Question about Amana Refrigerators
Amana drs2462bw, replaced the relay a month ago, worked fine, till today,now melting, the compressor is making a hum/click.....is there a recall on this fridge?
  • 29 Answers
Relay has gone again or compressor has a problem
Posted on Aug 13, 2008
Three weeks ago my refrigerator went out including the freezer. We pulled it out, used our wet/vac and cleaned it out then turned the reset button and it worked fine. A week later it went out again and we...
im not sure what reset button you are using / but cleaning it out was good . and if it started running that was good. when it quit the third time . things that would cause this could be the cold control / very common / and at 15 yr old i would replace the compressor relay . that starts it . sometime you can hear it clicking or humming . ( trying to start . . so try the relay .. . and ck for bad connections on old wires to the compressor as the get brittle and burn off .. mm hope this helps .. feed back .. pls
Jan 19, 2011 | Amana Refrigerators
I have an Amana bottom freezer refrigerator, model no. BX21V1C,it stopped cooling and freezing. The relay was replaced 6 months ago and now it has happened again. You can hear the click and buzz of the...
Good day,
Sounds as if the relay has failed again. ....or when relays start going bad, it could be an issue with the internal part of the compressor.
But the relay approach should be your first step.
Thank you for using FixYa
Jan 26, 2010 | Amana ABB1927DE Bottom Freezer...
I purchased an Amana refrigerator that has been making a humming noise and will not keep food cold or frozen. what' wrong? The model # is ABB1924DEB, and I purchsed it in 2005. is it included in their...
The recall was for units that had embraco compressors. the relay would burn up and not start the comperssor. (hum and click) some amanas had tecumseh compressors. They would just scize up and not run (hum and click)No recall. remove the back cover and see what name is on your compressor. If its hot and trying to start, Embraco needs new relay, Tecumseh needs to be replaced with a embraco compressor.
Dec 01, 2009 | Refrigerators
The ice is melting in my Amana arb2205.It clicks,buzzes for a few
sounds like a bad compressor relay. The compressor it self might be bad but 80% chance it is just the relay.
Oct 23, 2009 | Amana ARB2205C Bottom Freezer Refrigerator
Amana ABC2037DEB after 4 years, now freezer click and hum melting
that click followed by a hum can only be one thing
pull the unit out and feel the compressor, if its really hot you have a relay and overload issue, and it struggles to start.
with any luck, it is the external relay and overload found mounted to the comresssor should be a lil white block
if not it will be two differant parts
a lil white one and a brown one
let these cool a bit and check both for continutity
ive included a link for the parts
they are 10 and 11 on the schematic
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174380&diagram_id=1358665#d1358665
Oct 22, 2009 | Amana ABC2037DEW / ABC2037DEB / ABC2037DEQ...
Amana refrigerators is not staying cold and freezer is not freezing. Makes a "humming" sound, on and off, like a low "grind" noise, or like the noise an airconditioner makes prior to kicking on.
Mine had the same problem, and I had a tech out today who determined it's the motor inside the freezer. It's (the fan) not running. It's a $100 part, but if your refrigerator is new enough, it's probably worth the investment to go ahead and have it fixed.
Jul 29, 2009 | Amana ABB1927DE Bottom Freezer...
Amana/Maytag ACD2234HRS sometime not working
If your compressor is running with the noise you described, I would make sure the parts that were replace on compressor are working properly. Also use a amp meter and get a reading on amp draw while it is humming. Anything that is above normal readings for the compressor would indicate compressor is bad or the relay and starter are not working properly. I need a series number also like a number 15 before the model number, Thanks, Sea Breeze
Mar 21, 2009 | Maytag MZD2766GES Side by Side...
When compressor clicks on it makes funny electrical humming sound and then makes click sound and does not get cold. the compressor feels hot.
sounds like a bad compressor to me, you should have 5 yr full warr on compressor, if over 5 years you can try to replace the overload relay assy attached to the side of the compressor
Nov 11, 2008 | Amana Refrigerators
Kirland Refrigerator
It sounds like your compressor has failed. The hum is the compressor trying to start and the click following is the over current protector opening.
Jun 16, 2008 | Refrigerators
Buzzing intermittent
It sounds like the ice maker. If you don't have the water hooked up, and the ice sensor bar is in the down position, the ice maker assembly will attempt to make ice continuously.
Solution is easy: raise the ice sensor bar until it clicks in the up position. It will lock in this position, and the ice maker will not cycle anymore.
May 04, 2008 | Amana ABB2227DE Bottom Freezer...
Refrigerators Logo
143 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
