Whirlpool Heavy Duty Super Capacity Plus top loading washer
The tub fills with water but won't spin. I then have to manually turn the knob to rinse afterwhich it will drain but still not spin.
  • 6 more comments
  • joss333 Dec 23, 2008
    Recently I have been noticing water leakages on the bottom of the washer after a cycle. Not sure if it should be repaired or if it is the end of the road after 9 years of dependable usage.
  • Anonymous Feb 18, 2009
  • rybeck Apr 11, 2009
    When my Whirlpool washer reaches the rinse cycle...I get nothing. I have also had water coming out of the bottom of the unit. Mine is also 9 years old.
  • zantha72 Oct 21, 2012
    Tub fills washer and drains all over the floor at the same time, any Ideas?
  • Anonymous Mar 17, 2014
    It sounds like it's trying to work but the tub isn't moving...
  • Anonymous Mar 21, 2014
    not drain
  • Anonymous Mar 23, 2014
    whirlpool heavy duty super capacity not draining completely - it rinses, spins, drains, rinses, spins, drains - but then at the end the clothes are wet with about 2 inches of water left at bottom
  • Anonymous Mar 30, 2014
    On medium water level, for cotton loads and perma press, it fills with water, agitates, and then stops. The water doesn't drain out. I don't know if its a good idea to manually advance the control dial past rinse to spin... and what the problem is. I don't know anything about mechanical things and I don't have money to fix it right now. Maybe my neighbor can help, but it is better to have an idea what might be broken....thanks.
I see water around the bottom outside of my whirl pool heavy duty spuer capacity washing machine...in the spinning cycle it appears to be going out the drain hose and drainning ok???
Posted on Aug 25, 2008
I just took the pump off the bottom of the motor. The pump is at the bottom of the machine. If you're handy, lay the machine on its back and remove the pump as follows: it is held by two clips that come right off, the pump is then connected to two hoses the one from the tub and the one to the drain, squeeze the hose clips with pliers move the clips up the hose off the pump, grab the hose ends and work them off the pump one at a time, they can be a bit stiff, don;t break the hoses or you'll have to replace that too. We are on our way to find a new pump and see if that solves the problem. The pump appears to have a crack in a worn out place. I believe this will solve the problem, it probably has no pressure with the worn place to pump the water out fast enough. I would like to know iof there is a filter to clean out that could be a problem too..
Posted on Dec 28, 2009
What is the capacity of a front loading whirlpool washer MO#GHW9150PWO
Whirlpool GHW9150PW 27 Inch Duet Front-Load Washer with 3.8 Cu. Ft. Capacity, 8 Wash Cycles & Triple Dispenser.
whirlpool ghw9150pw0 capacity Google Search
Nov 25, 2017 | Whirlpool Washing Machines
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Whirlpool Ultimate Care Heavy Duty Super Capacity Plus
clutch could be it check if nothing is jammed between tub andbasket. if u have an oily tranny i would replace it
Feb 12, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool gold UIltimate care heavy duty super capacity washer
Well you can check the capacitor with a meter for farads, but it sounds like you have a clutch and/ or gearcase failure causing the motor to overheat. The second thing to do is unplug the washer and check the timer. I would right after the agitation to inspect for heat and burnt connections.
Oct 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Fill Cycle Won't Stop
heres hteaprt numbr for both the water level switch and the connecting tube, before i replace he switch make sure the tube is connected to rear of tub nad isnot cracked or kinked, and connected correctly to the switch for that matter. a hole in the tube would hamper he switches ability to sense when unit is full
3356466 water level switch,3347780 pressure switch tube
Mar 16, 2008 | Whirlpool LSQ9030P Top Load Washer
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Super Capacity stuck on rinse
Krom, sounds like the machine is syphoning. Check the drain hose and make sure there is a air gap and that it is not too far down the standpipe or drain. To test it hold the drain hose right at the drain top and see if the problem stops...Catriver...post back.
Jan 18, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
4,753 people viewed this question
Top Washing Machines Experts
