Thermal copier i have no idea! i put carbon transfer paper in one slot and original picture in another slot it should copy on to carbon transfer paper, but carbon paper comes out blank.
    Master:
    Sergeant:
  • 462 Answers
Can u try finding out the make and model... it will help a lot... also if u can give any other technicall info..
Thankyou
Posted on Aug 13, 2008
My copier does not print,it gives white paper
Are you getting a error code???? Also, when you put a original on the copy board glass will the scanning lamp turn ON??? You could also have a broken transfer corona wire.... Need a bit more info.
May 06, 2013 | Canon imageRUNNER 5570 Copier
Copy from computer to Sharp ux300
The UX-300 is a fax/copier. It can send and receive faxes over a telephone line and it can make copies of paper documents. It is not designed to connect to a computer.
If you need a manual you may download a copy at
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/PrintersFaxMachines/Manuals/fax_man_ux300.pdf
Apr 23, 2013 | Sharp UX 300 Plain Paper Thermal transfer...
Trying to copy a document, but it only copies 1/4 of page and exits the document. Any suggestions
There is a dirty sensor in the transport of the original document.
The only one solution is to clean the sensors.
Thanks.
Feb 25, 2011 | Sharp FO 1460 Plain Paper Thermal transfer...
The thermal transfer paper tore during process how do I fix it? I removed the cartridge but now the fax paper just sit in tray while the rollers rolls.
Cartridge? There is no print cartridge in a thermal fax. Maybe you removed the thermal print head. Put it back! You simply need to "thread" the fax paper back through the slot that leads to the cutter mechanism. When you close the lid the rollers will pick up the paper and cut off a fresh strip. Locate the long slot for the paper.
Jul 22, 2009 | Brother Office Equipment & Supplies
Will not fax or copy - Given error light
The thermal roll is basically a roll of 'carbon' like paper that is used to transfer the image to your paper (terrible technolgy, and a massive waste of money for the end user....but that's another story)...it likely needs replacing -it's only good for 300-400 pages.
Feb 24, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Machine does not take "grab the document"
probaly you not remove all the paper check again
Jan 30, 2008 | Panasonic KX-FP85 Plain Paper Thermal...
Copy picture
Copy on paper (print a picture) or copy to computer?
Frist thing simply press photo cap and start color ply watch the display!)
Second issue: you need the mfl-pro suite software installed. Windows: Press START/PROG./BROTHER/CONTROL CENTER. Here you can choose the photo cap in diffrent modes.
Nov 03, 2007 | Brother MFC 210C All-In-One InkJet Printer
Copying
You should be able to open the machine up easily and see the jam. It is a very small unit and no plece for the paper to hide. Does the unit use a film ribbon to print from. If so, remove the ribbon to see the jam.
Aug 09, 2007 | Sharp UX P100 Plain Paper Thermal transfer...
How Can I Reprint a Fax?
Here's a trick that I used on the Canon thermal transfer years ago. First take out the thermal transfer unit and roll up the black transfer sheet to the begining of the lost fax. Then reload the paper. Next get a solid black original equal and make a copy. The result you should get a negative copy of the lost fax. Repeat this step until all the faxes are recovered..
May 31, 2007 | Panasonic KX-FC195E Plain Paper Thermal...
51 people viewed this question
jasbo
jasbo
