Question about Canon Office Equipment & Supplies
The printer says it has the wrong cartridge but it is the correct one and will not print.
    Sergeant:
    Champion:
  • 246 Answers
Please check whether the correct model number with your old cartridge
IF it is ok
Please reinstall the printer Driver
Posted on Aug 13, 2008
SOURCE:
My HPLJ3500 Color Printer wont print black even tho we just put in a new cartridge. Prints magenta, cyan, yellow, but no black. HELP!
Run the PQ troubleshooting diagnostic.
See if the black is printing.
If not, run the Disable Cartridge check. This will allow you print with only one cartridge in the printer. Take out all the cartridges. Put the black in another slot and put the cyan in the black slot(the top). Print the config page. If the black is printing, is the cyan printing. If black isn't printing the cartridge is bad. If black is printing and cyan isn't something is wrong with the printer. If they are both printing put them back in the correct locations along with the other two colors. It isn't the printer.
Jan 11, 2011 | HP Color Laserjet 3550 Printer
Printer won't print, message says ''wrong cartridge'' I have the correct cartridges installed and it still will not print.
Would I be correct in thinking that you have just changed the cartidge?
If so, then remove the cartridge and check that you have removed all the transit seals that are fitted to prevent leakage in transit.
Mar 15, 2010 | Canon Office Equipment & Supplies
Printer 5510
If you use your printer occasionally, it might be that the print head on the cartridges is clogged. I don't know what was serviced, but if your cartridges haven't been printing for a while, that is surely your problem. You can try this:
  1. Try cleaning the print cartridge from the Maintenance utility by following the steps below:
    1. On the all-in-one front panel, press Setup (or Menu) repeatedly until "Maintenance " displays, then press Enter .
    2. When "Clean Cartridges " displays, press Enter .
    3. At the end of the cartridge cleaning cycle, a page will print. Examine the page to determine if the problem is corrected.
  2. If the problem still exists, clean the cartridge following the directions below in the "Clean under the cartridges and the carriage " section below.
  3. Verify that the ink cartridge is not low on ink by checking the estimated ink levels as indicated in the "Colors on printout are wrong or fade in and out while printing " section above.
  4. Replace the print cartridge for the color that is not printing correctly.
Mar 05, 2010 | HP 5510 4-in-one Printer
Printer doesnt want to print
Is it a genuine Lexmark cartridge? They are sometimes partial to their own products.
Oct 13, 2009 | Lexmark X7350 All-In-One InkJet Printer
Printer keeps flashing wrong cartridge with correct cartridges
make sure all in correct. Clean sensors and cartridges then delete and reload driver. if this does not correct issue, then you have a faulty cartridge
Oct 10, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
When the printer prints the colours come out all wrong
If the cyan, magenta and yellow blocks print correctly on the self test page but on pages from the computer then I woukld suspect a driver issue.
else
I would suspect the cartridge has run out of magenta ink. Try printing a diagnostic page.If the colors are "wrong" on this test then your cartridge is most likely the issue.
Sep 23, 2009 | Epson Stylus RX500 All-In-One InkJet...
Hp 110 ( cb304A ) some of these cartridges they print colours wrong, let's say instead of Cyan/Magenta/Yellow they print it backwards Y/M/C WHY?
if you have refilled the cartridge, then it shows that cartridges are not refilled in correct order.
change the cartridge
Sep 16, 2009 | HP Photosmart A526 photo printer
No print on Canon Pixma MP150
it is problem your printer black cartridge .Black cartridge is signal E 5 color cartridge is E6.please change it you buy a new original cartridge
black ink cartridge chip is demage
Jul 20, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Wrong cartridge?
Doubled check the cartridge numbers and that they match what is on the printer. If no match get correct ones.
Oct 24, 2008 | HP PSC 1410v All-in-One Printer
Printer message: Wrong print cartridge
Have any of you tried to uninstall and reinstall the printer? It's possible something this simple might just solve your problem. Let us know.
Aug 16, 2008 | HP PSC 1315 All-In-One InkJet Printer
Open Questions:
Clive
Clive
old marine
old marine
Ekse
