Question about Canon MX700 Office All-In-One InkJet Printer
Printing problem when my machin prints either a fax or copy the lines come out gagged or some times the wording is printed double
In China , I found certainly have secret society, it have
secret words and body langue or other things.it control the real society.
decipline and wealthy even women. it have out of the control of Chinese goverment . I think the whole world should know these information.
Posted on Sep 22, 2008
Will not print word document
Most likely there is a problem with the default "Calibri" Font in the body template of Normal.dot.
temporarily change the default font to say "Times new Roman", then download another version of the Calibri font from internet or copy from another PC.
Dec 18, 2013 | HP Officejet Pro 8600
No print on copies or faxes
This is a clogged print head. This happens if the printer has been off for a long time or if the cartridge was removed and the unit left empty for any time.
Take out the cartridge and press the print part on a piece of paper. Any black lines? If not, you will need a new cartridge. Wiping the print head gently with a Q-tip moistened with PURE alcohol (99%) may restore printing.
Mar 31, 2010 | HP 1040 Plain Paper Inkjet Fax
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
4100 when I copy I get a black line down the middle Ok after cleaning inside top cover, but,comes back after a few copies. Printing and sending fax ok.
Try printing out a report. If the line is still there you need to use the wire cleaner on your print cartridge or if that doesn't work, replace the drum unit.
Apr 03, 2009 | Brother IntelliFAX 4100 Laser Fax
Canon will not receive faxes or copy documents
see if you have fax line(conect a telefone in the line to see if you have tone) or if the cable is conected.
Nov 21, 2008 | Canon NP 7130 Black and White Copier
Muratec MFX 2500 copies have lines
need to be more specific, printing have both hor. and vert. lines aas well as copying ???
Dec 18, 2007 | Muratec MFX-2500 Plain Paper Laser Fax
Lines show on printed copies from Muratec MFX 2500
Probably a bad cleaning blade in the toner cartridge or a dirty charge wire.
Look for a small slider on top of the cartridge.
SF-755P LASER FAX
IF WORDS GET STRETCHED ONLY ON RECEIVING AND NOT ON PRINTING OR COPYING FRONM THE MACHINE, THE PROBLEM LIES WITH THE TELEPHONE LINE DISTURBANCE YOU MAY TRY GETTING THE PHONE LINE CHECKED /CHANGING THE CABLE LENGTH SETTING OR ATTENUATION LEVEL IN THE TECHNICAL MODE.. HAPPY FAXING OMNIPRESENT.
Nov 06, 2006 | Samsung SF-755P Laser Fax
Canon MX700 Office All-In-One InkJet Printer Logo
281 people viewed this question
old marine
old marine
