Question about Philips HTS3450 System
No Sound I have the same problem everyone seems to be having and as recommended I bought the 470uF/35Vcapacitors but I am unsure which ones to change as there are lots of capacitors.If you could direct me to the correct one to change. Thanks P
  • jutterback Mar 25, 2009
    I have the same no sound problem, which cap number do you change? C905 and 906 or C913 and 914? do you use 20 V vs 16 V for the loss of sound after fix? what Radio shackk part number is working best? Electolytic or Ceramic?
    Thanks for the advise!
You are probably actually looking for two 16v capacitors, not 25v. They are either black or brown near the huge copper coil magnet capacitor at the end of the board. A thin, tall metal heatsink sits between it and the copper coil capacitor. Philips is notorious for their completely worthless stereo systems, so they probably knew about the problem with the capacitors and put in 25v for later versions of the hts3450.
Posted on Dec 10, 2008
No sound, just a Buzzzzzzzzzzzzzzzzzzzzzzzzzzz!!!!!!
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will probably last forever now.
Jul 06, 2009 | Philips HTS3450 System
HTS3450 - Replaced Capacitors now have sound back but is very low
The new capacitors have a lot more value than the factory ones. Because of the higher value the amplifier will have to give it all it's got and mostlikely not live for too long (see first comment).
Replace the replaced capacitors with ones of the correct value and your problem is solved. You can use ones with a slightly higher vlaue (20v iso 16v) but it will also produce less louder sound.
Dec 10, 2008 | Philips HTS3450 System
Philips HTS3455/98 System "NO SOUND" PlZ Help!!
There are two capacitors on the power board that are 470uf/35v. go to Radioshack and buy two catalog #272-1030 470uf/35v radial lead capacitors. if you have soldering wick and a soldering iron, then this will cost you under $3.00. when you remove them, the capacitors have a white strip with a negative sign on it. match this up with the shaded area on the board. put it back together, and it will work, and last a long time. I have this same system, and it wouldn't play any sound. so, I replaced the capacitors. Hope this helps!0ccab8c.jpg
Nov 30, 2008 | Philips HTS3450 System
Phillisp HTS3450
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will proibably last forever now.
Jul 06, 2008 | Philips HTS3450 System
I bought philips 5.1 home theatre for PC it is not supporting
Jul 02, 2008 | Philips HTS3450 System
Philips HTS3450 sound problem
Jun 09, 2008 | Philips HTS3450 System
Won't power up
May 10, 2008 | Philips HTS3450 System
No SOund from the HTS3450
Apr 20, 2008 | Philips HTS3450 System
No Sound HTS3450
There are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. As far as installation instructions go; you have to have some soldering experience, first. You will also need some type of de-soldering device, be it a solder ****** or solder wick to remove the caps. Make note of the polarity before removing. Then it is just a matter of popping the new ones in (they are slightly larger than the originals so they might not go all the way down flush with the PCB) and soldering them back in. Make sure you do not make any solder shorts or your system will be toast! Your unit will be as good as new and will probably last forever now.
Philips HTS3450 System Problem buzzing/clicking sound on startup. Now nothing.
Apr 06, 2008 | Philips HTS3450 System
Philips HTS3450 System Logo
249 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
