Question about Lexmark Office Equipment & Supplies
Having a problem copying in colour only prints about half the page and stops and says 502 hardware error but willprint out in black
  • kwilliamson Aug 13, 2008
    x5100
  • Jefferson Casavant
    Jefferson Casavant May 11, 2010
    Could you state the specific model of your printer?
  • 35 Answers
I found this on fixyourownprinter.com after some digging.
Try this:
Hardware Error 0502 on LCD Display ID:ENUS16536
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridge carrier.) Do the following:
1. Switch off the printer using the power button.
2. Disconnect the power cable from the back of the Lexmark X5100 / X6100 Series.
3. Leave the power cable disconnected for 30 seconds.
4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
5. Take out both cartridges.
6. Place an index finger on the encoder strip on either side of the cartridge carrier.
7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
8. Lightly press the strip first to the rear and then forward, if necessary.
9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer. If this does not clean these parts, a cotton swab with rubbing alcohol on it may be used.
10. Reconnect the power cable and switch the printer on again.
11. Perform the hardware test without cartridges first and then with both cartridges.*
12. Make a standalone copy.
13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
That's the best I can give you.  Quite sorry if it doesn't work.
Posted on Aug 13, 2008
I had the same issue, 502 error, only half a page would print.
Shut off printer, move carriage to far right side of rail. take cotton ball dipped in rubbing alcohol and clean paper path where carriage travels. You will notice it is probably sticky with ink. Several cotton balls will be needed to clean it up. Move carriage to left and clean remaining area.
Posted on Feb 23, 2009
I have a xante 502 it has streaking on the top side of printing I printed each color and streaking is on each color with black the worst what part do I replace?
if you are familiar with ilumina menu search for the ID Test Pattern. Print test using 11 x 17 page.
On the copy you will see which of the drums need to replace, if the copy has vertical or horizontal lines on it the drum which ever color shows it has to be replace.
Jun 19, 2014 | Xante Ilumina® 502 Laser Printer
Canon ir2520 copy only half page
it is normal, just mixing, continue printing, it will slowly cover the page till the entire page is printed or copied, dont worry, just reuse the half printed paper till when the pages print complete.
May 27, 2012 | Office Equipment & Supplies
I keep getting Hardware Error 502 (printer stalled) when I try to copy a page or to print direct from the computer. I followed the instructions for a "fix" but still doesn't work
Hi there
Not know what Instructions you had before but got a sit for you to look at.
Click on link it will take you there to your error 502.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=45A49F4D2A17494E8F4B63951C8A1237&doclang=en&cs=
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 15, 2010 | Dell A960 All-In-One InkJet Printer
Printer error 502
Shut down the printer, check whether the printer has peripheral devices such as a stabilizing power supply, and disconnect them.After five minutes, restart the printer to see whether the fault corrects itself. If the fault persists, the heating component may be faulty and the printer will need to be repaired.
Thanks for using FixYa.
Jan 26, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Installed new black ink cartridge per instructions. HP #56 - machine type hp psc 2210 all-in-one. Machine instructed how to run cartridge alignmet check. In all modes machine runs about one half check and...
to complete the alignment it needs to detect the lines printed from both the black and colour cartridges.maybe ur black cartridge is printing the necessary pattern but the colour is not printing so when it tries to read the colour paattern ,it cant read and cancels the alignment and ejects the paper out..it will keep on doing this if it cannot read the both colour and black patterns.see to it that both ur cartridges are printing and working properly.
Dec 17, 2008 | Office Equipment & Supplies
Broken printer help
have you tried manually cleaning it...if not give it a go...thats the only thing i can think of
Sep 09, 2008 | Canon PIXMA MP780 All-In-One InkJet...
2 Missing ink black streaks
Check the dev unit for missing lines. Also clean the laser glass with the supplied cleaner pad - though if the problem were caused by toner on the lens, there would be gaps in ALL colours.
Check the dev units first. You can also do a stop test whilst a full colour test image is half way through printing and see if the lines are missing off the image on the PCU as well.
May 20, 2008 | Epson Aculaser C1100 Printer
Konica Minolta 2530DL
I had the exact problem with the paper stopping at the same point in the printer. The fault was not the paper feed but the fact that the drum stopped at this point due to a loose toner cartridge. I rotated the cartridge using the menu for relpacing it and removed the cartridge and then re-fitted making sure it was fully seated in the printer. It now works fine. I would check each of the toners again.
Chris
Dec 12, 2007 | Konica Minolta magicolor 2300DL Laser...
138 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
