Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Picture behind a square
I was turning tv off by its remote and instead of turning off it put a large square ontop of picture except the right and left side of the screen you can see 1 inch top to bottom.parental locks are off,closed caption is off,is there a way to reset all setings back to factory? when i view menu the box is not there.
  • 138 Answers
The problem is the close caption turn it off again and when the square leave turn the set off.
Posted on Aug 19, 2008
SOURCE:
I keep getting a black square in the middle of the picture. The sound stays on and the picture is behind the black square. How do I get rid of the black square for good
This is a caption for hearing impaired, grab remote! scroll down to captions, use right arrow 1,2,3,off when the cursor is flashing over the " off " press enter on the remote, that should restore the set. Some remotes have the captions on a separate button.
Mar 11, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
Have re-booted, re-synced numerous times, held red button simultaneously, one at a time, etc. Everything with the remote works except the cursor. Can move to the right and left by using the +/- buttons,...
Your sensor bar is messed up a replacement on ebay is less then $6. Your controllers arent the problems. Also do you have the sensor bar ontop or bottom of your tv? Theres a setting on the wii to change the sensor bar from top or bottom of the tv depending on where youve put it. 99% sure its a bad sensor bar though.
Nov 25, 2010 | Nintendo Wii Console
My lg 42PQ3000 has a problem. The picture just dissapeared this afternoon but the sound continued. The remote control doesn't work except for the power button and when I try the buttons on the actual tv...
Try unplugging the power and then holding down the power button for a few seconds either on the remote or tv. I think this will reset the lcd tv. Tell me if this works.
-Ben
Jun 18, 2010 | Televison & Video
I left my tv on when I went to bed and the picture was fine. Then I woke up and turned it off. When I came home and turned it back on, the picture was blurry all around the tv except in the middle of the...
is the blurry all around the picture have different color like a smear of red, blue or yellow?
if it is i think the posistor of your tv is not working. it is the one who activate the degaussing coil around the picture tube the prevent color miss-landing upon opening your tv set.
Aug 11, 2009 | Samsung SlimFit TX-S3082WH 30" TV
A grey square in the top left corner
This TV dose have PIP (Picture in Picture), Press the PIP button on the remote and see what happens. If fail then I would recommend to call Viewsonic.
Apr 26, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Our 32'' JVC TV model # AV-32030 has an obscured picture.
With the remote go to the Closed Caption menu and make sure it is turned off.
Let me know if this helps
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Apr 03, 2009 | JVC AV-32020 32" TV
Mitsubishi 1995 cs31205 32 inch tv
Good Day;
Sounds like you have the TV in the "close caption " mode (text), turn off. 2. Check batteries and the mode the remote is in; eg TV, VCR, Cable & ect. Good Luck, big IRISH.
Oct 05, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Black screen
I have a Sharp Tv that had the same problem with a large brownish or black square right in the middle of the screen. It only left about an inch around the edges that you
could see the picture moving in behind the big black block or square.I have DISH sat-elite and the book recomending that I check and see if the "caption settings" were on
or off. They were on. I turned the caption settings off and the large square diappeared.
Nov 18, 2007 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Orion standard tv
Have you had any kind of magnets close to the tv set? I had a brand new sanyo do the same thing. I had pulled the speaker box out of my truck and stood it up next to the tv (not thinking about where I put it). Turned it on a few hours later only to see a messed up picture. I moved the speaker box to get behind the tv and the picture got better. Moved the speaker box back to the truck and after a couple of days the picture was back to normal. These were 4 large magnets on these speakers. Maybe I helped some!
Mar 08, 2007 | Orion STV2763 27" TV
Black Square Covers 80% of screen on most channels on TV
have your tv checked by a tech.probably your chip the eprom needs to be reset by lifting it up from the board and resolder back.some one could have put in a code for those channel.good luck.
Dec 27, 2006 | Toshiba CF35E50 35" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
