Question about Refrigerators
My fridge of 3.5 years KitchenAid Model KBRA22KMSS00 all of a sudden is making weird noises as if the compressor is continueously getting turned on and off. Also, I have noticed the freezer is not working properly. All my meats are in half frozen state. I have tried to turn off the fridge for 1 hr and then turn it on again to see if it resolves the issue, and it did not. Any idea as what could be the issue and how I could get it fixed.
  • brokenhill Jan 15, 2009
    my majic chef is 4 yrs old and now the compressor cycle 's on and off and it not cooling ,Freezer not freezing.I blew out the back side of all dust.
    just how do "bridging the thermostat " to check it out.?
  • 29 Answers
If the compressor is turning on and off you will only have partial cooling/freezing at best .if this is what is happening there are only a couple of things that can cause it,firstly listen to the fridge at the rear for an audible click when it turns off,if this is heard it is stopping on klixon overload due to either a faulty overload or faulty compressor,this is a sign of excessive amp draw,the other thing that can cause this is a faulty thermostat,it can be checked by bridging the thermostat resulting in fridge now not turning off and freezing everything,hope this helps
Posted on Aug 13, 2008
Kitchenaid KSCS251 from 2004 suddenly stopped cooling/freezing all interior lights work.
If the previous posts do not solve the problem, these fridges frequently have failures in the control board. The control board is no-longer-available from Kitchenaid however is can be rebuilt at www.fixyourboard.com. The rebuild comes with a 2 year warranty. The turn around time is a few days. The control board may be one of (depending on your full model number): 2252159, 2215946, 2221501, 2221522, 2252071, 2252095, 2252097, 2254739, 1548001, 2223443, 2252111, 2303934, 2307005, 2307028, 8201521, 2304135, W10121049, W10219462, W10219463, W10185291
Aug 07, 2015 | KitchenAid Refrigerators
Strange tapping noise
forget about using youtube try googling it and see if u can get help? not sure but the compressor has a seal that separates the coolant from the oil and when it goes or starts to leak u may get weird sounds? sorry cannot help more Ive heard clicking sounds before from the compressor but it was usually due to bad relay having to do with the starting process
Feb 19, 2015 | KitchenAid Refrigerators
Hi woke up this morning and the divider between the freezer and refridge compartments was very hot. Kitchenaid model ksbp25fkss. opened back panel, and compressor was also very hot. also seemed to be...
if it is making a lot of noise then your compressor is going out, if it is full of dirt dust or debree vacume it, or if you have a air compressor, then blow it out, but unplug your fridge to let the compressor cool down, if it is cold outside and you can wheel it there with no problem then you can clean it . you might have a freon leak or a stuck valve let it get cooled off and try again
Dec 12, 2010 | KitchenAid KSBP25FKSS Side by Side...
Kitchenaid Refrigerator
Built in KitchenAid means your fridge is in the price range of $ 10,000/=.
Most likely the compressor and condenser on the top of the fridge. That is why you get the ringing noise. May be compressor not starting properly. Starting device issue or compressor seized.
Shut off the fridge and call a local service guy or Whirlpool Corporation. No time to test this and that. Your fridge worth $ 10,000/=. Don't be penny wise and pound foolish.
Oct 24, 2017 | KitchenAid Refrigerators
Kitchenaid Side by Side Refrigerator minus the cold air?
your compressor has issues. some times the start relay goes bad or the compressor windings are shot. thats why it clicks on then off .a service tech can install a "3-n-1 hard start on it. sometimes that works. good luck
Dec 10, 2009 | Washing Machines
Model kbr20etss01 very noisy when compressor is running
If the noise seems to be coming from the compressor That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Also you have two fans which run when the compressor runs. One is next to the compressor and the other is behind the rear cover inside the freezer. One of them can be hitting something or the fan motor itself could be making the noise which would be a bad motor.
Oct 20, 2009 | KitchenAid Refrigerators
Motor continuously runs.
What you describe sounds like the fridge is not making temperature for the thermostat to shut off. What number is the thermostat on? 0-6 usually a setting of 3 or 4 will do. Try turning the thermostat down to 1 to test it, does the compressor stop? Place a thermometer in the fridge for an hour with the thermostat on 4 and keep the door shut, if it doesn't get below 7'C (1)Check your door seal is clean and seals all the way round when you shut the door. (2)The cold element is frosted up and can't work properly-defrost the fridge. (3)If your sure the compressor is rotating then your fridge requires regassing, although this means potentially there is a leak and no guarantee can be placed on how long this will last.(mine was 5 years between gassing)
Aug 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
KitchenAid Side by Side
if you hear a clicking like the compressor is trying to start, like a clicking on and off this sounds like it could be your start run relay trying to kick your compressor on. if this is bad it will continue to click, and your compressor won't start. unless your mechanically inclined this might be the time to call a service tech. the start run relay switch sits on the compressor behind the fridge.
Mar 12, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerators Logo
137 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
