Question about Intel D945GTP Motherboard
Power SW, LED SW, etc. location
To start off i actually have an Intel 945GC Express, but this was the closest processor i could find.
So i just moved my PC into a new case and i can't figure out where the power switch and other switches plug-in. I've been trying for the past 10 minutes or so and can't get the right pins. IF anyone knows or has a diagram that would be great. thanks!
  • Intel Master
  • 3,051 Answers
If you go to motherboard.pronto.com they can help u out there unless you have a diagram on the inside of the case or any other documentation that came with your board or just contact the place where you got the board from keep me postedd ok best regards mike
Posted on Aug 14, 2008
SOURCE:
Dont know where i can put the power sw
go here ok jim http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=719&MenuID=1&LanID=0
Aug 18, 2014 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
I need a vedeo card that supports ecs livermore8
The Motherboard is considered the 'Building Block' of the computer.
From it all hardware components are supported.
Processor, Ram Memory, Harddrive, Optical Drive/s, and add-on expansion slot cards.
A graphics card (Video Card) being one.
You need a graphics card that the ECS 945GCT-HM,
or also stated as HP's Livermore8-GL6; will support.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01237572&lc=en&cc=pt&product=3632125#N33
The motherboard chipset is an Intel 945GC,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
According to Intel came out the first quarter of 2005,
http://ark.intel.com/products/34505/Intel-82945GC-Graphics-and-Memory-Controller
The year PCI Express 1.1 technology came out.
PCI Express 2.0 technology didn't come out until 2007,
http://en.wikipedia.org/wiki/PCI_Express#PCI_Express_1.1
Will the ECS 945GCT-HM support graphics cards based on the PCI Express 2.0 technology?
YES!
PCI Express 2.0 technology IS backward compatible, with PCI Express 1.1 technology.
You just won't get the full capability of the PCI Express graphics card; based on the PCI Express 2.0 technology.
Will you notice? Doubtful.
From what I have seen listed in reviews on the graphics card, I would not suggest a graphics card based on the PCI Express 2.1 technology.
Reviews suggest it doesn't 'play well' with a motherboard using the PCI Express 1.1 technology.
There is another thing to consider; Power Supply
Most decent graphics cards require a minimum Power Supply wattage, of 400 to 450 Watts.
This Power Supply requirement isn't just for the graphics card.
Graphics card manufacturers base it on a test computer system.
One they put together with a powerful Processor, high performance motherboard, 2GB's of Ram Memory (At least), optical drive/s, harddrive, and the graphics card. (Plus allowance for computer case fans, etc)
If you're running a 300 Watt power supply, this = No.
(Yes, even though AMD ATI Radeon graphics cards, are touted to use less power; 400 to 450 Watts is still the limit for a decent graphics card, from them. Unless you want to run a simpy PCI expansion slot graphics card, or budget/starter, PCI Express graphics card)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4501123&CatId=7387
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2555929&CatId=7387
Regards,
joecoolvette
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5344843&Sku=T925-3014
Dec 25, 2012 | ECS 100% Ok 945gct-hm Motherboard...
Intel D945GCNL has no display though ram, hard disk,power supply, processor is fine
Okay.
Provided you have checked out the simple stuff; monitor, AND monitor cable, suggestion would be to install a graphics card, and connect the monitor to it.
You won't have THE drivers for the graphics card installed yet, as you have no display, but you should get a display you can see well enough, to install the drivers.
I do need to ask a few questions before this is done, however.
1) Do you know the Power Supply is good?
Your LED lights may light, fans may spin, and it may sound like the harddrive is spinning, but the Processor may not be on.
Why?
A) IF, all of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is.
{ The Intel D945GCNL mobo has an LGA 775 processor socket.
Front Side Bus support is 800MegaHertz.
The motherboard chipset is an Intel 945GC (Part number 82945GC)
Can use up to an Intel Core2 Duo processor, with a 800MHz FSB.
These processors can use up to 65 Watts.
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_chipsets
I'll go with the chipset info, and not the stated 1066MHz support,
http://www.overstock.com/Electronics/Intel-Essential-D945GCNL-Desktop-Motherboard-Intel-945GC-Express-Ch-Refurbished/6113423/product.html
Stated facts from Intel,
http://www.intel.com/support/motherboards/desktop/d945gcnl/sb/CS-026727.htm }
2) How do you know the;
A) Processor
B) Harddrive
C) Ram Memory
D) Power Supply
,is fine?
Connected them/it to another working motherboard? Won't work with the harddrive, unless Windows Activation screen comes up, and then the harddrive will be for THAT motherboard, and not the original one.
Post back in a Comment.
Regards,
joecoolvette
May 21, 2012 | Intel D945GCNL Motherboard
No display
Hello Abhramukherj, try cleaning the memory slot. reset CMOS and retest RAM sure 100%.
Jan 21, 2012 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
I want to know that did intel d945gcr supports core 2 duo processor...............plz
This mother board will work if we have a compatible processor like Intel Core2 Duo, Intel Pentium D, Intel Pentium 4.But the processor should be greater than 2.99Ghz if the processor is less than this then it will to work.Dual core processor means there will be two processors working
The detailed specifications of the new Intel D945GCCR Motherboard are:
  • Form Factor:MicroATX
  • Processor:Intel Core 2 Duo, Intel Pentium D, Intel Pentium 4 and Celeron D processors in the LGA775 package
  • Supported System Bus:800 MHz / 533MHz
  • Chipset:Intel 945GC Express Chipset with ICH
  • Supports Hyper-Threading Technology
  • Graphics:Intel Graphics Media Accelerator 950
  • Graphics Connector:One PCI Express* x16 graphics connector
  • Memory Support:Dual-channel DDR2 533 / 400 MHz, 2 DIMM slots (2GB Max)
  • Expansion Slots:Two PCI connectors
  • One PCI Express* x1 connector
  • Audio:Intel High Definition Audio with 5.1 Surround Sound
  • USB Ports:Eight Hi-Speed USB 2.0 ports (4 back / 4 front)
  • Storage One IDE (ATA 100/66/33)
  • Four Serial ATA ports (3.0 Gb/s)
  • On-Board LAN:Intel PRO 10/100 Network connection
  • Warranty:3 year limited warranty
Hope that solve your problem!
Thanks for using Fixya!
Dec 15, 2010 | Intel D945GCCR Motherboard
Computer does not start. CPU fan tries to move and stops
your processor is overheating. if you know how to open your cpu, that would do the trick. you should check out your cpu fan and try to clean it up. maybe it is all covered with dust. it cannot let the heat go out because your fan is clogged with dust. also, clean your processor.
Nov 01, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
LED connectors
The LED pins should be on the front panel header.  See page 12 of the manual which can be downloaded from http://download.ecsusa.com/dlfileecs/manual/mb/eng/p4/945G-M3.zip.
Jan 25, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Intel D945GTP Motherboard Logo
115 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
