Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Lawn tractor draining battery when systems engaged
    Champion:
  • 313 Answers
Something is shorting. try eliminating any possibililty that ground & drains ur battery, it could be a bare wire that touching the metal etc.
Posted on Aug 13, 2008
PTO wont engage unless battery is charged up
Dale, it is normal for the PTO not to engage when voltage is low. Have battery and charging system diagnosed and repaired.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Charging System Battery Alternator Test Briggs FAQ
CHARGING SYSTEM MAINTENANCE
LAWN MOWER TRACTOR ZTR HOW TO TEST SMALL ENGINE VOLTAGE REGULATOR...
May 25, 2016 | Cub Cadet Garden
Why does my tractor keep draining the battery?
get a DC volt meter and check voltage at battery post before starting tractor
start tractor and again check voltage at battery posts . you should be getting between 13 & 15 volts,if not charging circuit is not working.
Its either a voltage regulator problem or a stator (located under flywheel) problem.
Stator produces AC voltage to regulator so you need to set your volt meter to AC ,most stators have a plug exposed insert red and black lead of meter into each side of plug, you should read around 23 to 26 volts AC if no reading stator is opened (bad). The PTO clutch requires a full 12 volts to stay engaged. you could have a bad battery bad cell .have seen new batteries be bad.
Nov 13, 2017 | Garden
Craftsman 20hp lawn tractor blades won't engage
check to make sure your cable is in tact its called a pto clutch cable about 20 buck on ebay it may be broke inside
Sep 26, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Blades fail to engage (using pto) after tractor has been running for awhile.
bad wiring to the charging system or the alternator is bad
May 03, 2012 | Garden
Have a Yamaha YT3600 lawn tractor. The battery is good but mower will no recharge the battery. replaced battery and have the same problem. my knowledge of the electrical system on this lawn tractor is...
the starter puts out the amps to charge the battery, you have do an amperage check to find out what its puting
any good parts store will set you up with an inexpensive tester
Jul 23, 2011 | Garden
I have a Husqvarna 21 HP Lawn Tractor and I went out to start it and the battery was totally dead, so I jump started it. It started but died out a couple times. So I got it going again and drove it up the...
The electric clutch needs full power in the battery to stay engaged. I would recommend you check your charging system before replacing the battery. Put a digital volt meter across the + and - terminals of the battery and while running at about 1/2 throttle you should be over 13 volts DC. Probably around 13.5 or so. If not you have a charging problem. Lawn mower batteries I have seen seem to last only 2-3 years. I would also recommend a trickle charger for extended periods of non use. Don't forget the Stabil also.
Hope this helps.
Jun 27, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I have an 18.5 Intek Craftman Tractor. The battery
pull the plug out and crank it over....if it's been sitting, there's liquid fuel in the cylinder...can't compress liquid...drain the carb too...use fresh fuel...
Apr 18, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Mower starts but when you engage mower it stops
Check for a weak battery. On some lawn tractors the mowing deck is started by an electric switch, and when the deck is engaged it pulls all the remaining power from the battery thus robbing the engine of the current it needs.
Oct 24, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Jun 07, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
52 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
