Question about Cameras
Lens error 111,0,0,0 - Cameras
    Master:
    Sergeant:
  • 462 Answers
Please give us ur complete camera details as well as date of purchase..
Thankyou
Posted on Aug 13, 2008
4 Suggested Answers
  • 11967 Answers
SOURCE: kodak easyshare c182 lens error 111
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 13, 2010
lock123
  • 6831 Answers
SOURCE: Kodak Easyshare CD82 lens error 111
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 09, 2011
lock123
  • 6831 Answers
SOURCE: lens does not open fully has "lens error
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Regards
Posted on Mar 03, 2011
Lens error 111
ALSO, please see this link for further troubleshooting steps for a lens error.
May 01, 2013 | Kodak Easyshare C813 Digital Camera
Dropped camera in sand...
Your best bet is to just open it up and try and blow the sand out but you will want to be very careful.
Hope this helps.
Thanks,
Lee
Jul 15, 2008 | Kodak EasyShare C743 Digital Camera
I have a kodak easyshare cd82 camera an it keeps saying error 117. how do i fix it?
clean the lens guide like. USe compressed air on the lens body, tap the lens face down position and then turn on and see the result.
Aug 12, 2012 | Kodak Easyshare CD82 Digital Camera
When i try to turn my camera on it sounds like its going to turn on but it stops and gives me the message on the screen Lens error 111. then it shuts off. I've been messing with it and i can get it to...
Often times a lens error comes up when the lens extension/focus mechanism has been jammed. It may almost fully function, but then the gears run into a small spot where those tiny gears are jammed, broken, have debris on them, etc. When the motor hits unexpected resistance, the camera kicks back the lens error code and shuts down before it does further damage to itself. Make sure there isn't anything wedged between where the pieces of the lens slide past each other. Past that, the best solution I can offer is to look on ebay... most cameras either die because the lens mechanism breaks, or because the LCD screen breaks. If you can find a donor camera with a bad screen, you can combine the best of both at a pretty reasonable price. These cameras are quite complicated to transplant, but fortunately most lens mechanisms and sensors are a full unit of themselves, and so are the lcd screens. Before investing in the donor camera, take yours apart and see how difficult it appears to be to work on it. Then make your decision. Good luck!
Aug 13, 2011 | Cameras
The camera says lens error 111 what do i do to turn it on
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth a try.
May 27, 2011 | Kodak Easyshare C813 Digital Camera
Error 111 what the ****
It is Lens open time out error. Your camera lens is jammed or bent. Try re loading battery. If not resolved go to service centre.
Dec 24, 2010 | Kodak EasyShare CX7530 Digital Camera
How do i fix the lens error 111?
for me when i was getting the lens error 111, the lens shutters were set crooked and was able to move them slightly and the error went away and the camera works fine now.
Nov 01, 2010 | Kodak Easyshare CD82 Digital Camera
Lens error 111
thats ok... but i will need other details like the make and model as well as date and place of purchase please...
Thankyou
Aug 13, 2008 | Kodak EasyShare C633 Digital Camera
Cameras Logo
50 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
