My transcend storejet(ts320gsj25m) is not detected for my laptop.
My System Details:
Compaq Presario v5000
Windows XP service pack 3
Hard disk 80 GB and RAM 512 MB
You may just using just a data usb cable on your hard disk. Try to get usb cord with data and power cable (combo) and check if this resolves your concern.
The problem is the usb ports in your pc. You know the drive works and is properlly deteced on the laptop so you can ignore that.
IF you can try other usb devices in your pc usb ports and see if they work.If they don't at all then you either have dead ports or drivers are missing. You should see them listed under control panel system hardware.
If they work then I would wonder if the usb drive you have requires a differant usb port than what you have. There is a type 1 and 2 and type 3 which has just come out so we can ignore that one. A type 1 is slower and cannot power devices usually. A type 2 is faster and can power some devices. I don't know how old your pc is so it could be hardware, either failure or drives. You should also makre sure you have the service packs installed for windows. Sp3 is the latest version. There were some changes to the way usb devices were deteced in Sp2 if I remember correctly.
HI Presario was design for windows vista. if I am sure the windows you're installing cannot find the hard disk. I it is not compatible with the machine, look for I higher windows version and I recommend windows XP professional service pack 2 as the lowest you should use. thanks
