Question about Broan-NuTone WHV20 Fan
Need to replace switch but can't find replacement
Hi
I have a NuTone WHV20 fan and the switch to turn it on no longer works. The switch itself says "Model CFVS-1 120V 60Hz 10A"
I can't find anyone with a replacement switch, can anyone please tell me what other switch I can use as a replacement. I am not electrical but really would like my fan to work
Thank yo so much!
  • Bob Blitzer Aug 24, 2008
    Same thing here, switch clicks but fan stays on.  No luck yet finding a dimmer-type switch with the same amp limit as the CFVS-1.
  • stevej1 Sep 18, 2008
    I too have the same problem. I looked for the switch at electricsuppliesonline, as suggested. Although I found the switch, it says "discontinued by manufacturer" and provides no way to put it in a cart...apparently they're sold out (I assume forever).
An update: Grainger has several fan controls with the same 10A capacity as the one you're looking to replace: http://www.grainger.com/Grainger/categories/hvacr/controls/fan-speed-control
Posted on Aug 24, 2008
They have a switch here that will work. I had the same issue.
http://www.hvacquick.com/frfnconfig.php?fm=wc
Its a 115 V - 10 AMP switch.
Posted on Oct 16, 2008
I actually had the same thing just happen. I found the same switch online. See here: http://www.electricsuppliesonline.com/modelcfvs1n.html
Posted on Sep 10, 2008
Nutone Model 671 Died and need Replacement
You should be able to use any replacement by Nutone. The kit should have finishing rings to install and cover anything from the old one.
Mar 12, 2014 | Broan-NuTone Dryers
I need a replacement motor for a NuTone Model LS-80SE exhaust fan but can't find one.
Home depot usually has a good selection of replacement fans. They usually are a fan on a mounting plate, not just the fan motor itself. Sometimes you have to purchase the entire fan unit just to get the fan motor plate inside for a replacement part.
Feb 23, 2011 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Fan motor does not work.
The replacement motor is available for that fan model. The NuTone part number is the 0696B00. It can be purchase from these sites:
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=qt100l&Search.x=0&Search.y=0
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/0696B000-Motor-Assembly.php
http://www.ventingdirect.com/nutone-0696b000-power-unit-assy-packaged/p431404?y=16&term=0696b000&x=41
Jul 24, 2010 | Broan-NuTone QT100L Fan
I have a nutone 8 amp lo hi off switch keeps tripping breaker and eventually arced at switch . replaced switch and looked for an open or short at connections were I could access . found nothing .tried new...
Sounds like the load is shorted. You don't say what the switch is controlling. What happens if you jump out the switch and just connect the load, then turn on the breaker? If the breaker trips, it's the load itself that's shorted.
May 08, 2017 | Broan-NuTone FAN CONTROL SWITCH
NUTONE HEATER PROBLEM
contact nutone. the problem is that the sensor that shuts off the unit to prevent overheating is too sensitive or faulty. nutone website seems geared towards selling their product so you may have to call them direct at 1-888-336-6157. this is customer support. good luck.6-6157
Mar 03, 2010 | Broan-NuTone N-668RP Combination Light Fan...
Problems with exhaust fan NuTone Model LS 100SE
The fan/motor part of the Broan fan is replaceable. They are actually very simple to take out and install a new part.
The part can be easily purchase here...
http://parts.broan-nutone.com/broan/Shop
Heatman101
Feb 27, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Broan ventilation fan not working
Does it start before the mark as you turn it if so replace the switch. power off first and check with a meter.
Jan 28, 2010 | Broan-NuTone NuTone Ultra Silent...
My fan doesn't start right away when the switch is turned on. Then as it is starting up it squeaks and hesitates. Seems like a "gunked-up" problem but I can't remove the impeller blade assembly from the...
The fan blade can be removed from the shaft. You just need to pop the lock washer off and pry the fan blade. You most likely will not be able to remove the fan blade without damaging the blade. You can buy the replacement fan blades online. The part number is 5901A000. Here is a blog on the entire replacement motor assembly. http://nutoneproducts.typepad.com/nutone-products/2009/08/nutone-0695b000-replacement-bath-fan-motor-for-model-qt80.html
Oct 05, 2009 | Broan-NuTone QT80 Fan
Nutone ls80l motor stopped working
If you remove the motor, which usually isn't to difficult to do. I would recommend plugging it in to one of your electrical outlets to check it. There is a possibility that the wiring is messed up or the plug in the housing went bad. If the motor doesn't work you need a new motor if it does work then you could try replacing the plug in the housing. All these parts are still available.
Here is a motor finder for NuTone motors:
http://www.centralvacuumstores.com/nutone/fan-motor-main.php
Here is the manufacturer you can get parts from them:
http://nutone.com/
Jul 14, 2009 | Broan-NuTone N-LS80L White Polymeric-...
Noisy, smelly fan in nutone heater
You should probably replace the heater motor. All the parts should still be available for you fan and it should only take a few minutes to change out.
Dec 07, 2008 | Broan-NuTone Wall Heater
Broan-NuTone WHV20 Fan Logo
774 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
