Question about Husqvarna Designer I
I have a viking sewing machine designer 1. The touch screen is dark and there is nothing on the screen. What needs to be done?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 192 Answers
You can try running the latest update on the machine. I have heard of a person turning their machine off in the middle of an update and this is what it did.
You don't have to be able to see the screen to install the update, and it's free to try.
Next, if this doesn't work, go to an authorized service center.
Posted on Sep 14, 2008
How do i restore designer pape only letter page is showing on screen have husqvarna designer 1 with 4d embroidery extra
I'm not sure I understand the problem exactly. It sounds like you touch pad is not responding properly. Did you notice before this happened that you needed to touch the screen not exactly where the button on the screen comes up. If that is the issue your best bet is to have a husqvarna Viking tech and have the touch screen calibrated.
Feb 11, 2015 | Husqvarna Viking 1
How to open fixed screen? on Designer 1
I would check the Touch Screen first. Your Owner's Manual tells you how to calibrate the touch screen from the SET menu. However if the touch screen isn't working, you can't get to the SET menu. Suggest taking it to an authorized Viking Dealer and they would be able to quickly determine the solution. You can find the nearest dealer by going to the Viking website - http://www.husqvarnaviking.com/us website and click on 'Locate a Dealer'.
Jun 10, 2014 | Husqvarna Designer I
My husqvarna designer 1 keypad doesnt work
It could be the Touch Screen. If it is a Designer 1. If it is a Designer II or Quilt Designer or #1 it could be the Dcard. Recommend it be checked by an Authorized Viking Dealer. You can find the nearest dealer from the Viking website - http://www.husqvarnaviking.com/us Click on the link Locate a Dealer.
May 21, 2014 | Husqvarna Sewing Machines
How can i change cable in touch screen of sewing machine
if the touchscreen cable is broken or damaged, the only fix is to replace the touchscreen assembly with a new unit which includes a longer and more robust amber color cable . I suggest that this repair should only be done by an authorized Viking dealer.
Apr 20, 2014 | Husqvarna Designer I
How do I find out the embroidery time on my Viking Designer 1 sewing machine?
Hi there, If your trying to find out how long it took you to embroider something, You need to go to your touch screen menu- touch Set- then down at the bottom left of this screen and touch More- three (3) times you'll get to where it says Running time:(It's the 3rd Selection) There it will actually show you the total running time (Sewing and Embroidery If you haven't zeroed it out by hitting the zero (0) next to that selection.) You can do this on the touch screen with the embroidery unit on or off. You need to touch the zero (0) to zero out your time before you start an embroidery project. Once you've done this and you've finished an embroidery you can check how long it took by the touch screen menu- Set- touch More 3 times and there you will see how long on the Running time it took to embroider your design. I hope that helped. The total time your machine has ran (Embroidery and Sewing) is kept in Memory on the Service Screen that your Technician gets into when he services your machine. So your not actually wiping out that. The Set menu is just for you to keep track of how long your machine sews or embroiders something pretty much. I hope that helped you out with your question. Happy Sewing!! Kathy
Nov 19, 2010 | Husqvarna Designer I
Viking designer 1 screen crack can't use touch screen sensor not working due to crack. can it be repair and how much would it cause me.
The touch screen can be replaced. The part is a little under $200 and the labor cost will vary with the repair facility that you use.
See an authorized dealer.
Jan 07, 2010 | Husqvarna Designer I
I recently purchased a Husqvarna Viking Designer SE online and just unpacked it obvously from the original factory packing. The machine turns on, lights come on, motor runs and the machine even sews...but,...
Sorry. Sounds like a dead LCD screen. It will have to be replaced by an authorized Husqvarna Viking dealer. Be sure it is an authorized dealer. Check the Husqvarna Viking website for dealers close to you. Http://www.husqvarnaviking.com/us
Nov 16, 2008 | Husqvarna Viking 1
Just made a floppy disk from quick font plus and now
1>Turn on machine
2>touch PROG (menu on top)
3>insert desired font disk
4>touch floppy icon
5>select font/font size
6>touch each letter consequtively until speeled (use "_" in menu for a space between words/names.
7>When done, touch REP (menu on top)
8> then start to sew by pressing start/stop
Nov 15, 2008 | Husqvarna Designer I
Sewing Machines Logo
119 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
