Question about Micro Electronics WinBook Si Notebook
How to Open a Winbook Si Laptop
Bernie ...
How did you get the dang case open? I'm trying to get at the internal keyboard connectors.
Thanks in advance.
  • jcohen339 Sep 22, 2008
    Same problem! Please help.
The keyboard is fairly easy to get off. At the top there is a plate that covers the switches; on the left there is a tiny hole that you use a paper clip to push down gently and unlock a catch (like on a CD-ROM drive door). While gently pushing down, slide the entire cover to the right, and then lift it out. This will loosen the top edge of the keyboard; lift from the top edge and push toward the screen, and the tabs at the bottom edge will slide out of their sockets. The keyboard mylar flat cable will have some sticky stuff on it, so be careful when lifting the keyboard not to tear the keyboard cable.
Once you get the keyboard off, you can also remove the CD-ROM drive (two screws, silver and black).
To get at the hard drive, which comes out of the top of the case, from under the keyboard palm rest, you take out the battery, and the three screws on the bottom side of the case nearest the front edge. Then you can pop off the black keyboard palm rest below the keyboard. Be careful to not damage the cable connecting the touchpad to the mobo; it has a little plastic connector. The HD has three screws holding it in, including one on the adapter that attaches the IDE connector to the mobo.
Hope that helps
Posted on Nov 06, 2008
  • KeithV Nov 06, 2008
    BTW, sorry I couldn't answer in time for the first two posters, but I just discovered this thread myself and I found out the above information by trial and error, so I decided to share my experience. Hope it helps future searchers.
Replacing dvd drive
Most times there are a few screws just below the drive. Open the drive, remove the screws, the drive should slide out. It'll be a little stiff at first until it's unplugged.
Oct 22, 2012 | Micro Electronics WinBook Si Notebook
No image on monitor, only beeps four times
Four beeps means Faulty RAM.
1. If u know how to open and set RAM, then open ur RAM by simply opening the RAM cover on the backside of ur laptop, there wil be 2 screw, u have to open it first, then just remove RAM by pressing both side locks.
2. After removing the RAM, clean it with news paper aur any clean cloth.
3. Place the RAM again to its slot. (remember the cut mark of slot, don't try to place hardly)
4. After placing RAM, tight screws and then start the laptop again.
5. If the beeps are coming again then change the RAM. (If it is in warranty u can replace)
Jan 31, 2011 | Micro Electronics WinBook Si Notebook
My winbook wont charge
turn off remove the battery
plug in charger and see if laptop turns on
fiddle with cord to see if laptop cuts off. If so you need a new charger or
the jack in the laptop has a short.
If if stays on the battery may be bad
Nov 08, 2009 | Micro Electronics WinBook Si Notebook
Replace keyboard on Acer 4720Z
Hi..
I will provide you a solution this solution are very useful with you. You can do it with your self to follow this instructions. There are some image on how to replace the keyboard.
These instructions will help you to remove and replace keyboards on various laptops. I will not be able to cover all models but you’ll get the idea. Steps for removing and replacing the keyboard are similar for most laptops.
Warning!
- if your laptop is still covered by the manufacturer’s warranty, do not open the case or you can loose the warranty
- always remove the battery and unplug the AC adapter before you open the laptop case
- if you damage the keyboard connector on the motherboard you’ll have to replace the whole motherboard
- proceed on your own risk
Sony laptop
I took these pictures from a Sony Vaio PCG-K33 (model PCG-9S1L) notebook. Should be similar for some other Sony notebooks too.
sony-keyboard-1.jpg Insert a small flathead screwdriver under the keyboard bezel and carefully lift it up. Continue releasing plastic latches and removing the keyboard bezel with your fingers.
Be careful, on some models the bezel might be connected to the motherboard as it shown on the picture above. If you accidentally pulled the cable, connect it back. It is not necessary to disconnect the keyboard bezel from the motherboard in order to remove and replace the keyboard, just put it aside so you can access the keyboard screws.
sony-keyboard-3.jpg Remove three (or more) screws from the top of the keyboard. Carefully lift up the keyboard from the laptop case.
sony-keyboard-4.jpg The keyboard connects to the motherboard via a flat ribbon cable. Before you pull the cable from the connector, you’ll have to unlock the connector.
sony-keyboard-5.jpg The image above illustrates how to unlock the keyboard connector. Carefully move the connector lock 2-3 millimeters up and after that pull the keyboard cable. To install the keyboard, follow the above mentioned steps in the reverse order.
Toshiba laptop
The following pictures were taken from a Toshiba Satellite A135 laptop. The keyboard removal instructions will be almost the same for most modern Toshiba laptops.
toshiba-keyboard-1.jpg The keyboard bezel removal procedure is similar to the above mentioned Sony Vaio laptop. Lift it up with a small screwdriver and remove using fingers. On most Toshiba laptops the keyboard bezel doesn’t have any circuit board underneath, it’s just a piece of plastic and you don’t have to worry about cables.
toshiba-keyboard-2.jpg After the bezel is removed you get an access to the keyboard screws. Remove two (or more) screws. Release the plastic latch pointed with the red arrow and lift up the keyboard. Carefully put the keyboard aside so you can access the connector underneath the keyboard. Do not forget that the keyboard is still connected to the motherboard.
toshiba-keyboard-3.jpg Before you remove the keyboard, you’ll have to open the connector and release the flat ribbon cable.
toshiba-keyboard-4.jpg Here’s a closeup picture of the keyboard connector on the motherboard. Be careful, this type of connector is fragile. On the left image the connector is closed. On the right image the connector is opened. Unlock the connector by moving the lock up as it shown on the right image and after that release the ribbon cable. Remove and replace the keyboard. For assembly instructions follow all the steps in the reverse order.
Hope it is helpful for you!
Thanks for using Fixya
Regards
ICmanServer
Aug 04, 2009 | Acer Computers & Internet
Replace keyboard Sony
Hi..
Warning!
Sony laptop
Toshiba laptop
Regards
ICmanServer
Aug 02, 2009 | Sony VAIO VGN-BX543B Notebook
How to remove Keyboard from Toshiba Satellite M45 latop.
Before you open the laptop case, remove the battery. The keyboard securing strip doesn’t have any securing screws and shouldn’t cause any problem when you remove it. The keyboard cable connector on the system board is cover by a metal plate and the plate has to be removed before you can get an access to the connector. Before you pull the keyboard cable from the connector you have to unlock it. To open the connector, move the connector lock toward the LCD screen. It is enough to move it 2-3mm to open the connector. Be careful with the keyboard connector on the system board. If you damage it, the entire system board has to be replaced.
Hope this helps
Jun 10, 2009 | Toshiba Satellite M45-S331 Notebook
I have a WinBook XL Laptop that will not Power up,start up, switch on.
Check your power adapter if it is still working. Try taking out the battery and plugin the power adapter and see if its gonna turn on.
Jun 02, 2009 | Winbook Corporation PowerSpec MCE 410 PC...
Laptop CMOS battery
This is for Winbook WinBest 233MMX may be good for other Winbooks
Had trouble booting then just quit booting altogether...
For a quick fix that won't require soldering....
Replace the cmos battery2.gif. If it is more than 7 years old, it will most likely be weak or dead.
Remove the keyboard by sliding the KB toward you and lift the top up and slide out, Remove KB ribbon cable2.gif from connector by pulling on the plastic tab, remove the 4pin KB power connector. Then remove bottom screws and separate the case.
Locate the 3V battery, Pry the top tab of the 3v battery off the welded ends with a small needlenose, Pry the battery off the mini board, bend battery tabs so the new non-tabbed battery will be squeezing the new battery for contact, + is up!, add a piece of electrical tape to secure it from sliding. Replace bottom case and screws and then re-attach keyboard2.gif ribbon cable and 4 wire power connector. Re-boot and reset cmos ( CTRL-ALT-S ) on boot. Set your time. You must set the boot sequence to C:. It will then auto boot to C: WALLA! WIN98!
Mar 18, 2009 | Micro Electronics WinBook J1 Notebook
Micro Electronics WinBook Si Notebook Logo
636 people viewed this question
Top Micro Electronics Computers & Internet Experts
Dennis Maeder
RSole
Masood Rasool
Level 1 Expert
Are you a Micro Electronics Computer and Internet Expert? Answer questions, earn points and help others
