Question about Compaq Deskpro 2000 PC Desktop
New (used) hard drive
I installed a new hard drive, set the jumper 2 master, (the cd rom is slave)when I rebooted I got a disk 0 error.... Can u tell me what I can do to get it 2 recognize the new hd??? THanks, prince_fanatic2003@yahoo.com
Thanks,
Tony
  • 158 Answers
Just remvoe the cd rom and then try to install your hard disk. if it is detected than it means there is a problem of setting master and slave in jumper.
So just check again your jumper settings and read the front side description of hard disk for jumper settings.
Posted on Jan 31, 2009
NEED JUMPER SETTINGS FOR MASTER HARD DRIVE
Set The Jumper Setting On Your Hard Disk Drive
The hard disk drive will be detected as 32 GB if the jumper is set to the 32 GB clip pin setting. The common jumper settings for Samsung hard disk drives are listed below. Please check the label on your hard disk drive for the correct jumper setting.
Important: Use the alternate jumper setting listed below under General Pin Setting. After changing the jumper, partition and format your hard disk drive.
Configuring your Hard Disk Drive (Master, Slave, or Cable Select) - Setting the Jumper
If this is the only HDD in your computer, set the pin setting to Master.
If this is the second HDD in your computer, set the pin setting to Slave.
If this is the second HDD in your computer, and the first drive is set to Cable Select, set the pin setting to Cable Select.
If you are replacing the HDD in your computer, set the jumper setting to match that of the drive you are replacing.
Cable Select:
This setting is the default setting for PATA/IDE hard disk drives. With the Cable Select jumper setting, the BIOS determines whether a hard disk drive is Set as Master or Set as Slave by it's position on the UDMA cable.
If the hard disk drive jumper is set to Cable Select and is connected to the black connector on the end of the UDMA cable, it is recognized as Set as Master for that PATA controller.
If the hard disk drive jumper is set to Cable Select and is connected to the grey connector on the middle of the UDMA cable, it is recognized as Set as Slave for that PATA controller.
Note: When using Cable Select, your system must meet the following conditions:
Your systems host controller must support Cable Select.
Your hard drives must support Cable Select.
Your cable must support Cable Select.
Set as Master:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Slave, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
Use this setting if you are installing an additional hard disk drive to a single UDMA cable and the Cable Select setting is not recognized.
Set as Slave:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Master, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
32 GB Clip Pin Setting:
Use this on computers manufactured before November 1998 when either you start up your computer and see the message, "Hard disk drive controller failure", or your system stops responding during the boot process after installing a new drive. This occurs when the hard disk drive is too large for the BIOS to support.
If after performing the troubleshooting procedure listed above, the full capacity of your hard disk drive is not recognized, click here for information about obtaining a system BIOS update. If you are unable to update your BIOS, another option would be to create a second partition with the remaining unallocated disk space.
Aug 18, 2012 | Computers & Internet
Getting three beeps with my asus m4a785t-m motherboard initializi
Okay, not much else is mentioned about the system so I would assume you have one CD/DVD drive and now two HDDs and your new HDD is still set to factory default of "Cable Select" or CD, if not and the new hard drive is a replacement for a damaged OS (Operating System) drive, then you need to insert the Windows OS Installation disk prior to booting and set the system to check your CD-ROM before checking Hard disks, for the OS.
First off if IDE, you have a ribbon that resembles this [====[========[ the furthest to the right would be what plugs into you motherboard, being the one with the furthest distance between itself and the next plug/connector.The one on the other end is for the Master drive and teh middle one is for Slave.
If only one HDD, then the jumper for the new drive needs to be set to Master and the CD/DVD-ROM needs to be set to Slave.
  • If two HDDs & one CD/DVD Rom, On the primary IDE Controller, set the OS HDD to Master, the CD/DVD-Rom to Slave & put the second HDD on the secondary IDE Controller as Master.
  • If two HDDs & 2 CD/DVD-Roms they must be set up on totally different IDE controllers to cancel out the chance of cross-communication. This happens on some systems because of having two CD/DVD Roms and/or two IDEs. So, we set the OS HDD to Master on the Primary IDE Controller & we set the CD/DVD-Rom to Master on the second IDE controller and the
I would normally say that three beeps from the motherboard itself would be either graphics card or memory problems, normally solved by simply pulling either or both and reseating them. Wear Nitrile gloves (the blue ones) to keep oils and static charge from damaging the components, ground yourself &/or touch the case before and while pulling the components. Check this site for "Post Codes" if the beeps are coming from the MoBo... if you have Award BIOS (should show what BIOS brand when booting up the system)
Award BIOS Post Codes
If three beeps from the system itself, then that would say it can't find the OS... and you might possibly also find an error on the monitor, stating something similar to "no power to monitor".
If you don't have an illustration on your drive telling you what pins are for what when it comes to the jumper, then search google for the drive brand and the word "jumper" or words "jumper configuration" or "jumper placement"
example: Maxtor Jumper configuration
If the system is SATA only (I believe it to have at least one IDE controller unless the board's controllers are all blue & black, to which I see a controller, but can't tell if it is FDE or IDE), then you'll most likely have to enable the SATA controllers in BIOS and set the boot preference/sequence/order as mentioned above, to check the correct disk for the OS, after removable devices & CD-ROM. Should be that order anyway, with floppy seek disabled to save wear on the head.
Hope that was not too much and that it helps!
Apr 15, 2010 | Frigidaire FEQ1442ES Electric Dryer
Reinstalling the original cd rom that came in the computer. do i need to change the jumper settings. it is a samsung sc-148
That depends upon the IDE cable you are attaching the CD ROM to.
There are two IDE cables attached to the motherboard, on IDE 1 connector/cable will be your boot hard drive (C drive) and this will be jumpered to Master and you can attach the CD ROM drive to this cable and set the jumper on the CD drive as Slave.
On IDE 2 connector/cable if there are no drives attached to this cable then the CD ROM drive can be jumpered as Master or Slave..
If there is another drive on the same IDE 2 cable then look at the jumper on that drive, if it is jumpered to Master then the CD drive needs to be jumpered to Slave. If the existing drive is jumpered as Slave then the CD drive needs to be jumpered as Master.
Both drives on the same IDE cable cannot be jumpered with the same setting.
Nov 30, 2009 | Computers & Internet
Trying to install Windows XP SP1 onto HD with this Motherboard. System will not boot from HD to start install.
Make sure your IDE hard disk drive is connected to IDE1 port and that the data cable is fully connected. Also check the jumper on the IDE drive. If you are using only one IDE hard disk drive set the jumper on the drive as a Master without a slave. If you are running two IDE hard disk drives set the primary drive's jumper as a Master with a slave. Set your second IDE disk drive's jumper as a slave. The master drive should be connected at the end of the data cable and the slave drive should be connected to the next data connector. Than check your bios settings. Power on the system and press the Delete key every 2 seconds until the bios menu loads. See page 3-1 in your manual. If you need the manual for the NF8-V MB click on the link provided below and download it;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF8-V&fMTYPE=Socket+754
You'll also need the program Adobe reader to view the manual. Adobe reader is a free download; http://www.adobe.com/products/reader/
Once you’re in the bios go to page 3-4, Standard CMOS Features.
Follow the instruction listed for IDE HDD Auto-Detection. Your HDD should be listed here. Than see page 3-7 in the manual. Open Advanced BIOS Features. A normal boot menu for the Abit would read;
First boot device Floppy disk drive (If one is connected). 2nd boot device should be (CD-ROM/DVD-ROM). Third boot device should list your primary hard disk drive's (Model number). Load your windows CD into your CD-ROM drive.
Once the settings above are set, press the F10 key to save your changes and exit the bios. Your system will auto restart. Windows should begin to load.
Cheers!
Mike
Nov 18, 2009 | Abit NF8-V Motherboard
I am installing a new WD3200AAJB HD in a Dell Dimension 4550. This is the only HD in the system. There are also 2 CD drives and a floppy drive. I used the jumper settings the drive came with which pins...
Reinstall your old hard drive as master and install the new hard drive as slave.
Here is the link to jumper settings from Westrn Digital;
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1540&p_created=#jumper
If you've got your jumper settings wrong and installed your os on the 127 GB section of the 320 GB Hard drive and you change jumper settings and then you have problems you may need to reinstall the old hard drive as master and the new hard drive as slave. Reformat the new hard drive as 320 GB, and as a bootable drive. You can either do a disk copy from old to new or reinstall your os on the 320 GB drive. Please let me know how this goes. You can get to me @ johnkariotisjr91741@yahoo.com
Oct 25, 2009 | Dell Dimension 4550 PC Desktop
Sir When i connect cd rom & hard disk together on my computer then the does not work.Kindly give me a solution.
There is a jumper in HDD and CDrom
  • Set the hard disk jumper to Master Connect the drive using the Master connector on the primary IDE cable.
  • Set the CDD jumper to Slave Connect the drive using the Slave connector on the primary IDE cable.
To know about jumper settings verify this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03792&lc=en&dlc=en&cc=us&product=3872037
Aug 28, 2009 | Computers & Internet
Intel 845epi board not booting
Please go through the following option :
1) Check the master and slave jumper settings of hard disk and CD-ROM. Hard disk jumper setting should be Master and CD-ROM should be slave.
2) Check the cable of hard disk and CD-ROM.
3) Use different power supply which should be in good condition and than attach your hard disk and CD-ROM.
Mar 20, 2009 | Intel D845GVSR Motherboard
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
Dvd rom drive
is cable on master jumpers or slave ?
Feb 07, 2008 | NexxTech (COB6V5216) Burner
Compaq Deskpro 2000 PC Desktop Logo
110 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
