Master
- Posted on May 11, 2011
Re: I need to pair my bt2050 up to a new phone,it was...
Hi Barbara,
Please follow the below steps, i hope your problem is resolved :-
- Make sure that your phone's blue tooth is out of hidden mode and , it now shows up as shown to all, in the connectivity settings.
- Make sure that you delete the pairing from the other phone , via it's blue tooth settings, if you are not using the phone and it's switched off , then you don't have to worry about it.
- Switch off the bluetooth and restart it , so that it's ready to accept new connections.
- Now go in your blue tooth option and search for a new paired device , it should reflect your Jabra blue tooth.
- If the above method does not work , sadly your phone does not support the Jabra blue tooth.
- You should also try connecting this blue tooth to someone else's nokia phone to check compatibility , if it's compatible with the other models, that means X3 is an exception to this compatibility.
Hope this helps.
