Question about JVC XV-N212 DVD Player
Connecting DVD player to Viewsonic TV
Just want to know easierst most basic way to connect DVD player to TV
  • 35 Answers
You will use component video cables.  They come in threes and all they require you to do is connect the DVD output with the TV input and match the cable colors on both ends.  They will be red, white, and yellow.  The yellow is the video, and red and white are left and right audio.  If your TV is too old to have stereo audio, only one (red or white) audio cable needs to be connected.  It doesn't matter which.  The yellow cable always needs to be connected.
Another option, but a slightly less common one, is to use a single AV cable to connect the two.  The reason this is less common is because most newer TV's do not have AV input, and newer DVD players do not have AV output.  If it does, however, this is the most simple, and you probably wish to take advantage of it, so you have a connection available when you purchase a newer unit which does not have AV.
Posted on Aug 13, 2008
How hook up dvd player to tv. what channel put tv on to see dvd pitcure
You should be connecting your DVD player to either an HD input or a composite video connection. Most modern TV SHOW will have at least 2 HD connections. On your TV setup menu there should be an HD connection to choose (probably HD-2) You will need to switch your input selection on your TV menu between HD/TV for TV and HD2 for DVD. It's hard to give specific directions without knowing the TV and DVD models.
Oct 27, 2016 | Televison & Video
How to connect dvd player to tv
    1. If so you can get yourself a component cable and connect the DVD player to the TV using those plugs. Otherwise, you will need to get an RCA to HDMI converter.Nov 23, 2015
      Connecting old VHS/DVD Player to my Smart TV - Tom's ...
      www.tomsguide.com/.../id.../needed-connecting-vhs-dvd-player-smart.html
    Feedback
  1. 5 Easy Ways to Hook Up a DVD Player (with Pictures)
    www.wikihow.com/Hook-Up-a-DVD-Player
    wikiHowHooking up a DVD player to your TV will give you access to countless hours of movie-watching bliss, and most modern TVs and DVD players make the setup ...‎Setting Up your DVD Player - ‎Connecting with an HDMI Cable
    How to connect a standard DVD player to a TV - YouTube
    ? 2:57
    https://www.youtube.com/watch?v=8pARHjY8xoo
    Jul 5, 2011 - Uploaded by All About Home Electronics.com
    Lol I used my standard AV cables for the component, and I used an adapter to plug the audio into my speaker ...
Dec 30, 2015 | Televison & Video
Hi Need help connecting a dvd player to LG 42 inch tv
Got to be more specific than that! what cables are you using etc. Not Miss Cleo here.
Dec 28, 2009 | LG Televison & Video
How to connect dvp 3356 t0 samsung 29 inch tv with crt tube.
Please check the connection. If you are connecting the 3 RCA cables to DVD component input/output, you need another pair of RCA cables to connect to audio out (FL&FR rear of DVD player) and Audio in (L&R) in your TV set. Else connect 3 RCA cable in 1-Video out & 2 Audio out of DVD player and 1-Video in & 2 Audio-in of TV.
Dec 15, 2009 | Philips Televison & Video
How do I hook up my DVD player to my TV. I have a simple Panasonic DVD player and a Viewsonic flat screen TV.
Hi, I recommend using a scart lead, all TVs and DVD players should have this connection.
Dec 05, 2009 | Sanyo DVW-6100 DVD Player/VCR
Now have verizon Fios and cannot get DVD player to play
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
Regards.
Jul 25, 2009 | Sharp DVMX1U DVD Player
Laptop not connecting to tv
TV's do NOT accept all computer resolutions. You must keep trying the various resolutions of the computer until you find one that works.
I believe 1280x768 normally works for most TVs.
Apr 29, 2009 | ViewSonic NextVision N2050W 20 in. LCD...
Jvc stereo receiver rx-5032vsl
If your TV is a higher quality set that is HD capable, the problem may be in using RCA jacks. I suggest buying some component video cables. Some higher quality DVD players and TVs do not respond well to cheaper video feed wires. The only other option is a problem with the DVD player since the picture is coming through fine through other DVD sets. Try the wires first, its your cheapest option.
Dec 29, 2007 | Gateway FPD2275W LCD Monitor
Connecting devices
well its actually pretty striaght foward.All components like DVD,VCR,CAMERA, CABLE BOX etc.. will usually be connected to a TV , MONITOR or some kind of main viewing source.to connect
DVD to TV =use video out of dvd to TVs input 1 ,2,3 or 4 .To view dvd on tv simply activate that input you used as input for dvd.this applies to any other components you use to TV or monitor
Dec 29, 2007 | Televison & Video
Connecting tv to dvd player
It should be fairly straight forwards.. Simply get the SCART to SCART Cable.. Connect up the Two, DVD to Screen, turn them on, selecting any input/outputs Format etc, setups from any Menus...then start player select "Play" & ya should see the Picture & hear the sound...
Aug 31, 2007 | Philips 30PF9946 30 in. HD-Ready Plasma...
JVC XV-N212 DVD Player Logo
512 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
