Question about RCA RCU300WBL Remote Control
Programing codes I have a Symphonic tv/vcr combo do you have a code to program the remote
  • bjcookie Nov 07, 2008
    I have a similar problem...I still have the original remote but it doesn't work. I have tried all the universal remotes in the house that I had the codes for but nothing worked. I remember that at one time I had a universal remote that had a separate code for a tv/vcr combo so I have been searching for that info with no luck.
I NEED THE CODES FO JVC.
Posted on Nov 02, 2008
HELP
Need codes for a orion tv with an RCA remote
Posted on Aug 15, 2008
Need to program a symphonic tv with a oneforall remote urc-4021boo
Hello
Setup codes for Symphonic TV with One for all URC 4021 remote control are:
0180, 0171
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY
OK
Jul 26, 2011 | One For All URC-4021 Remote Control
I need the remote code please
Hello
Three digit universal remote code for Syphonic Tv are:-
: 033/ 053/ 189
Four digit universal remote code for Symphonic TV/VCR combo is:-
0227
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Wish You Happy peacefull 2011.
Dec 30, 2010 | Symphonic SC309C 9 in. TV/VCR Combo
Sirs and mesdames: I have a Symphonic TV/VCR COMBO model # TVCRI3E1. The remote control part # (UREMT32SR007) is missing. Where can I find a replacement? Thanks, Ilia Rivera
Hello
Just buy one Philips Universal Remote control Model number [CL 034]. You can synchronise it with your Symphonic Combo by entering one amoung the following codes. Proceedings are also given.
Note: Switch OFF and Switch On your combo, before entering each code.
Three digit codes for Symphonic are:-
033/ 053/ 189
Four digit code for Symphonic TV/VCR combo is:-
0227
Four digit remote codes for Symphonic tv are:-
0053 0189 0227 0456 0024
Four digit codes for Funai are:-
0051 0189 0053 0227 0456 0042
Direct Code Entry
You can also check according to the catelogue of that remote control also. The above given numbers are most common for all universal remote controls. OK.
Dec 24, 2010 | Funai Televison & Video
What is the code for DISH Network remote on a Symphonic SC313E 13 in. TV/VCR Combo?
I hope that you have found the code already, but if not, I am here to help!!! Follow the link below, which will walk you through programing the DISH remote to that tv. Very simple process!!!!
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Becki Barned
DISH Network Customer Service
Sep 03, 2010 | Symphonic SC313D 13 in. TV/VCR Combo
I can't find a code to set the remote for my Symphonic combination TV/DVD tv
Hello, on some of these combinations you might have to try not only the TV codes on your universal remote list, but also the DVD or VCR codes also. One of these three will program your universal remote, but make a note: you may have a partial function on your remote ie: power, but no volume control or channel scan(up/dn) or no number operation(0-9). This happens on some of the universal remotes not all of them. thanks!
Jun 19, 2010 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
In need for remote code number(s)
Yes I have solved my problem. Thank you very much for the help. I came across a web site that gives you the TV codes so I can program my Direct remote.Thank you again.
Mar 31, 2009 | Symphonic SC313D 13 in. TV/VCR Combo
Programming cable channels for emerson tv vcr dvd combo
To see RCA's code list you probably need their website but Emerson is one of several names now owned and built by Funai, who also builds Symphonic & Sylvania.
You might want to try those codes with your set.
Dec 11, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
RCA RCU300WBL Remote Control Logo
185 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
