Computers & Internet Logo
Posted on May 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Indicates chassis open when booting up - Computers & Internet
Anonymous
Level 3:
  • Computers & ... Master 32,281 Answers
  • Posted on May 11, 2011
Anonymous
Level 3:
Answers
32281
Questions
Helped
7913169
Points
102259
When the desktop case has been opened there is this notification when the computer boots up.
You can remove this message by going into the BIOS configuration and resetting this notification, this message will not appear again until the case has been opened again next time.
I have a dell and it said that i had a chassis intrusion I dont know what it means nor what to do help
That just means the case of the desktop was opened by someone.
http://phubner.eng.ua.edu/Files/Optiplex%20GX620/advfeat0.htm#wp1124663
Security Chassis Intrusion Detection note.gif NOTE: When the administrator password is enabled, you must know the administrator password before you can reset the Chassis Intrusion setting. This feature, if installed and enabled, detects that the chassis was opened and alerts the user. To change the Chassis Intrusion setting:
  1. Enter system setup.
  2. Press the down-arrow keys to move to the System Security option.
  3. Press <Enter> to access the System Security option's pop-up menu.
  4. Press the down-arrow key to move to the Chassis Intrusion setting.
  5. Press <Enter> to select an option setting.
  6. Press <Enter> again after you update the option setting.
  7. Exit and save system setup.
Option Settings
  • On - If the computer cover is opened, the setting changes to Detected, and the following alert message displays during the boot routine at the next computer start-up:
Alert! Cover was previously removed.
To reset the Detected setting, enter system setup. In the Chassis Intrusion option, press the left- or right-arrow key to select Reset, and then choose On, On-Silent, or Off.
  • On-Silent (default setting) - If the computer cover is opened, the setting changes to Detected. No alert message appears during the boot sequence at the next computer start-up.
  • Off - No intrusion monitoring occurs and no messages appear.
Asus motherboard shows this error on boot: Chassis intruded! Fatal error...System Halted I do not know what seems to be the problem is. Is my motherboard going bad? Could it be one of the attached...
Some computers will have a sensor to indicate that your chassis(case) is open. This sensor can get stuck sometimes and you will need to enter BIOS (setup) and reset it. You should be able to disable this feature in BIOS also and I would as it's not really useful other than having the chassis open and screw up the airflow and raise the temp of the computer internals.
Comment if you need further assistance
2helpful
The system intruded.chassis opened or tempered before please check the system. what shall i do ?
When you open the computer case, a switch is tripped and after the case has been closed and the computer boots up, you get this chassis intruded message.
To clear this message go to the BIOS configuration and then to the chassis intruder detect and then Reset this setting.
1helpful
Open chassis warning fixed by SteveS1013
You have to disable the chassis intrusion alarm by going into the BIOS as the machine first starts up, either by pressing Esc or Del, in the BIOS you can then disable the alarm.
Regards.
2answers
Chassis Intruded
clear your bios, close very good your case, open bios disable chasisis open detected fro yes to no, (or in some model from enable to disable ) change saves exit booting and good work.
Error msg "The system chassis was opened" how to continue booting
firstly, you have to close the side panel after install any component. if the message show you again, try to find and short connect the jump (2 pins, signed Chassis) on your mainboard.
20helpful
3answers
Strange message saying "Warning! Your chassis has been opened!"
  1. Hit DEL when booting to get into the BIOS
  2. Choose PC Health function
  3. The first item is the chassis open function - hit Enter to change it to Clear.
  4. F10 to exit and save the change
  5. Reboot
  6. GO into the BIOS again and this time select Disable for the chassis opened function
  7. F10 to save and exit
  8. Done.
Problem at boot
There is a mechanical switch connector available to determine if someone has opened the chassis.
You can bypass this through the BIOS by entering the BIOS on bootup (DEL? message at bootup? F1?) then look for the system chassis intruder alarm and DISABLE
Another option is to find the pins that the switch is supposed to be connected to (documentation on the ASUS P4B motherboard) and jumper them.
Problem at boot
plz disable the chassis open warning option in the bios.
Grand Canyon Tech
Grand Canyon Tech
