Panasonic ER 240 Beard Trimmer Logo
Posted on May 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a panasonic ER240 trimmer. its blade has stopped working but the motor is still working. so how can i fix the problem or from where can i buy the blades for the trimmer?
chakkritc869
Level 2:
Producer:
Uploaded 30 video answers.
Filmmaker:
Uploaded 5 video answers.
  • Expert 95 Answers
  • Posted on Oct 14, 2013
chakkritc869
Expert
Level 2:
Producer:
Filmmaker:
Answers
95
Questions
0
Helped
21771
Points
194
Panasonic WER9606P replacement blades replacement hair trimmer blade for panasonic er2403, er2403k, er2405, er2405k parts.
1helpful
Remington BHT-2000 stopped working - missing/broken link between motor and blade?
yes there is something disconnected or broken the high pitched noise is because of the lost resistance from the blades 2 years full warranty .
If no warranty anymore is on it ask for Pricing for repairs ,because there can bemore differend prices on some models. that only a complete part must buyed that a complete new razor body is cheaper then the loose spare part. some marketing technical creations can have remarkable prices. thats why i know it will be a wise decision to inquire first advance because of and
To avoid repeating complaints if something is the cause on it and the problem will repeat the cause in a short time.
5answers
Brand new andis trimmer pulling hair and not cutting good
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at www.mannys-sharpening.com or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
Need a replacement blade for ER240 beard trimmer in bangalore
panasonic WER961P replacement blades for beard trimmer panasonic er240 cutter replacement parts.
panasonic er240 replacement blades
3helpful
2answers
Where can I find replacement blades for my Panasonic Model No. ES2113 Facial Hair Trimmer?
The response posted by brector3 is not exactly true. While this is an inexpensive trimmer, Panasonic DOES offer replacement parts for this item!!
Go to the Panasonic website (panasonic.com): hover over 'Consumer' at the top of the page, then select 'Personal Care'. When you get to the next page, simply enter the model number in the search box located in the top right hand corner of the page (hit enter). Click support and then you will see a link to find Accessories for this item. The direct link is here: http://shop.panasonic.com/shop/model/ES2113PC?support
If you are not sure which blade you need (or if what I have typed is too complicated), contact their customer service center at 800-338-0552 (if in the US). The blade cost $6, while a new trimmer is at least $20- don't be fooled into buying a new one!
NEED A REPLACEMENT BLADE FOR TRIMMER ER 240
10helpful
2answers
My Black and Decker hedge trimmer's blades won't move, but smoke and a burning smell comes from the motor. Can it be fixed? How much would it cost?
Your blades are stuck together.
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
1helpful
Power cable for er240?
I could not find just the power cable anywhere online, but I found the save shaver on ebay for 25 dollars. You could just use two AA rechargable batteries and get a charger for the batteries. :)
CST2000 Grass Hog Cordless Trimmer/Edger stops working until shaken
open up the motor housing maybe loose connection between the terminal & motor. for parts & diagram see www.dewaltservcienet.com look for the icon find it now & enter the model #
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
ADMIN Andrew
ADMIN Andrew
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
