Question about Estro Barista Athena
Barista athena We didn't use our barista athena for a couple of weeks and when I went to use it water did not come out of the steam wand, rather straight through the shot handle which is unusual because when I first turn it on I flush the steam wand (per the directions) and then flip the steam on switch. I opened the top and it doesn't look like anything is blocked
  • ultrarunning Oct 20, 2008
    same issue, didn't use for months, turned on, waited for green light (steam button off) and then once green light came on, turned knob on, but just a few spits of water and looks like the water is not being pumped thru the tubing from the bucket. Ideas?
I have just had a similar problem. Water no longer moves through the steam wand when I try to prime it. Instead, water shoots through the shot handle (or screen if handle is not in).
One thing I did notice is that the dial for the steam wand unscrewed too far and basically popped out. I screwed it back in and the water did not ever come out of the wand again. I took the top lid plate off and unscrewed the wand dial and removed it. I put it back and noticed that there is a little metal spring switch underneath that I assume turns the wand pump on.
Attached to the dial is a plastic sleeve with a flat side. When the dial is turned, this sleeve should turn the switch on. I noticed though that the sleeve is creeping up the shaft towards the dial head which makes it miss the spring switch.
I don't know what kept the sleeve in place before. Probably a plastic stop that has been worn away from use. There is an allen screw in the sleeve, but tightening it doesn't seem to keep it in place. Perhaps inserting a spring in between the dial and the sleeve would work, but the sleeve cannot be taken off to do this. No other answers right now. My wife is not happy the lattes have dried up.
Posted on Nov 07, 2008
This happened to me once, and it was a matter of a clogged steamer wand. I straightened a large safety pin and very gently scraped it up and into the wand, pausing to turn the steam valve every couple of scrapes. eventually whatever was in the wand (assuredly milk, even though I clean it religiously) came out and voila- no more problem! hope this helped!
Posted on Dec 17, 2008
Krups XP5240 very loud pop sound while steaming
Take it back to the retailer, tell them about the noise and the water leak. It's under guarantee so you should not be looking for any self help solutions, it's faulty.
Mar 12, 2017 | Krups Coffee Makers & Espresso Machines
Delonghi Magnifica My steam arm drips when I make coffee.
I initially replaced the o-rings in the pipe/valve assembly. It didn't work for long (not correct size o-rings probably). I then bought a new pipe-valve unit. To replace you need to pry off the stream handle (chromed plastic). It only fits one way on the axle (so take notice when replacing!). Then remove back and side covers (6 screws all at the back). Then remove top (2 screws each side at the front and a couple at the back). Then the front panel should be lose. (Instructions based on a slightly different model)
Mine made better coffee after I fixed the leak! A large portion (perhaps 25%) of the water intended for the coffee went via the steam wand straight into the drip tray, which is not good.
Oct 15, 2012 | DeLonghi Magnifica 3300 Espresso Machine
I have a starbucks barista athena that has a vapor lock. How do I fix this?
It's easy to break the vaporlock on an Athena.
  1. Power the machine off and let it cool (20-30 minutes is plenty)
  2. Place a mug under the steam wand and open the steam valve all the way. If there's residual pressure, let it release the pressure before proceeding
  3. Power on the machine and wait for a steady stream of water from the steam wand.
  4. Close the steam valve and you should be good to go!
Jan 14, 2011 | Estro Barista Athena
Water drips from the steam wand when I'm trying to get water through the espresso. I have a starbucks barista athena. I took the top off....but cannot see how to fix it.
Mine had the same problem, and I was able to fix it. 1) Unplug the unit and allow it to cool. 2) Remove the 2 screws from the top of the unit, and take off the cover. There will be a ground wire attached to the top. You can set the cover off to the side with the ground wire still attached. 3) Rotate the steam valve until you see the hex screw that adjusts the location of the inner plastic stop relative to the outer valve knob. You will need to "tweak" the position of this inner stop relative to the outer knob to allow the steam valve to close a bit tighter. Be aware that there is limit switch that needs to be in off position or pump will come on as soon as you turn the unit on. There is also a hard stop on the inner plastic piece that prevents over-tightening of the valve. This is a bit of a touchy adjustment. I would suggest playing with the mechanism before you adjust it so that you understand how it works before attempting a fix.
Sep 25, 2010 | Estro Barista Athena
Barista Athena No water comes out the head?
A good operating pump will fill the tubes in 2 seconds. Sometimes the spring loaded check ball in the pump assembly (brass tube) gets stuck. It can be unstuck by disasdsembly or high pressure air application.Unplug unit before opening the top or any inspection. The brass tube unscrews from the angle fitting, then release the rubber mount by depressing the white tab and slide it out. Note slowly and carefully the positions of springs, ball, plastic plunger and rubber washers.Look closely at the holder for the brass tube and you will see that it releases with a push and turn. The white plastic spring retainer in the brass tube unscrews with small forseps or two toothpicks. That spring should be weak and you should just be able to blow a little air by mouth (one way) through the tube if assembled correctly. I use a toothpick to push the stuck plastic valve out and scrape the calcified deposits off..
Jul 05, 2009 | Estro Barista Athena
No water flowing through steam wand
You might want to try draining the machine and filling it back up. There could be a number of different things wrong with your machine.
Mar 21, 2009 | Starbucks Barista Utopia
Barista Zia Espresso Machine
file:///Users/Julie/Downloads/Barista_Final_011305.pdf
I had the same problem. The Barista Zia is the same as the Barista Athena on the inside, the only diffrence between the two is the plastic shell on the Zia, and the steaming wand is on the opposite side. This is the instruction manuel for the barista athena, so its basically the same. Thanks! good luck!
Nov 10, 2008 | Starbucks Coffee Makers & Espresso...
Starbucks Athena
I have had this machine for four years now, and it is FAB!!! it does have an extra step to it- after you put in coffee and add water to the reservoir, you DO need to prime the pump. So here's what you have to do:
-Fill the reservoir with MORE water then you think you will need, fill the coffee filter with the standard amount of finely ground bean.
-Turn the machine to "on," making sure the "steam" switch and valve (knob) are off.
-Wait till the green "ready" light comes on, then put an empty cup under the steam wand and turn the valve on (the steam switch is still in the off position). Hot water will come out of the steam wand, allow it to flow until the "ready" light blinks off. Discard this.
-close the steam valve, stopping the flow of water.
-turn the "steam" switch into the on position, wait for ready light to come on again.
-put your milk container under the steam wand and froth to your heart's content (this machine makes GREAT frothed milk and you should use a large enough milk container to allow for that! *smile*)
-when you have finished with the frothing, close the valve and flick the "steam" switch back into the off position. You are now ready to make your espresso.
-push either of the two buttons, ie one or two cups, and the espresso will start to flow. There is a way to set the length of time for each of the two buttons, but I have had mine set perfectly for so long i don't know how to do it any more. Sorry!
This has been the best machine I've ever used, and has lasted me for years. I heartily recommend it!
Jan 02, 2008 | Estro Barista Athena
Estro Barista Athena Logo
408 people viewed this question
Top Estro Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Estro Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
