Question about PC Chips Computers & Internet
USB PORTS DOESN´T WORK
  • pjmarc Aug 13, 2008
    USB PORTS FAIL,
    IN HARDWARE PROPERTIES EVERYTHING IS OK.
  • pjmarc Aug 15, 2008
    into boot USB ports are enabled.
    and
    into hardware properties everything is ok.
    when I connect an USB flash memory it detects something and shows a message :´UNKNOWN HARDWARE´´
    but the keyboard works ok.
    I work win xp sp2
I SOLVED PART OF THIS PROBLEM.
I FOUND L14 ON THE BOARD OPENED
Posted on Oct 10, 2008
  • 3,051 Answers
If you boot into bios and go to periphials section the usb ports should be there make sure that they are enabled and then save and exit and reboot
Posted on Aug 14, 2008
  • Michael Thomas
    Michael Thomas Aug 16, 2008
    that is good if you are getting a unknown device notice least you know that port is workiing and when the unknown device shows up it probably does not finish loading right cause it is looking for the hardware if u have the cd for the device then install it i just about 1 hour ago got a new keyboard and ut hooked into the usb port and the same thing happned once i installed the cd and loaded it all it worked great
  • Michael Thomas
Doesn t recognize usb connection.
check follows :- Computer's USB Ports are Working or not ?
Printer's USB cable is ok or not ?
Printer's USB Port is ok or Not ?
Change Printer's (Logic Card )Formatter Card.
Nov 24, 2013 | HP LaserJet Office Equipment & Supplies
It doesn't recognize USB flash drive anymore
The flash drive itself may be faulty or damaged, and sometimes this is not apparent from a physical inspection. Try attaching the drive to a USB port that you know is operational, and try plugging another USB device into that port to verify that the port is working.
Jun 19, 2012 | Kenwood KDC-MP445U CD/MP3/WMA/AAC Receiver...
Team promark keyboard won't work
If it has a USB plug, try attaching it through a different port hub, i.e. not the usb port right next to the one that didn't work. If that doesn't work, test the usb port with something else first. If the USB port is not the problem, you may need to download a driver for the keyboard.
Jan 03, 2012 | Team International Team ProMark Carolina...
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
My computer doesn't recognize my dane-elec 8gb usb stick , although other usb devices do work.
1. Try a different USB port. If other ports recognize it, then the original port is fried. 2. Try a different computer. If the other computer does not recognize it, then your flash drive is damaged.
Good Luck!
Aug 19, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Computer will not recognize mp3 player, device doesn't light up
The two most likely causes for this is either your USB port or the USB cable itself. Try plugging the device into different ports and if that doesn't work, get yourself a different USB cable. If neither of those works then your device is faulty and the only fix for that is to get it serviced by the manufacturer.
Jul 02, 2011 | Computers & Internet
My usb port wont reginize my usb stick
try putting your USB stick in the port provided at the back side your PC !!! if it doesn't work try in your friends PC if it doesn't work there then your USB stick must have failed!!
Jun 15, 2011 | Computers & Internet
Divice not reconiged
plug it again and if it doesn't work at all try other USB port. A USB flash drive nowadays supports only 2.0 and above USB ports. It all about signal speed a USB 2.0 and above were backward compatible with USB 1.1 .
May 27, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
253 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
