Question about Microsoft Windows 98 for PC
Universal serial bus
What if, your usb getting overload I mean, its full of data and you try it to unplug but you plug it again and it cannot open? My problem is not so serious but I want to make my data or files from the usb back.
    Scholar:
  • 27 Answers
This could only mean that the flash drive was corrupted. I got a solution for you but you must try to download a third party software called Stellar_Phoenix_FAT_and_NTFS_v2[1].1.
In this case, this software retrieves lost files or even corrupted files from separated hard drives and other removable disk such like USB drives.
It works for me, I sure hope it does to you too.
Posted on Sep 06, 2008
6ya staff
SOURCE:
My usb ports aren't working, they are not finding my pen drive even though it lights up
Some pen drives require drivers, if that is the case here go to the pen drive manufacturer's website, for example: SanDisk.com their support section and downlaod the driver you need. if Visa or Windows 7 is your operating system it should automatically search for the correct driver. Also, there are a limited number of devices that you may plug into your usb ports if you overload them you'll get a yellow warning sign in the device manager under Universal Serial Bus controllers. Right click on computer go to properties and look at your device manager you'll see Universal Serial Bus controllers.
Sep 09, 2011 | Toshiba Computers & Internet
What stand for USB memory?
Hi
Universal Serial Bus.......
Aug 10, 2011 | Computers & Internet
My computer keeps on saying that a usb device not recognized. i havent connected any device to my computer. how can i fix it? tnx a lot..
First simply try turning off your computer then unplug your computer from the "power supply".
Wait 15 - 30 minutes and then plug it back in and restart. If that doesn't work....
1. Click Start, Control Panel, and then Performance and Maintenance.
2. Double-click the System icon.
3. Click the Hardware tab and then Device Manager.
4. Double-click Universal Serial Bus Controllers.
Uninstall the USB ports from here. To do so, right-click the USB controllers that are listed under Universal Serial Bus Controllers and click uninstall.
Hope this helps
Nov 27, 2010 | Sony Televison & Video
My freegent go 250 gb hard drive silver worked fine until yesterday. The hard drive is full of music and data, now when i plug it into my laptop, i cannot open the drive. When i try to open or explore the...
you might need a usb to firewire adapter or you can try
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you could see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click updare driver
hope this helps
Sep 29, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My scanner won't work the printer and copier work
Scanner drivers seems to fail to communicate with printer, you have to reinstall the USB driver. Follow the steps
1. Click start ->Run.
2. In the Run window, type "devmgmt.msc" (without quotes), click OK.
3. Device Manager Window will pop out, in this screen at the bottom you will see "Universal Serial Bus Controllers"
4. Click on the(+) sign next to "Universal Serial Bus Controllers" and look for "USB Composite Device".
5. Right click on "USB Composite Device" (Read Note below and then proceed) and select Uninstall.
6. After the the device is uninstalled, disconnect the USB cable from the back of the computer.
7. Restart the computer, after the system is booted plugin the USB cable.
8. You may need to wait for sometime for the device installation to get complete.
9 . Then try to print a word document.
Note: Before uninstalling the "USB Composite Device" right click on it and select properties to confirm whether that driver is for the printer.
Regards
Riztech
Jul 16, 2010 | HP Photosmart C5180 All-In-One InkJet...
When i connect my n95 phone to my computer by usb, it is not recognize.. how can i solved it/
Remove and reinstall all USB controllers To remove and reinstall all USB controllers, follow these steps: Click Start, click Run, type sysdm.cpl in the Open box, and then click OK. Click the Hardware tab. Click the Device Manager button. Expand Universal Serial Bus controllers. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time. Restart the computer, and then reinstall the USB controllers. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
Apr 19, 2010 | Nokia N95 Cellular Phone
Samsung E2210L Connecting to PC wont recognise
Apr 10, 2010 | Cell Phones
I have a Kingston Data Traveler 2GB USB Flash Drive which I bought 2weeks ago. Whenever I plug it in one of my usb ports, i get a message which says "USB Device Not Recognized. One of the USB Devices...
We have all had it, yesterday it was fine now it says it doesn't recognise ya USB device.. AARrrgg. Well there are various way to try to fix. Now providing your USB aint Kaput then this works like 99 outa a hundered.Simply Remove and reinstall all USB controllersTo remove and reinstall all USB controllers, follow these steps:
  1. Click Start, click Run, type sysdm.cpl in the Open box, and then click OK.
  2. Click the Hardware tab.
  3. Click the Device Manager button.
  4. Expand Universal Serial Bus controllers.
  5. Right-click every device under the Universal Serial Bus controllersnode, and then click Uninstall to remove them one at a time.
  6. Restart the computer, and "Windows" will then automatically reinstall the USB controllers.
  7. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
Remember with USB devices. FIRST, install software/drivers, then insert USB device SECOND.
Feb 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
"USB DEVICE NOT RECOGNISED"
Try this first...
  1. Unplug everything connect to a USB port on your PC.
  2. Open up the device manager (in Start/Run/devmgmt.msc)
  3. Click on the + next to ''Universal Serial Bus Controllers'' to expand it.
  4. Right-click on each item in the list and select ''Uninstall''.
  5. Once all items listed under ''Universal Serial Bus Controllers'' have been uninstalled; restart the system.
  6. Once the computer restarts and comes up to the desktop, plug your USB devices back in one at a time. You should see a ''New Hardware Found'' message in the lower right corner of the screen. After you do this you should get your devices back. If not then most likely your USB device or the USB controller on your motherboard are bad.
Otherwise, it may have finally died on you. USB flash drives are not as durable as internal drives on your computer and will fail if used a lot, a lot sooner than the bigger drives. If you can somehow get your computer to recognize it, copy all data you can off of your drive and any files you have problem with, I recommend you install data recovery software Recuva by Piriform and attempt to recover any data you can on it if it will allow you to.
Aug 31, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Printer P 400 not regonized by windows XP
check under device manager-universal serial bus controllers if you have USB PRINTING SUPPORT
-check for conflicts (?, !, X marks)
-If USB printing support doesnt show, unplug usb cable and try plugging cable to different usb port
-notify me after checking
Apr 05, 2008 | Office Equipment & Supplies
Microsoft Windows 98 for PC Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
