Hi I have a samsung dvd recorder. I am trying to record a video on to dvd recorder. doesn't seem to record anything. go to play it back and it does not play.
  • Jefferson Casavant
    Jefferson Casavant May 11, 2010
    Get a Laser Lens Cleaner disc.  It is a CD with brushes on the bottom to clean the lens (which reads the discs, and writes on them).
    This disc will probably run you five to ten dollars and can be found cheapest in grocery stores, and office supply stores.
    This is a very good deal because whenever it does not work again, simply run the disc through. It improves playback quality as well.
    And can be used in any problem drive.
    I would begin to save money for a new unit. It's going to be a year or two before you need it, though.  And begin to research units from a better brand.  I have had several bad experiences with Sony and the brand I use now and has served me for some years is a Magnavox.
  • 35 Answers
Sorry, that was meant to be a solution.
Posted on Aug 15, 2008
DVR620KU From the HDMI connector, how to get non-pinched vertical HDMI images on the TV monitor and on the DVD. Recorded DVD's have been Finalized
Using a DVD-RW disk, try ALL different recording settings even if they don't seem probable and record a sample. If output is correct with all BUT the HDMI-cable, go through ALL picture format settings on the TV when a HDMI-cable is used. Different discs and HDMI cables don't have anything to do with this. I'm still chewing on this...
Dec 15, 2014 | Toshiba DVR620 DVD Recorder/VCR
Dvds recorded on video to dvd recorder wont play elsewhere
Mosr DVD recorders have a "compatible" setting or require you to "finalise" the disc. Check that is being done.
It's also worth checking that the laptop will play other DVDs sometimes you need a codec.
Jun 23, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
LCD not working
my samsung mini dvd had problem with recording, the screen would go black (though menu displays come up fine).
could do play back but not record.
i put it in the sun for awhile or in a warm spot and it will record and show display.
it is not a complete fix but worth trying (on top of the heater works good too). of course the fix doesn't seem to work when i REALLY need to record something.
also had stripes coming across screen recently on playback, gave it a good tap and the stripes went.
Jun 17, 2009 | Samsung Compact MiniDV Digital Camcorder
Cannot copy video from JVC GZ-HD6 camcorder to DVD Recorder
If you can play the vision on your tv via an av connection you should be able to record it onto the recorder. the recorder can record anything thats being played on the tv even if the other device is connected to the tv via another av connection. try this & see if it works.
Mar 14, 2009 | JVC GZ-HD6 HDD Camcorder
Samsung dvd r-120 recorder
First make sure there is not a DVD or CD in the tray. It must be empty. Turn the unit off, then on. Then press the "play/pause" and "stop" buttons. This will reset your DVD player. This worked for me. Unfortuantely the DVD player has always had issues with DVD's that play over 90 minutes. At this point it freezes. I have updated the firmware. It seemed to freeze earlier prior to the update (say around 45-60min). It came free with my TV, which after a year was replaced as it required a $2k repair.
Jun 03, 2008 | Samsung DVDR120 DVD Recorder
Samsung dvd recorder
Make sure you have finalised the disk, otherwise it won't play back on other players. Also there are two standards that you can use to record onto disks, video mode or VR mode. Video mode was the original standard but it wouldn't let you edit or add anything to the recording afterwards but it is more compatible with other players. VR mode allows you to edit the recording but is less compatible for playback on other players.
Mar 28, 2008 | Televison & Video
SAMSUNG HR733 DVD RECORDER WILL NOT PLAY ANY REGION DISCS AT ALL
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
http://downloadcenter.samsung.com/content/UM/200506/20050618115856781_HR720-00758C-XAC-Eng_0519.pdf
Dec 08, 2007 | Samsung DVD-HR720 DVD Recorder
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
