all is checked, plug fridge back in. When dispensing water you should hear a solid clunk as the relay engages. As for the ice dispenser you will only hear the clunk as it requires water to fill the tray. Just remember to allow for two complete cycles (fill - freeze - dump) before receiving full cubes. Oh, by all means don't forget to make sure the Ice bucket full lever (Usually a thick wire) running the length of the bucket Is in the down (empty) position. If it is up, this turns off the ice maker indicating the bucket is full. New ice maker units usually come packaged with the (bailer wire) in the up (off) position.
Hope this info helps!
Dec 28, 2014 | Samsung RS2630SH Side by Side Refrigerator
How do I Prevent ice dispenser from freezing up? Ice is in the ice bucket but will not disperse.
The ice stays in the cubemaker tray for a set time and then empties into the bucket. If the freezer was too warm the ice wasn't frozen enough when the cube maker emptied it and it all stuck together. Now the fridge is cold again empty the bucket, make sure there is no ice stuck in the dispenser and try again. If it is a Samsung fridge do the above and turn it off for 30 seconds and back on again. Sometimes the controller and display freezes and reads the wrong temperature.
Nov 18, 2014 | Refrigerators
My ice maker is not making ice cubes
Ice mold empty (no ice in bucket)= water valve
Ice mold full (no ice in bucket)= Ice maker
Feb 10, 2010 | Refrigerators
My Samsung RS267LBBP refrigerator low ice
you could have a faulty ice maker try to reset it by pushing the reset button if this does no good have the ice maker replaced are you cubes normal size
Sep 16, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Ice maker stopped working
if there is ice in the mold then the problem is the ice maker unit , replace the ice maker for the fix.
Jun 10, 2009 | KitchenAid KSRG25FKSS Side by Side...
Ice Maker is not working on my Whirlpool Gold Refrigerator
I removed six screws from the ice maker to pull it out of the refrigerator.  Their are four screws holding the ice maker in place and two screws on the ice maker door.  Had problems getting the electrical harness disconnected.  Used hot water to removed the ice cubes that were struck in the ice tray.  Poured all remaining water into a bucket and re-installed ice maker.  As of now, the ice maker is making ice !
Apr 08, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Ice maker does not make ice
check water valve check for water
Apr 07, 2009 | KitchenAid Refrigerators
Crosley side by side ice maker makes to much ice !!!!!!
Most ice makers have a wire bar that senses when the ice bucket is full. The bar lifts up when new ice is made. The ice maker determines if the ice bucket is full by lowering the bar back down after the ice drops into the bucket. If the bar hits the ice cubes in a full bucket, the ice maker shuts off. If the bar drops all the way and dosen't touch ice cube, the ice maker continues making ice until the bucket is full.
So you likely have one of the following problems:
1) The wire bar is missing or bent. Check to make sure that when the bar is pushed up, the ice maker stops making ice. Most bars will 'click' into the up position so you can shut the ice maker off. Push the bar up until it clicks into the up position and wait overnight to see if it makes more ice. If there is no wire bar over the ice bucket, that is your problem.
2) The switch the wire bar is connected to is malfunctioning. If you push the wire bar up and the ice maker continues to make ice, this is likely your problem. You will need a new ice maker unit. Try Appliance Parts Pros or EBay for a new unit.
Jan 07, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker is not working but water dispenser is.
Try the following check:
First make sure that the temperature in the freezer is 5 degrees or below.
Unplug the fridge and then plug it back in.
If the compressor is running when you unplug it make sure that you wait 15 minutes before you plug it back in.
You will then have 60 second to open the freezer door and 2 second to view the LED output code.
Ice maker check 3 pulses pause 3 pulses
Optics receiver 4 pulses pause 4 pulses.
Optics emitter and receiver 2 pulses pause 2 pulses.
All good 5 seconds on
Dec 28, 2007 | Whirlpool ED5SHAXM Side by Side...
check you havent put icemaker onto vacation mode.. also if it has infra red sensors at both sides of ice maker unit , these can go faulty.. ally
Jul 02, 2007 | Whirlpool ED5SHAXM Side by Side...
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
102 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
