I have a thermal copier machine used for tattoo transfers i have no idea what make it is,all it has written on the side of it 928 series, i am having problems with transfering the original picture to the transfer paper, transfer paper comes out blank?
  • 876 Answers
It must not be heating. I believe they are made in China, but I had no luck finding a contact. You might check with the company that supplies you with other tattoo equipment. Just FYI There are some thermal tattoo copiers listed on ebay.
Posted on Aug 13, 2008
  • Gayle Ashbach
    Gayle Ashbach Aug 15, 2008
    Has your problem been solved? Is there anything else we can do?
  • 928 Answers
Actually this is basically a heat press much like transfering Tshirts or Mugs. May I ask if you have the correct type of transfer paper? Have you used this before? If not you may need to purchase the correct type of thermal paper.
Link1
  • Thomas Lim
    Thomas Lim Aug 13, 2008
    When i say much like a Tshirt on Mug i mean not literally with a directly applied heat. Just same principle.
  • Thomas Lim
    Sort of like a carbon paper type thing only the heating element is what transfers it instead of directly applied pressure.
    This devices works by putting your sketch on top of the thermal paper then feeding it into the device wherby transferring the sketch onto the paper that you can now apply onto skin to have the outline that you need. So if you are not using the correct paper then its not gonna work.
    Master:
    Sergeant:
  • 462 Answers
On what basis does it copy on... does it use a cartridge ink or drum or laser...
Need help with a 928 thermal copier does anyone know where I can send it to be repaired?
In general if a machine is a few years old, repairs cost more than a new machine. It seems this model is no longer available.
May 07, 2014 | Office Equipment & Supplies
928 series thermal printer is leaving streaks
Umm you need to make sure that the ink cartridge is not busted because that could of getting on another part which is causing the streaks
Feb 24, 2013 | Office Equipment & Supplies
How can i remove my tattoo?
there are products such as wrecking balm that claim to remove the tattoo but results vary, it may only made it very faded. if you want to do it professionally, you can have it burned off with a laser
Jan 13, 2013 | Medical
I dont know how to wire it
I hope it can help you: How to Wrap Coils for tattoo machines parts
http://www.ehow.com/how_7693710_build-tattoo-machine-coils.html
Oct 19, 2011 | ART Cast Iron Coil Tattoo Machine Liner &...
Hi, i have a TLP 2844 printer Thermal, but i cant print labels. I have read the manual and follow the instructions. Every time i put labels on the printer, only send me blanks. Can you help me, please
Are you trying to print in thermal or thermal transfer mode? If thermal transfer mode, do you have the ribbon install correctly with the coated side facing towards the label? If using thermal mode, are you using thermal paper and are you trying to print on the coated side? Hold the feed button down and turn the printer on. Hold it down until the light stops flashing. At this point the printer will print a diagnostic dump. If nothing prints then either you have the media loaded wrong or something else is wrong with the printer.
Jul 19, 2011 | Zebra LP 2844 Thermal Printer
When i try print the label..no output at the label..how to test whether the ink is function or not
I'm including this link to the users manual:
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
But here is the basic troubleshooting info for that issue
No print on the label.The media may not be direct thermal media when printing without ribbon (i.e. thermal
transfer). See the test procedure
Determining Thermal Media Types on page 29.
• For thermal transfer printers, the media may not be outside wound or approved for use in
the G-Series printer. See the following ribbon test procedures: Ribbon Test with Adhesive
on page 32
and Ribbon Scratch Test on page 33.
• Is the media loaded correctly? Follow the instructions for
Loading Roll Media on page 11
in the Getting Started section. For printing using transfer ribbon, see
Loading Transfer Ribbon
on page 14.
Mar 28, 2011 | Zebra GK420t thermal transfer and thermal...
Hi! I have bought a Philips Magic 5 Serie PPf685.
Manual is here: http://support.sagem-communications.com/site/modele_fax.php?page=livret&prd=PhilipsMagic5VoiceDECT&pays=uk
Apr 10, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
Can you use thermal transfer paper
The paper will probably come out black after being heated by the fuser. 350 degrees.
Jun 07, 2008 | Brother IntelliFAX 885MC Plain Paper...
316 people viewed this question
jasbo
jasbo
