Not used the PX-E855 for years. Now I need to there appears no power, fuse is OK Was fine when last used
This is an extremely simple unit: a power cord, a power switch, a motor powered at the mains that drives the platter thru a belt, with a small switch attached to the arm and a small electronic board to process the sound and sent it to the outputs.
If the unit is totally dead (the platter doesn't turn and the humming of the motor can't be heard when you move the arm) then it's either a power cable problem (it has a break in it) or one of the 2 switches has failed because its contacts have been corroded by the humidity in the air. Just check them with a simple multimeter and replace the failed one. The switches might be revived if you repeatedly activate them - with the unit unplugged of course.
