Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
My harley idles at 600rpm instead of 1000rpm and it has a flat spot under acceleration.I bought some bad gas awhile ago but ran a few tanks through it since.What's the problem?
Here is one thing to check. i live in south louisiana and due to the tight gasoline supplies, most of the stations here went to ethanol blended fuel to strech out their inventories. i have an xl 1200 which ran fine until i had to use ethanol fuels. this is when my bike started acting crazy with idle and all, but ran like a scalded dog elsewhere. my solution was to up the pilot jet two sizes. after this everything is ***** dory. you might have to remove the plug on the idle air screw and adjust but i did not have to. the ethanol fuel in itself is not bad and harley ok's it in small quanties. the problem is the evaporation rate plays havoc on idle circuit.
Posted on Aug 13, 2008
    Genius:
  • 2,028 Answers
Check and clean the air filter first since it's going to be the easiest to get to. Then, if the bad gas had sediments in it, you may need to clean the fuel filter and the carb. It could also be that your carb is just seating and needs adjustment. Try adjusting the idle, if you have any fluctuation or it has a high idle from time to time, then set the idle back, and pull the carb and clean it, floats, jets, etc... This is, if it's a carburated model, if injected, then you will need to run an injection system cleaner through it and have the injection system calibrated.
6ya staff
SOURCE:
My 01 katana been sitting up it will crank idle for a few than die out and wont crank until it sit awhile
Hi, Kevin and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Bike dies when you give it throttle
Suzuki GSX600F Service Manual
OEM parts for Suzuki
http://mybikemanuals.com/suzuki/suzuki-gsx-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 04, 2016 | Suzuki GSX 600 F (Katana Motorcycles
Just bought a 1988 Ford Ranger 2.9 liter v6 today. On my way home from the gentleman's house whom i bought it from, the truck starts bucking and sputtering. When accelerating at highway speeds there seems...
well i'd call the basterd and ask him what he wants to do about it , or take him to court as he did not disclose these problems. Or did he? I would check the fuel system for leaks which causes engine to get air and less fuel than it requires or check tank for leak and also check motor for bad vacuum lines and intake gaskets. spark plugs check.
Feb 05, 2011 | 1988 Ford Ranger
Chugging when I accelerate
When you ran out of gas, the pump probably pucked up crud from the bottom of tge tank and clogged the fuel filter - it's not uncommon. I'd change the fuel filter, and pick up a can of Seafoam (Walmart or any auto parts store). The next time you fill up, pour the Seafoam into the tank and fill up on top of it. That'll help clean the lines, tank, and injectors. Then you should be good to go.
Mar 20, 2010 | 2006 Mazda 6
98 Corolla stalls or stumbles when cold
It sounds like you may have picked up some small debris from the bottom of the gas tank when you ran it empty. You may need to run a fuel/injector cleaning solution through the next tank of gas to clear the debris and consider changing your fuel filter too. Sea Foam is a great fuel additive and I recomment trying it full strength. Hope this helps!
Oct 06, 2009 | 2001 Toyota Corolla
Sluggish and no pwer up a hill. Almost backfiring in second gear.
Yea probably the bad gas clogged the filter or clogged an already dirty fuel filter. Try changing it. If not I would say try using a lower gear by turning off the overdrive.
Jul 21, 2009 | 1993 Ford Crown Victoria
2007 street bob stalling at when idling
If it does it only when the tank is stating to get low, you have a hole in the fuel line, which should be covered under warranty. listen to the tank when the level is low. If it sounds like water being sprayed in the tank, then more than likely that's your problem, The problem won't generally present itself when the tank is full, because the gas helps cover the hole in the line keeping the pressure higher than when it's low on fuel.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_5bac37c3cb991fdb
Jun 08, 2009 | 2006 Harley Davidson FXDBI Street Bob
Geo Metro 1994, diagnose no fuel presure problem.
Quite a few things can cause a car to die after idling for awhile, but if you have verified that the fuel pressure is actually dropping when the motor dies, the likely culprits are:
1) Electric fuel pump in the gas tank is bad
2) The fuel pressure regulator (on the throttle body) is bad
3) An electrical problem in the power to the fuel pump (like a bad fuel pump relay or lose ground wire to the relay's circuit)
Apr 04, 2009 | 2006 Geo Metro
2004 Hyundai Santa Fe problems- Help!
i have a 2004 hyundai santa fe and i've had the same problems. it's so random when it happens but it seems to be when its a bit warmer outside.. above 70 degrees. it's when i press the gas from a stopped position the car just almost dies. i've pulled out in traffic and thought i was going to get killed. then the car accelerates and the tires squeal and the engine revs super high. the car jerks and its very scary. i bought the car new in 2004 and it started doing it after a few years and it still does it. it's not the gas pedal. it seems like a glitch in the computer or something. it's very dangerous!
Aug 31, 2008 | 2004 Hyundai Santa Fe
Lands Phones Logo
151 people viewed this question
Top Harley Davidson Lands Phones Experts
Tom Diffin
Sheldon Dedek
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
