Question about Watches
Dakota digital compass-three button
How do i rest the time on the watch?
    Scholar:
  • 65 Answers
Here is the site for the dakota watch company. find your specific product, click on the item for more details. on the left column their is a "instrution" tab under resources. you may need to scroll down to find it.
i hope this helps.
Posted on Aug 13, 2008
  • matthew carroll
    matthew carroll Aug 13, 2008
    did this information help you,
I just bought the Casio SGW500H-2B Mens Twin Sensor 100M Digital Sports Watch Compass Thermometer. My problem is the digital readout in compass mode reads fine but the needle/ second hand points to east...
To fix this, hold down the A button for 4 seconds. this allows you to recalibrate the home position of the second hand. My secondo hand was posting exactly 90 degrees west in compass mode, and this home position recalibration fixed it 100 percent.
Sep 11, 2013 | Casio Watches
HOW DO I RESET THE TIME ON A DAKOTA COMPASS WATCH
http://buydakotawatches.com/PDF_FILES/Digital.pdf this link should provide you with the information needed to set your watch.
you may try this link as well if you need more or diffrent info http://www.buydakotawatches.com/Instructions.aspx
I hope this was helpful.
Aug 12, 2008 | Dakota Watches
I have a tcm 217362 watch with a digital compass how can i set it up to show me north it currently shows cal. and when i press the top right and left button it shows err.(probably error) it is a black and...
Hi john30x,
You have to calibrate the compass.
1. Press the upper right button (switching to compass mode)
2. Press and hold upper left button. The "CALL" will appear on the display. You are in compass calibrating mode.
3. Rotate the watch horizontally (around his vertical axis) slowly, so to be sure that he point the North at least 2 times.
4. Now press the upper left button again to input the
declination (this is the angle between the magnetic and real pole). It is different for the area around the world, that you want to explore.
5. Switch between the positions of the cipher by pressing bottom left.
6. Change the cipher by pressing bottom right.
7.
Switch between the active position by pressing bottom left. Now you have to enter East or West declination
8. If you are ready press the upper left. "END" of calibration will appear on the screen
Once you calibrate and set the declination you can use the the compass by pressing upper right button. As the compass is very sensitive It is good idea to calibrate it on a field, far away of metal objects and electromagnetic fields (cables, ect.). You need to calibrate the compass each time you want to use it by different surrounding.
Remember the compass function of your watch need much more energy than the watch itself. Don`t worry to change the battery when dead. The water resistance remains good even after. Very robust and accurate device. I hope that should help.
May 15, 2011 | Watches
Is it worth having it fixed. Can't rest it, shows digital figures
This is a inxpensive watch and really not worth the price to have it repaired .....Sorry
Jan 29, 2011 | Timex Expedition Digital Compass T40611...
Can i find instuctions to compass watch
First, assuming you do not have the manual, following the notes below, find an outdoors location away from any medal building, obstructions, etc. You must calibrate the compass to get anywhere near the +/- 10 degrees accuracy readings claimed.
Timex has two ways to find information about your particular watch. If you don't have the manual, Try this link:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Sep 07, 2010 | Timex Expedition E Compass Watch Titanium...
Compass is no longer pointing North
I had the same issue. I found that if you re-calibrate the compass the same way you did the first time, then it will act properly. I've had to do this a couple of times and it works.
Jun 12, 2009 | Timex Expedition E Compass Watch Titanium...
Need a watch manual or instructions
A-Tech watches are sold under Dakota name. Here is the link for manual (best I could find):
https://dakota.webfeatsecurity.com/PDF_FILES/3sensorpt2%5B1%5D.pdf
Use zoom to get a better view.
Rate me, please.
Mar 20, 2009 | Watches
How to set time on my National Geographic Dakota Atomic Watch?
For the national geographic radio controled watch.
The easiest way to rest this watch is to remove the battery.
Once replaced the watch will flash set to 12. Push and hold the upper button till the hands spin. Press this button again to stop the hands. Tapping the upper button will make the hands move forword 1 sec. Set all the hands to 12. becareful, if you pass 12 you will have to go around again. to start the hands spinning again press and hold the upper button untill the hands move. Once all the hands are at 12, press the lower button and the screen should flas LON for london. Set the city code using the upper button to your area. press the lower button hard to confirm the information. The watch should set itself to the correct time. If it starts running from 12, place it on the window sill for the night so that it can get a signal.
Mar 08, 2009 | Dakota Watch Company Radio Controlled...
Compass wont work correctly
if your hands aren't straight when you use the compass try this to sync the hands.
1. Press and hold the middle button to enter T-Touch mode.
2. Press the centre area on the face twice to display 24hr/12hr
3. Press and hold the middle button to enter T-Touch mode untill screen says sync.The hands will face 1200.
4. Press either the upper (East) or lower (West) button to adjust the compass hands. They should both face 1200.
5. Press the middle button to get back to 'regular' compass mode. Note that your offset setting will still show in the digital area.
Oct 10, 2007 | Tissot T-Touch T33759851
Watches Logo
362 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
