Question about HP PhotoSmart 7350 InkJet Printer
Printer only prints top line of document (hp photosmart 7150)
Hi. my friend just gave me his photosmart printer and i hooked it up to my laptop. Seems to work just fine, I printed a picture. When i tried to print a document, it only printed the top line, continued like it was printing the rest of the page, but it was blank when it came out. This happened on the test page and a regular document. What could be the problem??
thanks.
  • 1 more comment
  • r_campos79 Aug 13, 2008
    according to my friend, he just replaced both not very long ago and has little use on them. could it be that since he hasn't used the printer in a while the cartridge is clogged? i tried to do a cleaning, but i couldn't find that option.
    hmmm...i don't see services. I have windows vista, does that matter?
  • Anonymous Mar 22, 2014
    D2680 printer prints test page but no documents
  • 876 Answers
Is the black cartridge full?
Posted on Aug 13, 2008
  • Gayle Ashbach
    Gayle Ashbach Aug 13, 2008
    You can go to
    Control Panel
    Printers and faxes
    Choose your printer
    Right click on it
    choose preferences
    choose services
    Now you will see the options for cleaning your cartridge and testing them. I hope this helps. If not let me know!
SOURCE:
Hp photosmart C7250 hangs while printing
Hi Georgette,
You have tried your best with possible troubleshooting to fix the issue. There are few possible workaround solution for this issue.
First, If the USB Cable is more than 3-5 ft long, it could be the reason. Also, if the USB Cable is worn out or is broken in-between.
2nd, The printer does not seems to accept command from PC ( win 7 ) using the HP Software. So Uninstall the Software. Restart the PC.
Do not install Printer Software. Connect the Printer USB to PC and Windows 7 will display new hardware detected message.
Continue with the New Hardware Found Wizard and install the drivers it will list by Default.
Try to print and it should work.
If this works, You will be able to print without any problems however if you want to scan a document, you need to use Applications like MS-Paint, Microsoft Word etc, or Use the Scanners and Camera option in Control panel.
You can then install the software disk of printer or the downloaded software from Hp website to install Printer software for SCanning.
If you do so, you will find 2 printer icons in Printers Folder. First one will be with WSD text ( this icon is created when you connect the printer using USB without installing the printer software ) and 2nd icon will be HP Photosmart C7200 All in One ( this will be the Software installed ) and this will be default icon with check mark.
Whenever you want to print from any application, You need to click on File - Print - choose the WSD icon to print.
Regards,
Sean S
Sep 19, 2012 | HP Photosmart C7250 All-In-One Thermal...
I am having printing problems w/ a HP photosmart. I uninstall and reinstalled the printer. when tried printing a test page, this came out blank. then tried printing a document (a few lines) but it too...
Hi Cally pls. visit this website and choose the type of operating system that you use. It will show you the step by step procedure on how to rectify your problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01892627&cc=us&lc=en&dlc=en&product=3192753&tmp_track_link=ot_search#N46
Mar 06, 2011 | HP Photosmart C4280 All-in-One InkJet...
My printer prints triple everything photosmart 7150
In the properties of the printer on your computer, you probably have it set to 3 copies. Go to devices and printers and open up the printer properties. Probably under the "advanced tab" you will find a setting for number of copies. Let me know if you are having problems finding the printer properties.
Jan 21, 2010 | HP PhotoSmart 7150 InkJet Printer
HP 7150 Printer
since you hav a AMD., try using a USB hub and try printing. coz AMD sends the data to the printer very fast.
this is a known issue with lexmark printers.
Sep 22, 2009 | HP PhotoSmart 7150 InkJet Printer
Unable to print from laptop to HP Photosmart C3188
Did you try adding the printer using Administrator privs? Just go to the Control Panel > Printers > Run As Administrator > Add Printer. This process gave me access to the network printer. Unfortunately, MS Word will not work at all if the network printer is setup as the default and not added by the administrator.
May 01, 2009 | HP Photosmart C3180 All-In-One InkJet...
Only prints on one side
Hi, You have to remove the Catdriges from the printer and clean both catdriges and the roller. This might sort your problem. Secondly before printing check the pagesetup of the particular file.
Mar 09, 2009 | HP PhotoSmart 7150 InkJet Printer
CANNOT HOOKUP PRINTER , LOST CD
Here is a link to HP's website where you can download the drivers and software needed. Just select your operating system first...
HP Photosmart 7150
Nov 24, 2008 | HP PhotoSmart 7150 InkJet Printer
Windows does not recognize usb device
Probably broke a solder point. Need to take in for repair, or find a friend who is an electrician.
Note: Needs to use low heat solder.
May 20, 2008 | HP PhotoSmart 7150 InkJet Printer
HP PhotoSmart 7350 InkJet Printer Logo
1,323 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
