Question about Polaroid 15'' HDTV Monitor FLM-1511
TV won't turn on
Hi, I have a 32" Panansonic Viera LCD TV and last night I think it got affected by a power surge resulting from a lightening strike to the house/ area (could have been through the ariel socket or power).
Now it won't turn on at all. Is it completely ruined? Being an Australian TV it doesn't have a fuse in the plug socket, so it's not a cable fault.
Could it just be an internal fuse or failsafe of somekind that has blown - in which case is it easy to repair?
It was a very expensive purchase, I'm hoping it wouldn't get destroyed that easily.
lightning strike fried our computer, air condiioning, sump pump, etc. My
year old polaroid 1511 won't turn on. Is there a fuse inside that can be fixed or is it totally gone? Thanks, Marie
  • CEL-GAL Aug 14, 2008
    Thankyou very much for your promptness and thoroughness of
    your answer. I really appreciate your help and I am inclined to think that it is probably not salvageable. Marie
    Problem Solver:
  • 7 Answers
I agree with the previously posted comment but there is still some hope.I have fixed thousands of lightning damaged sets and a fair percentage aren't too bad.This repair needs a meter and some familiarity with basic electronics-it is NOT for the completely unskilled or faint of heart.UNPLUG the set-can't say that emphatically enough.Trace the wires leading from the AC cord input to the board they attach to.Most boards have markings and a fuse(f1,f2-etc)will probably be nearby,There will probably be a bridge rectifier,frequently mounted nearby,frequently screwed or clipped to a heat sink.Remove the board from the set if needed(probably will be)and check the fuse.If it measures open circuit it is bad.Measure across all combinations of the 4 legs of the bridge rectifier.If any measure shorted or low it is probably bad.If it appears bad remove it from the board and remeasure.If still measures low it IS bad.Replace rectifier and fuse.and test the tv.If the fuse pops and/or it still won't come on it will probably take substantial skill to locate remaining problems.I would give this about a 20% chance of working,but if you have enough skill to go this far it has a chance and won't cost much.If the parts are bad post a question about getting them and I'll try to help or check listed parts sources on this site for getting them.
Posted on Sep 03, 2008
    President:
  • 173 Answers
Hello Marie,
I am sorry to hear about your situation. Most tv's do have an internal fuse, so if you open the chassis (which is the back part of the tv and slide it out and away from your circuit boards) the fuse will be located where the cord comes into the circuit board. Look for burnt or scorched spots on your circuit board also while you have the back off. I am sorry to say that most often than not in cases of lightning strikes the damage is expensive to repair and replacement of the devices is usually cheaper. Since the strike got a lot of your devices, it is not looking good. If you have further questions or need more assistance please let me know and I will be more than happy to help.
If you do not mind please rate my help, I would appreciate it. Thanks
Posted on Aug 13, 2008
Sony bravia lcd won't power on after lightning strike
I am sure the tv is shot from the surge but you can check a few things. I would take the tv apart and test the power supply first. Look for obvious burn damage throughout the boards. If there is a blackened one (prob video board) then you can try to replace that. Don't worry about taking this apart and breaking it further. In this case it can only get better for you.
Oct 06, 2012 | Sony BRAVIA KDL-46EX400 46" LCD TV
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
Jul 05, 2012 | LG 55 55LW5600 3D LCD TV
Panasonic Viera TH-50PX80A. After lighting strike, inputs do not work.
The set MAY have a hard reset but you would have to call Panasonic to find out.
What happens with lightening strikes is RF gets into the set in two ways--via the power cord (usually a dead set is the result) and via the coax or cable fitting.
It sounds like it was the latter--it may have confused the microprocessor in the set(input issues) so unplugging set and or a box if used (receiver unit also!) may or may not help.
Surge protectors rarely operate quickly enough to stop this and even if the cable feed is protected stray RF can get past that also.
try my suggestions and then call Panasonic.
May 17, 2012 | Televison & Video
Is it ok to turn a Toshiba LCD TV off at the power point to save a little electricity? We have a circuit breaker adapter board which runs 5 red LED's at night (TV, DVD player, sterio, surround sound...
Yes its fine to turn the power off at the power point. In fact this saves money because there is no idle appliance power drain. It is also a safe practice to disconnect the power at night or over longer periods of inactivity because there have been instances where plasmas in particular have caught on fire. Turning the power off will not affect your friends LCD TV they are designed and built by engineers who incorporate power surge protection. The circuit breaker should be one of very good quality and if this is the case then your friends LCD will be fine.
Jul 12, 2011 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
After a lightening strike hit our house, our Panasonic Viera powers on but does not have a picture or volume. The best buy geek squad set the TV up but did not plug into a surge protector. Is the TV...
i would say there is a good chance that the power board has fried , or some rectifiers on the power circuit have gone, i would check the mosfets for damage too. I would try a working power board in it to see if any life is shown before writing it off
Mar 26, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Sanyo dp32648 possible lighting strike, whats needed to fix and a possible cost an can i repair myself?
It wont turn on? Well if it is damaged by lightning the only thing damaged would be the varactors on the power supply. They are there to absorb tremendous surge of electricity. The same way a surge protector works. A worse case scenario is the power supply board is fried up. Then being a non electronic technician you can purchase the whole board or order on line and install them yourself. If you brought it to a shop they will charged you for the labor and the board. Don't buy used boards on the internet because a lot of them are no good in my own experience. Get a new one for about a little over a hundred buck or so.
Jun 26, 2010 | Sanyo DP32648 32 in. LCD TV
Bright white screen with faint images
If lighting did strike, you would be suffering power supply problems, due to a power surge from the strike.
The problem sounds like it could be related to the LCD panel becoming faulty or if your able to test inside the unit with a multimeter, you can measure the voltages from the printed circuit boards, especisly those suppling power to the LCD panel as well as the Logic PCB, A small printed circuit board you will find either attatched to the LCD panel. I hope this helps.
Good luck.
Jun 07, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Killed by lightning, have power, no picture...
The warranty does not cover lightning, check if your insurance covers it.
A lightning strike on such panel ( HDMI ) is very difficult to repair and if not impossible.The HDMI connector is hooked to the ground of the TV set so everything could be damaged.
My advice is not to repair.
Aug 10, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
We had a near lightning strike and now my tv (sanyo model ht27744)doesn't want to come on.
Lightening may have caused a surge on your power lines to the house and to the outlet the TV was on.
Do other things work on that outlet? If not you tripped a power breaker.If they do work check this.
Unplug the TV for 2 min or more and plug back in.
Try bypassing your surge protector you had it plugged into. It could have died when the lightening struck.
(no surge protector?) Bet you'll buy one for your next TV.
Look for 3000 joules and up rating for a surge protector and insure it has protection for a cable/antenna input too.
If this doesn't work the TV may be fried or internal fuse blown.
Time to take it to a repair shop or depending on it's age (5 years+) it may be time to buy a new TV and surge protector.
Near Lightening strikes can effect appliances from several inputs that could be affected from outside like Power, Cable, Antennas, Phone Lines that come into your house.
Jul 06, 2009 | Sanyo Televison & Video
Lightning affected Lcd tv
Panasonic 32"LCD Mod,TX32LXD70A
Jan 02, 2009 | Panasonic Televison & Video
Polaroid 15'' HDTV Monitor FLM-1511 Logo
238 people viewed this question
Top Polaroid Computers & Internet Experts
Larry Maranto
micky dee
Tom Chichester
Are you a Polaroid Computer and Internet Expert? Answer questions, earn points and help others
